Program to tell temperature of components?
Tomorrow.
    eMachines ET 1161-05
    AMD Athlon 64 X2 6000+ 3.0 GHz AM2 Dual Core
    3gb
    Galaxy GeForce GT 430 - 1gb DDR3 - 128bit Memory Interface
    Realtek HD Audio
    Samsung 23" LED, 1920 x 1080 resolution
    1920x1080
    160gb Seagate
    Cool Master Extreme Power Plus - 500watts
    APEVIA X-Trooper Case w/ Side Window-Blue
    4, 120mm fans. 1, 200mm fan. Sunbeamtech Rheobus-Extreme
    Logitech k800 Wireless Illuminated Keyboard
    150mbps
    Linksys WUSB100 Insignia 2:1 Sound system.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
Right nice looking.
A little tip. Uncase you 4/8 pin cpu power and run it under the front of your gpu, up to the plug.
You can see how I routed it under n thatr pic. It may even fit with the caseing.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Ah. Yes. I just went in there and did what you did.
I also spent some more time in there and moved every cable that comes out of the PSU, to behind the motherboard tray. So there is no cables in that whole corner - and no sleeving.
I also moved other cables and routed them behind the motherboard tray and to their ports.
I added a ****ty cellphone picture.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
How is that fan controller working out for you? I'm kind of interested in that.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Generally, the cooler the better. Without going through extreme measures it's unlikely you'll ever be able to get your CPU to be too cold. From my experience when I was monitoring my temps, 35 degrees C is a pretty low temp. For most processors, 95 ish degrees C is supposed to be the upper limit of functionality before you start getting problems. If you keep it below 85 C you should be fine, and I'd be really surprised if you ever have any issues running below 75 C. Of course, some processors might be different, but I'd guess those numbers are good for 99% or processors that aren't specifically built for higher temperature operation.
Those are for Intel CPU's.. Most amd processors, Especially the New Phenom II's melt at anything over 62C
    Amd Phenom II x4 965 BE rev.C2
    MSI ms-7599
    A-DATA DDR3-1600G PC3-12800 4GBx2
    Biostar NVIDIA GeForce 9400GT mn: VN9402THG1
    Creative SoundBlaster Audigy 2 Zs
    Compaq FS7550 (D-SUB)
    1600*1200
    Western Digital WD10 EADS-00L5B1 SATA (1TB) (Main drive) Hitachi HDS721010CLA332 SATA (1TB) (Secondary drive) Samsung HM250HI SATA (250GB) (Music and swap) Western Digital WD800BB-75CAA0 IDE 133 (80GB) (misc)
    RAIDMAX RX-850AE 850 Watt 12x4 rail 80plus gold PSU
    Cooler Master RC-430-KWN1 (elite 430)
    Corsair Hydro Series H50 (*120mm (x1))
    I Home Lazer
    Standard Microsoft (500)
    around 4 Mb a sec
    CD-rom's TSSTcorp CDDVDW SH-S223L SATA (Samsung) HL-DT-ST DVDRAM GH22NS40 SATA (LG)
Have you checked to see if your heat sink is seated properly on the processor? What about the thermal material? did you put enough/too much? Check in your bios to see if it has any fan speed management turned on. It could also be that it is not speeding the fan/s up until the temperature gets into the 50's
    MSI ms-7599
    1600*1200
    I Home Lazer
    around 4 Mb a sec
Works flawless. The brightness of the lights in the knobs adjusts to how fast the fan is spinning. The lights turn off when the knob is off.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
The heat sink is definitely seated right. And I used a rice size to a pea size amount of Tuniq TX 2.
I've reseated it, cleaned it, and added new TIM 3 times now, no change.
Hmmmm. Bios........ I don't see why the fan wouldn't adjust, It's a 4 pin fan header and a 4 pin fan.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
I thought you said you were using a 3-pin fan on a 4-pin header.. Humm must have lost track somewhere.
None the less. A rice size drop 0.o I know you are only supposed to use a small amount but rice size? I used about the size of a thumb tack head. And I have no issues and nothing *Bleeds out* on the sides of the cpu. Putting too little won't provide sufficient enough thermal conductivity. Enlighten me as I am still learning things :D
    MSI ms-7599
    1600*1200
    I Home Lazer
    around 4 Mb a sec
Here's a picture I just took of the cable management I did yesterday. This is pretty much the best I can get it with the set up I have. I've seen others where there isn't one cable showing except the 20+4pin mobo connection. I don't know how they do that
There is absolutely no where for the wire going from the rear fan to hide, it won't fit behind the motherboard tray so It just has to hang across the case. -__-
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
They usually use the space behind the main board bracket, providing the power supply has long enough wires. and alot of times I have seen people make custom sleeving to match the color of the case to hide wires to :P
all in all looks better than mine right now :D at least you can see in your LMFAO
    MSI ms-7599
    1600*1200
    I Home Lazer
    around 4 Mb a sec
Doing the full on sleeving looks like a pain in the ass, between removing the ends, shrink tubing it, and then sleeving it. I just don't like the removing the connections part.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
Haha Yeah I feel ya man.. it is a pain. I recently tried to do the same with mine.. Sadly I failed horrifically.
    MSI ms-7599
    1600*1200
    I Home Lazer
    around 4 Mb a sec
I use rice all the time, and once i remove the hsf, i find complete coverage.
Actually, using as little as possible is best. Youre trying to fill in micro-scratches in the cpu and hsf. The paste provides an intermediate for heat, and is not as good as the metal f the cpu or hsf.
Its not the paste, but the metal additives in the goo, so to much goo slows heat.
then maybe I should lap mine because Rice size just don't cut it for me :P:eek:
    MSI ms-7599
    1600*1200
    I Home Lazer
    around 4 Mb a sec
Haha, subtract a half a grain of rice size from the pea size and that's what I put.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
SO a dot
lol sorry half out of it at the moment.
    MSI ms-7599
    1600*1200
    I Home Lazer
    around 4 Mb a sec
