The answer is: - from 32-bit and 64-bit Windows: frequently asked questions
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, Installing and reinstalling Windows 7
Awesome, thanks mate
Will be upgrading my system shortly.
- Custom built.
- AMD FX-4170 Quad-Core @ 4.2GHz
- ASUS M5A78L-M/USB3
- 8GB DDR3 @ 1333MHz
- Nvidia geforce GTS240 1GB, 3GB shared memory. SLI soon.
- realtek high definition audio, onboard.
- 19 inch widescreen monitor, DVI.
- 1440 by 900, 32 bit colour, 75 hertz.
- 1 128GB Kingston SSD Now OS drive 1 250GB sata main drive. 1 160GB from old install. 1 500GB for re-directs from OS disk. 1 Seagate GoFlex External 1TB with backups.
- PSU
- 750 watt.
- Case
- Foxconn TSAA699.
- Cooling
- 4 fans.
- Trust Wireless Optical Deskset Mouse.
- Trust Wireless Optical Deskset Keyboard.
- download about 60/65MB/s, upload about 3/4MB/s. Virgin Media
- Other Info
- ASUS EEEPad Transformer 16GB with Dock w/32GB class10 SD | Dell PE1950 II / 2xDual Core Xeons @3.00GHz / 16GB RAM / PERC 5i/R / 2x36GB SAS OS - 2x1TB SATA Data both RAID 1 |
