System Restore Points - Stop XP Dual Boot Delete
How to Stop System Restore Points from being Deleted in Vista and Windows 7 when Dual Booting with XP
When you are dual booting XP with Vista and/or Windows 7, this will show you how to stop XP from deleting all of the System Restore Points and Shadow Copies in Vista and Windows 7 everytime you start XP.
You must be logged in as an administrator to be able to do the steps in this tutorial.
For more information, see also:
In Vista and Windows 7, shadow copies are used to maintain System Restore Points. Additionally, shadow copies are used to maintain Complete PC Backup files. Therefore, when you access the volume from an earlier operating system (XP), it will delete all restore points and all except the most recent versions of Complete PC Backup files in Vista and Windows 7.
This problem occurs because the volume snapshot driver that is included with Vista and Windows 7 uses disk structures that are incompatible with earlier versions of Windows. Therefore, the earlier operating system deletes Vista and Windows 7 shadow copies with the associated restore points. This behavior occurs because the earlier Windows operating systems do not recognize the new disk structures.
This does not actually fix the problem. It is a workaround that will stop XP from deleting the restore points and shadow copies. After you restart XP, you will not be able to access the volume Vista and/or Windows 7 is on from XP. However, you can still access the volume that XP is on from Vista and Windows 7.
It has been reported that some 3rd party disk defragmentation programs could also delete your restore points when used.
OPTION ONE
Using a REG File Download
This needs to be done in XP, not in Vista or Windows 7. This download assumes that Vista or Windows 7 is installed on the D: drive as the second OS. If this is not true for you, or you need to add another drive to be hidden from XP, then do OPTION TWO below to do this manually with the drive letter that your Vista or Windows 7 is installed on instead.
1. To Stop XP from Deleting Restore Points
Stop_XP.reg
download
B) Go to step 3.​
2. To Restore Default Settings in XP
Restore_Default_Settings.reg
download
5. Approve the merge when prompted.​
6. Restart XP to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
Manually Through Registry Editor
1. Open the Start Menu, click on My Computer to open it, then make note of the drive letter for the Vista and/or Windows 7 installation that you wan to prevent XP from seeing to prevent their restore points from being deleted.​
2. Open the Start Menu, click on Run to open it,, then type regedit and press Enter.​
3. In regedit, navigate to the location below. (see screenshot below)​
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
4. To Stop XP from Deleting Restore Points
A) In the left pane, right click on MountedDevices and click on New and Key.​
NOTE: If you already have the Offline key under MountedDevices, then skip this step and go to step 4C. (see screenshot below step 4C )​
B) Type Offline and press Enter.​
C) In the right pane of Offline, right click on a empty area and click on New and DWORD Value. (see screenshot below)​
D) Type \DosDevices\D: and press Enter. (see screenshot below step 4F)​
NOTE: While in XP, if your Vista or Windows 7 is not showing as being on the D: drive in Computer, then substitute D: with the drive letter that it is shown to be on instead. For example, if it is shown to be on the E: drive, then type \DosDevices\E: instead. Repeat this step if you wish to hide another drive letter from XP.​
E) In the right pane, right click on \DosDevices\D: and click on Modify.​
F) Type 1, and click on OK. (see screenshot below)​
G) The registry should now look like this. (see screenshot below)​
H) Repeat steps 4C to 4G for any other drive letter that you want to prevent them from being seen by XP.​
I) Go to step 6.​
5. To Restore the Default XP Settings
A) In the right pane of Offline, right click on \DosDevices\D:, and click on Delete. (see screenshot below step 4H)​
B) Click on Yes to confirm the deletion.​
C) Repeat step 5 for any other listed drive letter that you would like XP to be able to see again.​
  • Stop_XP.reg
    Stop_XP.reg
  • Restore_Default_Settings.reg
Hello Brink.
I just used option 2 in this excellent tutorial to get XP to stop eating the Vista restore points; it worked like a charm.
Thanks Shawn!...:)
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
You're welcome Ted.
Hey there..
Firstly, i wanna thank you so so very much Brink for this particular tutorial.
I've been using Vista for a few months now and everytime i did/installed something bad, i tried to do a system restore but Vista prompt that i don't have any. So i thought i had it turned off and checked. It's turned on but restore points just keeps disappearing. I'm on XP and Vista Dual-boot. XP on C: and Vista on F: ( same drive ). Did some research on Google and was linked to this site.
I did exactly how you explained it and it worked ! I tried Option 2 btw.
Again, i wanna thank you so much.
Have a great day !
Danny
    Inten Pentium Dual Core E2180
    1 x 2GB Kingston 667. 1 x 1GB Kingston 667
    256MB GeForce 7300LE
    Realtek HD 6.1 Audio
    Dual Monitor - 1 x 22" LG W2242T | 1 x 15" Proview
    1680 X 1050
    1 x 250GB Samsung ( Internal ) 1 x 500GB Hitachi ( Internal ) 1 x 320GB Western Digital ( External )
    A4Tech G6 Wireless Mouse
    Logitech Media Wireless Keyboard
    DL : 12MB/s | UL : 1.2MB/s
You're welcome Danny. I'm happy to hear that you got it sorted out.
I've a question:
if I work on Windows Vista it says me that Vista is on C: and XP is on D: but if I work on XP it saus me that XP is on C: and Vista is on D:
Now which letter do I use in the regeditor?
Hello Angyecarm,
While doing this tutorial in XP, you would use the D: drive letter for Vista then. :)
Yep, once this is applied, it should allow Vista to start keeping all of it's restore points and shadow copies for you to use Previous Versions. :)
No, not yet. Vista will not have any restore points or Previous Versions yet since it is just now starting to store them. You or Vista will need to create restore points first before you can do that after applying this tutorial. :(
I'm happy to hear that you can create them now. :)
Just out of interest and sorry to get an old thread going again. As XP can delete Vista's restore points unless modifications are made, does anyone know if the same goes for Vista in relation to Windows 7?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
No, Vista will not delete Windows 7 restore points; but XP will delete Windows 7 points.
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
So it was just an exclusively XP issue. Thanks for the clarification.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
I'd been hiding the Win 7 partition from Vista too, so now have unhidden it.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Hello Nipo,
Windows 7 and Vista should not delete each others restore points. This was a XP issue when dual booting with it and Windows 7 and/or Vista instead.
If you still believe this to be the case, then you can try hiding one of the Windows 7 from the other one using this same tutorial. Just substitute XP for the default Windows 7 that startups automatically to at boot.
Well, I have three HDD. Each of one have installed Windows 7. However I started windows 7 from another disk, the restore point of the first disk were deleted.
