asullivan
If the file really is JPEF, the problem is that it is not JPEG - probably just a typo somewhere along the way. Fix that and assuming it isn't too big, it should work fine. If not, convert the image to a filetype that is acceptable. It doesn't show a list (it may if you pick one that isn't acceptable - I'm not sure), but I'm sure the standard ones like JPG, GIF, BMP, etc... are fine.
To delete e-mail notifications, go to User CP, click Edit Options, and choose to prevent emails from administrators, prevent emails upon receipt of private messages, and/or receive no email notification for subscribed threads. It may take a few moments to kick in so give it some time - but eventually the changes you make will become effective.
I hope this helps.
Good luck!
Ahhhh Haaa!! Tha' old JPEF shuffle sabotage tricky thingy!!!!! I new Trigger was behind this most hideous crime!!!!!
Hid'in behide a mask..!!! Looks lke a common criminal he does!!!!!!:eek:
da' problem is, he's half machine, half Equus caballus and a' always stand'in in da' sleep mode!!!! Drats, that fly'in four legged, hay eat'in, cheat'in Trigger...
Dont's worry's Lorien, I'll get him...I will's.....
- H.P. Pavilion/ dv6985se notebook/ P/N FE11UA#ABA
- Intel 2 Duo T5750
- Quanta ver. 79.2E
- 4 GB/2 slots DMM
- Mobile / Intel 965 express chipset Family
- Realtek High Def. Audio
- laptop
- 15.4" vis
- Toshiba MK2552GSX (250.06 GB)
- PSU
- Internal factory w/ outboard Transformer
- Case
- Factory burgandy
- Cooling
- 1 input, 1 output
- F.O. single rotary
- Standard small w/o # pads
- Normal fiber.
- Other Info
- Keyboard standard 101/102 Main circuit Quanta 30CC 79.2E Bios H.P. F.59 Router, Netgear WGR614v8 Cannon MP250 wired printer Modem Motorola SM 56 Realtek High Def. Audio
