Reputation Points
z3r010
Staff member
Over the last few days it has become clear that some members are misusing the reputation system, this misuse makes the ranking system totally worthless.
From now on any member that I find begging for rep or randomly giving rep for useless posts will have 50 points deducted for the first offence, second offence will lead to that member having their reputation and rank disabled.
If this fails to work I will disable the rep and ranking system for all users and revert to manually promoting users that deserve it.
Edit
Rep given is now capped at a maximum of 50 points.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Read & Understood.
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Razer Copperhead Tempest Blue
    Logitech G15 V1
    100.0 Mbps
Fleeeee............
    ASUS P5B-E Plus
    ASUS EN8800GT 512
    1440x900 @ 75Hz
    Logitech G15 V1
    100.0 Mbps
Understood. I give rep, if I feel the poster deserves it.
I've seen abuses of rep systems at other forums, and I've seen most forums, won't even use reputation systems anymore.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    Viewsonic VG2030wm Widescreen LCD
    1680X1050
    120GB 200GB 320GB
    ThermalTake Toughpower 700
    Antec P182
    four 120mm fans
    Microsoft Wireless Intellimous Explorer 2.0
    Microsoft Natural Multimedia Keyboard
    10MB
    16X LG DVDROM & LG Dual Layer DVD Burner Logitech X-540 speakers
yes your right z3r010....this system can be open to rape!!
but ppl who do so should be aware they cant hide from it
its all logged :)
...............................:mad:!!DONT DO IT!! :mad:
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
I have just seen this; understood!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
And here I just handed out some rep before seeing this....hope I'm not part of the problem :(
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    Samsung T190 1440X900
    1440X900
    2X Seagate 120 (OS's) IDE 1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
If the posts were helpful or informative then you are not part of the problem, if you gave rep to crappy useless posts or traded it then you are ;)
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
If you are not part of the solution, you are part of the problem:)
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Guess I'm a problem child then :)
EDIT: I was looking for a post I know I made earlier, but looking for "posts made by" only returns 200 hits. Is this a forum restriction or have I really made 94 posts that have been hidden?
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    1440X900
    Corsair HX520
    Coolmax el cheapo
:geek:
I was wondering how a senile old fart like me got points. I thought yall young fellows was taking pitty on me. Best never to take any advice on faith. Reputation at least gives a ballpark idea of who
gives good advice.
I have repped a few that deserved it, but apparently my rep power is large.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
The forum is set to only show your last 200 ;)
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
OK thanks :D
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    1440X900
    Corsair HX520
    Coolmax el cheapo
There's something I would like to see eliminated. That is when you give somebody bad rep, allowing them to turn around and give you the same. I had this happen to me recently, as the person I gave bad rep to, felt that person deserved it.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    1680X1050
    120GB 200GB 320GB
    Antec P182
    four 120mm fans
    10MB
Wild Eagle You know if we all added up our points that and 10 dollars would get one of us in to the movies. Basicly all they do is give someone an idea on who gives good advice. But a expert at Networking may not know squat about software.
Maybe the rep (good or bad) could be made anonymously, that way no one feels like recipricating the actions (good or bad). Only show you which thread/post the rep was given and no other mention of who gave the rep out.
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    1440X900
    Corsair HX520
    Coolmax el cheapo
no, then all the little haters and n00bs who get mad when we ask for details and the troublemakers will be neg repping everyone they can.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I give rep for a good article someone posts or to a post someone makes that helps me.
Off topic: Is there anywhere that shows the ranks and how much rep is needed to acheive them?
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
