Solved The 32-bit RAM Issue
Creepinjesus, have u resolved this issue? If not, what make & model is your motherboard?
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
Hi folks,
This thread seems to be getting ridiculous. Here is my take on the 32-bit RAM question. A 32-bit version of Windows can address a maximum of 4GB of memory. This DOES NOT mean that it can address 4GB of RAM as some people think. Remember that the 4GB of address space also includes i/o address ranges for the hardware in your machine and that dependant on the hardware this reduces the actual amount of physical RAM that can be addressed to between 3GB and 3.5GB. To maximise the amount of memory available, you need to enter your BIOS and change a few settings. If you don't use the parallel or serial ports, then disable them to free up resources. Similarly, if you don't have a floppy drive installed, disable that as well (surprisingly, the BIOS in many systems still contains the floppy options even if the motherboard no longer has the interface socket). As regards the amount of memory on a graphics card, this, as far as I know, DOES NOT have an effect on this. Graphics cards are classed as an i/o device, and they typically have an interface width of 64 - 256 bits, although some are available with higher amounts. The memory on a graphics card is for its own private use, although in some systems an amount of RAM can be mapped in for graphics use upto a maximum of the amount of memory on the graphics card (check your BIOS).
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
lol....... cant believe this debate is still going!!
im sure your both right ...if nothing else this should be sticky'd
for ''32-bit address space''
well done though lads you have managed to keep it civil....
im sure you love each other really...:p
skunksmash,
If Fumz was right, this thread would have concluded a long time ago....
S-
Fumz,
Dont swear here please, I have warned you already about this.
My 2 cents:
32bit Vista can not address 4gb of ram without the boot code switch parameter and can not be used by yourself or programs reguardless...
64bit Vista can address 4gb of ram depending on your motherboard support.
Steven
I've got 4GB of RAM installed, but in 32-bit Vista (as is well known), only 3GB(ish) was available.
For reasons unknown to me, I decided to do a clean install to 64-bit (my computer supports both). So now I have a 64-bit system, but it still only let's me have 3GB of RAM. I feel robbed!
Does it have to be a 'dedicated' x64 system? Mine is a x86...
My only point to the OP, convoluted as it was, was that ultimately, a 3.xxGB Vista system is better than a 2GB Vista system.
@sidewinder, sorry for calling you a name.
@ dmex, sorry about using bad language. I'll take whatever punishment comes; however, it was not me you warned about swearing. This is not my second warning, I just happened to be in that thread. Just want to clear that up so you don't think I'm a repeat offender.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
When the physical RAM that is installed on a computer equals the address space that is supported by the chipset, the total system memory that is available to the operating system is always less than the physical RAM that is installed.
For example, consider a computer that has an Intel 975X chipset that supports 8GB of address space.
If you install 8GB of RAM, the system memory that is available to the operating system will be reduced by the PCI configuration requirements.
In this scenario, PCI configuration requirements reduce the memory that is available to the operating system by an amount that is between approximately 200 MB and approximately 1 GB. The reduction depends on the configuration.
great discussion
This shed some light - thanks!
The limit my system has is 4GB, so what you described here applies to me.
Thanks for the help, everyone! And enjoy your debate, Fumz and Sidewinder :p
    Intel Core 2 Duo @ 2GHz
    4GB DDR2 @ 667Mhz
    nVidia GeForce Go 7600
    1x 160GB 7200rpm 2.5" SATA
Its been resolved, Just dont swear again ;)
Yes, it does. Come on Dwarf, this is pretty basic stuff. Anyone that has 4GB of RAM in a system running a 32-bit OS and a video card with a lot of RAM or two video cards with a lot of RAM will have seen this firsthand. If you have 2GB of RAM, it won't be an issue.
Look here:
http://www.dansdata.com/askdan00015.htm
S-
    Intel E6600 @ 3.0 GHz
    EVGA nForce 680i SLI (NF68-A1)
    4GB - CORSAIR XMS2 PC2 6400
    EVGA GeForce 8800 GTS (640MB)
    2 - Seagate Barracuda 7200.10 (320GB) 1 - Seagate Barracuda 7200.10 (500GB)
:o Sorry, sidewinder. You are, of course, correct on this point. My brain was still half asleep (:sleepy:) earlier when I wrote that post (my excuse, and I'm sticking to it ;)), although I haven't any experience of this issue since my machine has only 2GB of RAM.
Dwarf
    Gigabyte IF233
dmex,
The boot.ini switch has nothing to do with what the 32-bit Vista can do in regards to addressing RAM.
The boot.ini switch alters how much of the 4GB virtual address space available to an application is set aside for the OS and how much is set aside for the application. Without the switch set, the OS is given 2GB and the application is given 2GB. With that switch set, the OS is given 1GB and the application is given 3GB. However, only applications specifically coded for this can take advantage of the change.
In other words, the boot.ini switch has nothing to do with what we are discussing here and just clouds the issue.
S-
My 2 cents:
dmex,
I just realized that you may be referring to the Physical Address Extension (PAE) switch and not the /3GB switch (bcdedit /set IncreaseUserVA 3072). You can turn PAE on in Vista with the following command:
BCDEDIT /SET PAE ForceEnable
This adds the switch to the BCD file (yes, I know boot.ini is not used by Vista).
But, turning PAE on in Vista (any 32-bit version) doesn't change anything in regards to the 4GB address space limit or how RAM is handled by applications. That's why, initially, it didn't occur to me that is what you were talking about.
S-
I must give props where props are due.
I had the hardest time wrapping my mind around the memory limitations of a 32-bit OS. This was due to a couple incorrect assumptions I had been holding onto with respect to MMIO mapping.
However, after tossing out those assumptions and going back over sidewinders very simple peg board explanation, I'm now laughing at myself at how I could not see it before.
Side, thanks for walking me through this and sorry for doubting you. Your detailed explanation has really helped me a lot.
now... can anyone tell me how I got this #$#$#$%@ dolly parton pic up? :D
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
dmex,
S-
Yeah :o I was talking about PAE, I haven't needed it in over 3 years and forgot the particulars :o
http://www.vistax64.com/chillout-room/170573-dolly-parton-fan-club-2.html
Just tried that - still on 3GB RAM :(. Maybe it is my motherboard after all.
CreepinJesus,
I just realized that, as far as I can see, you have not told us what motherboard you have. I looked in your public profile and it was not there either.
What motherboard do you have? Include manufacturer and model number please.
S-
I think it's an Intel 82801 GBM/GHM.
    4GB DDR2 @ 667Mhz
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Hi CreepinJesus,
Have you got a user manual for your PC? If so, have a look through to see if it mentions anything about memory, specifically the amount of memory that the board is capable of supporting. There should also be the information in there that we require viz the make and model of your motherboard. It could be that you need a BIOS upgrade, but this is not a job to be undertaken lightly and, unless there is a pressing reason to carry out such a task, I would err on the side of caution and leave your system as it is. Not recognising or being able to utilise the full amount of installed memory is not, in my opinion, classed as a pressing reason (especially if your system is otherwise working normally), although others may disagree. Either way, we need the information in order to assist you if this is, indeed, the case.
Dwarf
    Gigabyte IF233
Ok here we go:
    4GB DDR2 @ 667Mhz
