sp1 install problem
oki've tried all of what you suggested and it still doing the same.
do you think there is a conflict somewhere?
    Self Build
    AMD x64 6000+
    ASUS M2A-VM
    6GB DDR2 PC2 800MHZ
    Radeon HD4870
    On Board 5.1 Sound
    22" Syncmaster T220
    700w
It does sound like something related to the graphics. Still, what you may want to try is to run sfc /scannow from a command prompt as described elsewhere on this forum (search for this command). I too was unable to install SP1. After half a year, I set down and took the time necessary to fix it. What in the end made it, was to disable all functions of McAfee from within McAfee Security Center (turn on Vista Firewall first and make sure it does not warn for errors). My problems were not the same as yours, as my installation went all the way through but then reverted the installation. A couple of days after upgrading to SP1, I got problems with my graphics. This was resolved by re-installing the latest drivers. Though your installation problem appear different, it may be related to McAfee and Vista Firewall too.
Disregard this - I missed you had finally got SP1 in...
    Dell XPS720
    Intel Quad Q6600 2.40GHz
    4GB DDR2 800MHz
    Creative SB X-Fi Xtreme Gamer
    Dell 2407WFP-HC
    1920x1200
To be honest I really dont know what to think. I have searched through the internet for compatible drivers, even been to microsoft and they have sent me back to the drivers that you are now using, they should work. :(
I have searched through forums from ATI and found nothing.
Have you tried the drivers from the ASUS site?
ASUSTeK Computer Inc.-Support-
You have to give in your board details, It might be worth a last attempt
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
Hi pooch
I will try that through asus and see what happens, just done a memory test and it says there is hardware problems could be a fault with the motherboard.
I'll let you know what comes of it thanks for taking the time to try and help
Throbinson
    Self Build
    AMD x64 6000+
    ASUS M2A-VM
    6GB DDR2 PC2 800MHZ
    Radeon HD4870
    On Board 5.1 Sound
    22" Syncmaster T220
    700w
Ok, I presumed that as it was working before sp1 that it would still work after. I look forwards to seeing what comes out of this. :D
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Hi
I've tried it through windows update and from the standalone update from my hard drive when it was downloaded. Would doing of a disc make a difference?
I run a 32 bit, home basic. But this should work. Start-msconfig-enter-continue-
click services-check hide all microsoft services, click disable all- click ok. Restart your cp. Then install sp 1. To restore your cp to use a normal startup, repete steps 1, click normal startup, on the general tab, click ok. then restart your cp. It downloaded sp1 i a lot faster this way. Newbie. Good luck
