Solved TSST corp CDDVDW TS-L632H ATA Device
What OS are you really using? Windows Version 5.2 relates to Windows Server 2003 and XP Professional XP3 (assuming that's what version means in that message) - but not as far as I know to Vista. Are you absolutely certain you're using the correct drivers for your OS?
How are you doing on sending us those reports and doing those other tests and procedures? We can't help you much without more information and unfortunately although this message relates to the problem, it doesn't really help because it leads us to no solution that I've been able to find. The other reports may be more helpful.
Thanks for the update. Remember, the more you do and tell us about (including test results, reports, and the like), the more we can assist you. At this point, we are pretty much at a standstill until you provide more details and information and the results of those procedures.
Good luck!
    1920 x 1200 pixels
Re: Vista:Windows was unable to complete the format...enlighten me.
Please try these drivers: -
Driver Details - Toshiba
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
I ran the setup,nothing has changed?
    Toshiba L305D-S5900
Does the unit read/ play CD's or DVD's?
    40 Meg
yes it can,exceptionally well =]
the problem is i cannot format my dvd's so i can burn my data onto them
    Toshiba L305D-S5900
Ok,
Back to basics.
You say it will not format with any software.
  1. What software, versions too please, have you tried?
  2. What brand of CD/ DVD have you been trying to format?
    40 Meg
I have tried nero 6-10,roxio,toshiba disc creator,and my main concern is the windows thing,live system file and mastered....
    Toshiba L305D-S5900
The message from MS implies the the CD/ DVD is damaged in some way. This could be a manufacturing flaw or just a damaged surface.
The reason for asking about the brand is relating to die formats as some devices are "Particular" as to what media they are fed!
See: - http://www.proactionmedia.com/dvd_media_formats.htm
QUOTE[
Is it true there are compatibility problems with recordable DVD media formats?
Yes. A big problem is that none of the writable formats are fully compatible with each other or even with existing drives and players. In other words, a DVD+R/RW drive can't write a DVD-R or DVD-RW disc, and vice versa (unless it's a combo drive that writes both formats). As time goes by the different formats are becoming more compatible and more intermixed. A player with the DVD Forum's DVD Multi is guaranteed to read DVD-R, DVD-RW, and DVD-RAM discs, and a DVD Multi recorder can record using all three formats. Some new "Super Multi" drives can write to DVD-R, DVD-RW, DVD+R, and DVD+RW, but not DVD-RAM.
In addition, not all players and drives can read recorded discs. The basic problem is that recordable discs have different reflectivity than pressed discs (the pre-recorded kind you buy in a store), and not all players have been correctly designed to read them. Very roughly, DVD-R and DVD+R discs work in about 85% of existing drives and players, while DVD-RW and DVD+RW discs work in around 70%. The situation is steadily improving. In another few years compatibility problems will mostly be behind us, just as with CD-R (did you know that early CD-Rs had all kinds of compatibility problems?).
]UNQUOTE
    40 Meg
Well here is the problem i have been facing......i have burned a lot of these disc and all of them work fine...i appreciate your help but i cannot understand why it used to work and now it doesn't?
i was thinking it was drivers as well but this dvd rw is almost rogue...i cannot find anything on it besides people complaining about this same problem
    Toshiba L305D-S5900
    40 Meg
well i did have a few spare dvd-r instead of dvd+ r laying around...the -r works fine but i am still troubled =/
    Toshiba L305D-S5900
Well what more do you want me to say: -
Change the DVD writer or something???
    40 Meg
i mean i know their isn't a lot to say,im just wondering why they stopped working after using half of a stack out of a hundred pack
    Toshiba L305D-S5900
There must have been an issue & be a bad batch or they have got damaged somehow?
Sorry.
    40 Meg
well thank you much for your time and support...thanks
    Toshiba L305D-S5900
Dvd+R to DVD-R TSST corp CDDVDW TS-L632H ATA Device
So i ran into this problem...dvd+r cannot format but dvd-r formats with out a problem.
After going through half of a stack of 100 DVD+r the disk decided to give me the trouble...TSST corp CDDVDW TS-L632H ATA Device is the device i am using.
I know some drives cannot format some disc but this is why i am troubled....i USED to be able to use the DVD+R disc and format them =/
any suggestions..?
    Toshiba L305D-S5900
any suggestions..?
I did the chkdsk scan and it said it would post the results next time i logged on,but i didn't see it =/
    Toshiba L305D-S5900
In a prior post we requested additional infomation and we still need that information to try to assist you. Go back and perform those tests and procedures and answer those questions and then post the results and anything else you learn along with the requested files and we'll take a look and see what we can do.
We appreciate the update and the new explanation of the problem, but we need that other information.
Thanks and good luck!
    1920 x 1200 pixels
I think I am sure about using the right drivers for Vista Home Premium
Is there any way i can check?
As far as i know i am Using SP2 with my vista
I updated my toshiba L305D-S5900 bios from 1.50 to 1.90
I have downloaded the latest firm ware and installed it correctly i believe for the TS-L632H.
Device manager did not have any notification boxes and properties claim the device is working properly.
On the Dell website i found information about the device and it says it is compatible with all dvd's and cd's so disregard what i had stated previously.
    Toshiba L305D-S5900
There aren't likely separate drivers for Home Premium versus other versions of Vista - what I meant mostly was 32-bit vs. 64-bit. You need the ones for the appropriate OS bit-size. I have no idea what you installed so I don't know for sure, but the fact that there isn't an error message and that it says it is operating properly suggests you're OK there.
You are using SP2 - it's in one of the screenshots you included.
We can now cross outdated BIOS off our list (but not whether or not they are properly configured and I don't know how to do that as it varies from manufacturer-to-manufacturer and version-to-version).
Once again, we requested several tests and procedures (several times in fact) and have yet to see those results or hear anything about them. They are needed. Here's a link to the thread where they were first requested. PLEASE do them and include the files and the results and anything else helpful in your next reply. I appreciate you trying different things as you have (and probably would do so myself), but please ALSO do what we've requested. We can't do these things. We need you and if you want to get our best help, you need to help us by trying to follow our suggestions. http://www.vistax64.com/general-dis...p-cddvdw-ts-l632h-ata-device.html#post1296187.
I hope this helps and look forward to the information and files and results requested in the referenced link.
Good luck!
    1920 x 1200 pixels
