TSSTcorp DVD+-RW TS-L632D ATA Device
Cool thnx for the info.
Here is the link to install the Drive firmware.
http://ftp.us.dell.com/rmsd/DE04-2.zip
Make sure you remove any CD or DVD from the drive before installing this firmware update.
After extracting all the files to Desktop, run the file SFDNWIN3.27.11.exe
And then click on the left most button at the top of smaill firmware window and after selecting the firmware file that is: DE04.BIN
click on the second button from left to update the firmware.
Restart the computer after that update and issue should be fixed.
Thanx
Ricky
ok i did that but when i run the file SFDNWIN3.27.11.exe it says drive not found before it opens...
Thanx
Ricky
Oooooooooooooooooooooo
Is the drive visible in My computer, if it is not then check in Device manager for any yellow mark on the drive.
If there is a yellow mark on the drive then right click on it and delete it.
after that follow these steps:
Step 1: Start Registry Editor
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry
1.In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.2.Expand SYSTEM, and then expand CurrentControlSet.3.Expand Control, and then expand Class.4.Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.5.In the right pane (topic area), click UpperFilters/LowerFilters.bak.
Note An UpperFilters.bak or LowerFilters.bak registry entry may also appear. To delete the UpperFilters/Lowerfilter registry entry, you must click UpperFilters/Lowerfilter and not UpperFilters.bak/LowerFilters.bak.6.On the Edit menu, click Delete.7.When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?
Restart the computer and get the drive working.
I have the same problem. I did as noted above. I expected a prompt to re install the device when the computer restarted, but it didn't come up. What do I do now? :confused: I'm a ditz when it comes to puters. How do I re install the optical drive?
Also, it is my fear that this is only going to be a temporary fix.
(Mine is a TS-L632H)
Please check if the CD drives are visible in My computer , if they are not follow this KB article and restart your computer and it will be fixed.
You can no longer access the CD drive or the DVD drive, or you receive an error message after you remove a CD recording program or a DVD recording program in Windows XP: "error code 31"
Enjoy!!!!
Hey, it's working without being re installed. I expected to have to re install it. I just put a cd in it and it worked.
I'm hearing of the problem coming back, but I don't know if they did this same thing or not, though.
This post is for Roy_ricky Stallion.
I also have a 4-month old Inspiron 1720 Laptop with a 'detectable'-but-by-yellow-warning-sign-in-Device-Manager TSST TS-L632H ATA CD/DVD Rom. Never worked. No official Dell/firmware links or updates have worked. Spent hours and days getting old and frustrated and loserly chasing the endless solution options offered on various posts and forums. YOURS is the only one that has worked :) At least it shows up now in Explorer and I can read and copy from the drive. I'm not tempting fate today to see if it will burn... another day.
But thankyou thankyou thankyou thankyou for the help and relief and sanity your posts have finally given me.
Hurray indeed!!!
Hurray indeed!!!
You are most welcome my friend.
And sorry for replying late. Was busy in office you know holiday season...
I am having a similar issue with my tsst corp cd/dvdw ts-L632m ata device. I have an hp dv2601tx notebook and it has stop reading dvds. It still reads cds. I have removed then reinstalled the drivers yet still it doesn't work. I have also removed the dvd burner phsyically and again no success. Can anyone assist?
    hp pavilion dv2601tx
    hitachi 240 g
    intel r core (tm)2 duo cpu t7500 @2.2 ghz
    4 gig
    nvidia nb8m-gs
I am sorry sir, I couldnt find any valid download for this drive.
I will look more and once I get the link, I will forward that you.
Windows Vista Home Premium Edition
i'm not sure what you mean by system model haha but my laptop is a Dell Inspiron 6400 (does that help?)
Thanx
Ricky
I've done this and it did not work. My situation . . . same computer, same OS, same DVD player as previous poster. . . DVD quit working a month ago. I am not getting any error notices. Yesterday had computer technician replace my old hard drive with new, bigger hard drive. He used this DVD player to reinstall OS and drivers, but when came to install application software, DVD player wouldn't read it. DVD can be seen at Computer, Devices with Removable Storage . . . it makes noise when you put in a CD . . . the curser briefly shows a spinning CD . . . the player can be opened and closed using the computer . . . it just will not read the CDs which I need to install applications.
    Dell Inspiron E1505 laptop
    Intel Core Duo CPU T2250 @1.73 GHz
    2GB
    WDC WD2500BEVT-22ZCT0 ATA Device
Thanx
Ricky
I've already unistalled the driver n done the whole step, but I cannot find the UpperFilter/LowerFilter in the topic area... though there r seperate Upper Filters n lower Filters.... Plz help me out
Thanx
Ricky
I get an error of "This firmware is not compatible with the selected drive". I have already deleted the filters and triple checked the drive model info. I have also deleted the drive through Device Manager and re-booted. I have also used the cdgone.reg to no joy. Any ideas?
Just tried the fix that Ricky posted where you delete the drive and delete something else named the upper/lower something or other (that's techie jargon there!). Anyhoo, I might not have the correct words, but the fix worked! I'm thrilled! Thank you so much!
Linda
Thanx
Ricky
Just wanted to say thank you, that you rock, and you saved me untold frustration.
Hi, I'm new to this forum and discovered it while trying everything I could to fix my new lap top. It is HP Pavilion dv5. It came with 64 bit Vista home. Due to problems with the network connection at work I upgraded the Vista to Ultimate. This apparently knocked out the TSST TS L633L drivers or at least they don't work. I've tried removing and reinstalling. I've tried different scans that all report the driver is fine. I get the error code 39 when working through the device manager. The Toshiba and Samsung sites have not revealed a patch to me.
HP was a lot of help: "we don't support the system when you upgrade".
I bought it at Best Buy and the "Geek squad" guy looked at it and ran his thumb drive with Avast and said I had picked up a virus. I've done full scans with 3 different antivirus programs that can find nothing (Avast, Kaversky, Norton) so I doubt that is the problem.
Has anyone else figured this out?
Thanks
