QoS Bandwidth Reserve Limit
How to Change or Disable the QoS Reserved Bandwidth Limit in Vista
By default, Vista can reserve up to 20 percent of the network bandwidth for QoS traffic handled by the QoS Packet Scheduler. One hundred percent of the network bandwidth is available to be shared by all programs unless a program (Ex: Windows Update) specifically requests priority bandwidth. This 20 percent reserved bandwidth is still available to other programs unless the requesting program (Ex: VoIP applications) is sending data. Vista can then restrict the best effort traffic to a minimum of 80 percent of the bandwidth to the other programs so that the high priority traffic can be accommodated. If the program that reserved the bandwidth is not sending sufficient data to use it, the unused part of the reserved bandwidth is available for other data flows on the same host.
This will show you how to change the percentage of reserved bandwidth to what you want it to be instead, or disable the reserved bandwidth.
Quality of Service (QoS) is a set of technologies for managing network traffic in a cost effective manner to enhance user experiences for home and enterprise environments. QoS technologies allow you to measure bandwidth, detect changing network conditions (such as congestion or availability of bandwidth), and prioritize or throttle traffic. For example, QoS technologies can be applied to prioritize traffic for latency-sensitive applications (such as voice or video) and to control the impact of latency-insensitive traffic (such as bulk data transfers).
For more about QOS, see:
This only applies if you have the Qos Packet Scheduler checked in your Local Area Connection Network properties. (See Example below). It is enabled by default in Vista.
Disabling or lowering the reserved percentage to much can cause problems with applications that rely on it. For example, with streaming media or VoIP applications.
EXAMPLE: Local Area Connection Network Properties (LACN)
NOTE:
To see this, open the Control Panel (Classic View) and click on the Networking and Sharing Center icon, Manage network connections in the upper left corner, right click on the LACN, and click Properties. Click Continue for UAC Prompt.
METHOD ONE
Through the Group Policy Object Editor
NOTE: This method is only available for the Vista Business, Ultimate, and Enterprise editions. See Method Two or Method Three below for the Vista Home Basic and Home Premium editions.
2. In the left pane, click on Computer Configuration, Administrative Templates, and Network, QoS Packet Scheduler.​
(See screenshot below)​
3. In the right pane, right click on Limit reservable bandwidth and click on Properties. (See screenshot above)​
4. For Default Reserved Bandwidth
A) Dot Disabled or Not Configured and click on OK. (See screenshot below step 5B)​
NOTE: If you disable this setting or do not configure it, the system uses the default value of 20 percent of the connection.
5. To Change the Reserved Bandwidth
A) Dot Enabled.​
B) Next to Bandwidth Limit (%), type in a percentage to use from 0 to 100 and click on OK.​
NOTE: If you change the percentage to 0, then this will disable the reserved bandwidth.
6. Close the Group Policy Object Editor window.​
7. Restart the computer to apply changes.​
METHOD TWO
Using a REG File Download
NOTE: This method will work for all Vista versions. To change the precentage to something other than 0 or 20, then see the METHOD THREE section below.
1. To Disable the Reserved Bandwidth
NOTE: This changes the reserved percentage to 0 and disables the reserved bandwidth.
Disable_Reserved.reg
download
B) Go to step 3.​
2. To Restore the Default Reserved Bandwidth
NOTE: The default reserved bandwidth is 20 percent.
Restore_Default_Reserved.reg
download
4. Right on click on the downloaded .reg file and click on Merge.​
6. Restart the computer to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
METHOD THREE
Manually in Registry Editor
1. Open the Start Menu.​
3. If prompted by UAC, click on the Continue button.​
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows
5. In the left pane, right click on Windows and click on New and Key.​
6. Type Psched and press Enter. (See screenshot below)​
7. In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value.​
8. Type NonBestEffortLimit and press Enter. (See screenshot below)​
9. Right click on NonBestEffortLimit and click on Modify.​
10. Type in a percentage to use from 0 to 100 to be used as the reserved bandwidth and click on OK.​
NOTE: If you change the percentage to 0, then this will disable the reserved bandwidth. The default percentage is 20.
11. Close regedit.​
12. Restart the computer to apply the changes.​
Well,it was a nice try,but it had no effect whatsoever on my download speed :rolleyes:
not that i'm complaning about my current DL speed :)
Thanks annyways
greetz,
FAT69
    Intel Q9550
    asus p5kc
    ocz DDR3 1333mhz
    ATI HD2900 XT 1 gig ram
    Realtek onboard
    Samsung Syncmaster 226 cw
    Samsung spinpoint 1Tera
    OCZ gamer 850watt
    CS-A+380 Twin Engine
    Blue Orb
    razer copperhead blue led
    Microsoft
    20mbits theoratical ; ) real speed about 8mbit
You're welcome FAT69. It usually will not have an effect unless say Windows Update starts to download while you are already downloading something else.
Hello Jack, and welcome to Vista Forums.
I'm afraid that this is not going to have any affect on the quality of Skype. :(
You might consider posting a new thread about the details of the quality issue you are having with Skype in the forum area to see if someone may be able to help though.
When I checked the value to which it was set, Psched was not in the registry. I added it to set it to 0 so that I could disable it.
Is it already disabled without the Psched entry or does that mean it's using 20% already?
Wouldn't just unchecking QoS Packet Scheduler in the LAN Connection Properties do the same thing?
    Windows Vista Home Premium SP2, 32-bit
    Retrofitted Refurbished Gateway
    AMD
    ASUS M3A78-EM
    Acer 22-in Flat Screen Monitor
    Logitech M705 Wireless Mouse
    Logitech K350 Wireless Keyboard
Hello Andy,
It doesn't have the DWORD value in the registry by default since this is would be an added group policy to change the percentage from it's 20% default.
If you don't want to use QoS, then yes you could just uncheck QoS Packet Scheduler. This is for those that still want to use QoS, but would prefer a different percentage than the default 20%. :)
I'm going through the tutorial to speed up performance, as you might be able to tell from all my recent posts. If I understand this correctly, with QoS enabled, Windows only uses that 20% mainly for downloading updates. Does that mean it only has any effect when actually downloading those updates?
    AMD
    ASUS M3A78-EM
