QoS Bandwidth Reserve Limit
How to Change or Disable the QoS Reserved Bandwidth Limit in Vista
By default, Vista can reserve up to 20 percent of the network bandwidth for QoS traffic handled by the QoS Packet Scheduler. One hundred percent of the network bandwidth is available to be shared by all programs unless a program (Ex: Windows Update) specifically requests priority bandwidth. This 20 percent reserved bandwidth is still available to other programs unless the requesting program (Ex: VoIP applications) is sending data. Vista can then restrict the best effort traffic to a minimum of 80 percent of the bandwidth to the other programs so that the high priority traffic can be accommodated. If the program that reserved the bandwidth is not sending sufficient data to use it, the unused part of the reserved bandwidth is available for other data flows on the same host.
This will show you how to change the percentage of reserved bandwidth to what you want it to be instead, or disable the reserved bandwidth.
Quality of Service (QoS) is a set of technologies for managing network traffic in a cost effective manner to enhance user experiences for home and enterprise environments. QoS technologies allow you to measure bandwidth, detect changing network conditions (such as congestion or availability of bandwidth), and prioritize or throttle traffic. For example, QoS technologies can be applied to prioritize traffic for latency-sensitive applications (such as voice or video) and to control the impact of latency-insensitive traffic (such as bulk data transfers).
For more about QOS, see:
This only applies if you have the Qos Packet Scheduler checked in your Local Area Connection Network properties. (See Example below). It is enabled by default in Vista.
Disabling or lowering the reserved percentage to much can cause problems with applications that rely on it. For example, with streaming media or VoIP applications.
EXAMPLE: Local Area Connection Network Properties (LACN)
NOTE:
To see this, open the Control Panel (Classic View) and click on the Networking and Sharing Center icon, Manage network connections in the upper left corner, right click on the LACN, and click Properties. Click Continue for UAC Prompt.
METHOD ONE
Through the Group Policy Object Editor
NOTE: This method is only available for the Vista Business, Ultimate, and Enterprise editions. See Method Two or Method Three below for the Vista Home Basic and Home Premium editions.
2. In the left pane, click on Computer Configuration, Administrative Templates, and Network, QoS Packet Scheduler.​
(See screenshot below)​
3. In the right pane, right click on Limit reservable bandwidth and click on Properties. (See screenshot above)​
4. For Default Reserved Bandwidth
A) Dot Disabled or Not Configured and click on OK. (See screenshot below step 5B)​
NOTE: If you disable this setting or do not configure it, the system uses the default value of 20 percent of the connection.
5. To Change the Reserved Bandwidth
A) Dot Enabled.​
B) Next to Bandwidth Limit (%), type in a percentage to use from 0 to 100 and click on OK.​
NOTE: If you change the percentage to 0, then this will disable the reserved bandwidth.
6. Close the Group Policy Object Editor window.​
7. Restart the computer to apply changes.​
METHOD TWO
Using a REG File Download
NOTE: This method will work for all Vista versions. To change the precentage to something other than 0 or 20, then see the METHOD THREE section below.
1. To Disable the Reserved Bandwidth
NOTE: This changes the reserved percentage to 0 and disables the reserved bandwidth.
Disable_Reserved.reg
download
B) Go to step 3.​
2. To Restore the Default Reserved Bandwidth
NOTE: The default reserved bandwidth is 20 percent.
Restore_Default_Reserved.reg
download
4. Right on click on the downloaded .reg file and click on Merge.​
6. Restart the computer to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
METHOD THREE
Manually in Registry Editor
1. Open the Start Menu.​
3. If prompted by UAC, click on the Continue button.​
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows
5. In the left pane, right click on Windows and click on New and Key.​
6. Type Psched and press Enter. (See screenshot below)​
7. In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value.​
8. Type NonBestEffortLimit and press Enter. (See screenshot below)​
9. Right click on NonBestEffortLimit and click on Modify.​
10. Type in a percentage to use from 0 to 100 to be used as the reserved bandwidth and click on OK.​
NOTE: If you change the percentage to 0, then this will disable the reserved bandwidth. The default percentage is 20.
11. Close regedit.​
12. Restart the computer to apply the changes.​
Your welcome Tony.
thanks really appreciated this find i was doing it manually all along and wasnt sure if it had worked or not while i was reading this i was thinkin why havent anybody just made a reg
Your welcome Lyncy, and welcome to Vista Forums. I always liked it to when there was a reg file or something to do it automatically instead.
Hello Lordbdp,
Usually is is best to use the default settings unless you are encountering problems with it. If you are, then I would just disable QoS.
Have disable QoS affect to Skype?
If I turn it of, is there a chance to copy faster via my home LAN network? Because in Windows XP si copying in my network faster.
Thanks.
    Intel Core 2 Quad 9400
Hello Mark,
Sorry, but this would not affect this. :)
Yes, that may be better for you instead. Try the different settings to see which one you seem to get better performance from.
Enabled to 0, I've never seen my internet so fast! :)
    i7 965
    Asus Rampage II Extreme
    Corsair TR3X6G1333C9 x 2
    Gigabyte GTX295 SLI
    SB X-Fi MB
    Samsung Syncmaster T240
    1900x1200
    2x1TB Western Digital Black (Raid 0), 150GB WD Raptor
    1200W Thermaltake Toughpower
    Lian Li PC80P
    Chassis - 3 Front 140mm, Top 140mm, Rear 140mm
    Logitech MX Revolution
    Fold up beast by me :-)
Gnys, I'm happy to hear that your internet is running faster now. Thank you for sharing your results. :)
im new at this forum, and i'm reading all the tutorials!!!
this helped me a lot with my download speed!! from 223kbps i downloaded, now i can do it at almost 290!!! thanks!! :D
    C2D e6420 @2600mhz
    P35-DS3L
    OCZ REAPER 2x2gb ddr2 800mhz
    8800gt ADE + TT DuOrb
    on board
    2x samsung 226nw
    3360*1050
    wd320 wd500 wd750
    Coolermaster Real Power Pro 650w
    Coolermaster CM 690
    Thertmaltake Big Typhoon VX
    Logitech MX 518
    Microsoft Natural Ergonomics 4000
    3mb
You're welcome Marquillos, and welcome to Vista Forums. :)
Hi Shawn, Its a nice tutorial though and i have also followed this tutorial as my internet speed sucks. But still wanted to ask whether it will reduce the download speed for windows update?
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Hi Dinesh,
Instead of Windows Updates getting priority for the reserved bandwith by default, it will instead share all bandwith with everything equally when QOS is disabled. Because of this, Windows Update has the potential to have a lower download rate, but you will most likely not even notice it.
Anyways, who cares about the bandwidth for windows update. We are more concerned towards downloading our own stuffs. Thanks Shawn.
    Compaq
    15"
    160 GB WDC
You're welcome Dinesh. :)
Hi there shawn
i have no problem with my bandwidth,i have a pretty stable dsl line at about 800kb/s, but i got curious when i read this thread,and asked myself if this would infact have some positive result on my download speed :huh:
So i had to choose the manual way,because of my vista home premium limitations
and so i did the regedit,to the letter....but here's the strange thing
i kept the DWORD value at 0,because i wanted to see if it would infact have a positive affect on download speed,but the strange thing is it won't stick on decimal it keeps turning to hexadecimal,do you have anny idea why this happens,and what effect it could have on my system if i leave it like this, or should i delete the key and forget about it?
    Intel Q9550
    asus p5kc
    ocz DDR3 1333mhz
    ATI HD2900 XT 1 gig ram
    Realtek onboard
    Samsung Syncmaster 226 cw
    Samsung spinpoint 1Tera
    OCZ gamer 850watt
    CS-A+380 Twin Engine
    Blue Orb
    razer copperhead blue led
    Microsoft
    20mbits theoratical ; ) real speed about 8mbit
Hell FAT69, and welcome to Vista Forums.
It's just appearing to do this since 0 would be the same in decimal and hexadecimal, so no worries. :)
offcourse,that was pretty stupid of me that i didn't think of that :confused:
thanks for the fast reply doh ;)
greets,
FAT69
    Intel Q9550
    asus p5kc
    ocz DDR3 1333mhz
    Realtek onboard
    OCZ gamer 850watt
    Blue Orb
    Microsoft
