When the physical RAM that is installed on a computer equals the address space that is supported by the chipset, the total system memory that is available to the operating system is always less than the physical RAM that is installed.
For example, consider a computer that has an Intel 975X chipset that supports 8GB of address space.
If you install 8GB of RAM, the system memory that is available to the operating system will be reduced by the PCI configuration requirements.
In this scenario, PCI configuration requirements reduce the memory that is available to the operating system by an amount that is between approximately 200 MB and approximately 1 GB. The reduction depends on the configuration.
great discussion
great discussion
- ME.....
- Q9450 @ 3.6ghz
- P5K PREMIUM
- 8GB 1066mhz buffalo firestix
- HD 5970
- 20'' syncmaster
- 1680x1050
- 160GB 7200RPM SEAGATE BARRACUDA IDE 160GB 7200RPM SEAGATE BARRACUDA SATA 2
- PSU
- XCILIO 850w
- Case
- unknown ATX
- Cooling
- Arctic cooler pro 775
- logitech cordless optical
- logitech EX110
- 2mb
