System Restore Points - Stop XP Dual Boot Delete
How to Stop System Restore Points from being Deleted in Vista and Windows 7 when Dual Booting with XP
When you are dual booting XP with Vista and/or Windows 7, this will show you how to stop XP from deleting all of the System Restore Points and Shadow Copies in Vista and Windows 7 everytime you start XP.
You must be logged in as an administrator to be able to do the steps in this tutorial.
For more information, see also:
In Vista and Windows 7, shadow copies are used to maintain System Restore Points. Additionally, shadow copies are used to maintain Complete PC Backup files. Therefore, when you access the volume from an earlier operating system (XP), it will delete all restore points and all except the most recent versions of Complete PC Backup files in Vista and Windows 7.
This problem occurs because the volume snapshot driver that is included with Vista and Windows 7 uses disk structures that are incompatible with earlier versions of Windows. Therefore, the earlier operating system deletes Vista and Windows 7 shadow copies with the associated restore points. This behavior occurs because the earlier Windows operating systems do not recognize the new disk structures.
This does not actually fix the problem. It is a workaround that will stop XP from deleting the restore points and shadow copies. After you restart XP, you will not be able to access the volume Vista and/or Windows 7 is on from XP. However, you can still access the volume that XP is on from Vista and Windows 7.
It has been reported that some 3rd party disk defragmentation programs could also delete your restore points when used.
OPTION ONE
Using a REG File Download
This needs to be done in XP, not in Vista or Windows 7. This download assumes that Vista or Windows 7 is installed on the D: drive as the second OS. If this is not true for you, or you need to add another drive to be hidden from XP, then do OPTION TWO below to do this manually with the drive letter that your Vista or Windows 7 is installed on instead.
1. To Stop XP from Deleting Restore Points
Stop_XP.reg
download
B) Go to step 3.​
2. To Restore Default Settings in XP
Restore_Default_Settings.reg
download
5. Approve the merge when prompted.​
6. Restart XP to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
Manually Through Registry Editor
1. Open the Start Menu, click on My Computer to open it, then make note of the drive letter for the Vista and/or Windows 7 installation that you wan to prevent XP from seeing to prevent their restore points from being deleted.​
2. Open the Start Menu, click on Run to open it,, then type regedit and press Enter.​
3. In regedit, navigate to the location below. (see screenshot below)​
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
4. To Stop XP from Deleting Restore Points
A) In the left pane, right click on MountedDevices and click on New and Key.​
NOTE: If you already have the Offline key under MountedDevices, then skip this step and go to step 4C. (see screenshot below step 4C )​
B) Type Offline and press Enter.​
C) In the right pane of Offline, right click on a empty area and click on New and DWORD Value. (see screenshot below)​
D) Type \DosDevices\D: and press Enter. (see screenshot below step 4F)​
NOTE: While in XP, if your Vista or Windows 7 is not showing as being on the D: drive in Computer, then substitute D: with the drive letter that it is shown to be on instead. For example, if it is shown to be on the E: drive, then type \DosDevices\E: instead. Repeat this step if you wish to hide another drive letter from XP.​
E) In the right pane, right click on \DosDevices\D: and click on Modify.​
F) Type 1, and click on OK. (see screenshot below)​
G) The registry should now look like this. (see screenshot below)​
H) Repeat steps 4C to 4G for any other drive letter that you want to prevent them from being seen by XP.​
I) Go to step 6.​
5. To Restore the Default XP Settings
A) In the right pane of Offline, right click on \DosDevices\D:, and click on Delete. (see screenshot below step 4H)​
B) Click on Yes to confirm the deletion.​
C) Repeat step 5 for any other listed drive letter that you would like XP to be able to see again.​
  • Stop_XP.reg
    Stop_XP.reg
  • Restore_Default_Settings.reg
If I get this right: I can re-enable the access to the drives with Disk Management and not lose the restore point; question, it there a way to run a program (.reg) on shutdown to automatically change the registry setting?
That's something that will need to be tested to make sure that you don't lose your restore points first. I don't think you will as long as you offline the drive before shutdown, but I could be wrong.
If it works, then you could export the offline key in the registry to a .reg file to make it easy to set back.
Previously on my desktop I removed the drive letter for †he Vista partition and mounted it into a folder on a separate drive. I never noticed if XP was deleting restore points because I got to where I hardly used it. Reading this I was wondering if that prevented XP from deleting the restore points.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I guess this thread is good until support for XP dies in April. I will have to point out that I just set up a Quad boot with XP, Win7, Win8, and Linux Mint although not for myself and noticed that after applying this registry tweek, it did in fact work, but noticed afterward that XP took an excruciatingly long time to restart, following that and while in Windows 8 it took an excruciatingly long time to shut down, Windows 7 hung for many minutes and finally booted and then took extra long to restart. I am at a loss as to why. After this the only issue that seams to persist is a excruciatingly slow Windows 7 boot from the boot manager.
    Phenom 4 core
    Gigabyte
    4GB Hyperblue
    on board
    HD 5.1
    Samsung 713n
Hello Richman, and welcome to Seven Forums.
With Linux in the mix with the boot manager, there's no telling how it will affect it. :(
If you like as a test, undo the tutorial to see how it behaves afterwards.
Hello. I followed the steps using the correct drive letter, restarted back into XP, and the partition with windows 7 on it (C: ) is still accessible. I can click on my computer>C:>_____ and browse throughout the entire drive.
Any idea why it didn't work?
Hello 00000, and welcome to Vista Forums.
To no longer see the Windows 7 drive while in XP, the steps will need to be done in XP instead of Windows 7.
Hope this helps, :)
I did do it from within windows XP. I've done it before and last time it worked. I would still see the drive in "my computer" but when I clicked on it, it was just blank, no files or folders.
This time (recently did a clean install) I did the steps exactly the same from within XP restarted back into XP and the files/folders were still accessible.
In that case, while in XP, see if removing the drive letter for the Windows 7 drive in Disk Management will do the trick instead. :)
It may be of interest to some users that this method also works when duel booting between win. 10 & win 7, because win 7 has the same exact registry entries as XP
Brogan
Thank you for confirming Brogan, and welcome to Vista Forums. :)
