Program to tell temperature of components?
I wish Speccy would show the CPU temp so I can get rid of the Core Temp one.
    eMachines ET 1161-05
    AMD Athlon 64 X2 6000+ 3.0 GHz AM2 Dual Core
    3gb
    Galaxy GeForce GT 430 - 1gb DDR3 - 128bit Memory Interface
    Realtek HD Audio
    Samsung 23" LED, 1920 x 1080 resolution
    1920x1080
    160gb Seagate
    Cool Master Extreme Power Plus - 500watts
    APEVIA X-Trooper Case w/ Side Window-Blue
    4, 120mm fans. 1, 200mm fan. Sunbeamtech Rheobus-Extreme
    Logitech k800 Wireless Illuminated Keyboard
    150mbps
    Linksys WUSB100 Insignia 2:1 Sound system.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
Do you have a bowl of Ice setting next to the intakes for the Fan to be pulling in ? LOL that is kinda cool.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
The thing is, I have no fans pulling air in! Just exhausts! And whatever the PSU is taking in!
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
Don't know why Speccy didn't show all your temps.
Mine shows 46c but I have an Intel and that could be why.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
What was I thinking. It's speed fan that I use. What does that say? I still don't believe 21 because even when idle the cpu is still creating heat.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Just wanted to throw in that I've heard some CPU's don't have a temp gauge that your system can access. Now, I imaging ALL CPU's will have some sort of temperature control mechanism that shuts it off if it gets too hot, but these mechanisms can be connected solely to the CPU and not provide any info to your system. I got the impression that this case is pretty rare (and more likely to be a problem with older systems) but that might explain why you aren't getting any temp feedback.
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Touchpad, + Logitech wireless mouse (USB)
    Built in
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
If your core hasnt changed, then your thermal temps broke.
My T5800 isa like that too.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Ok. We'll see what happens with the new CPU when it arrives and I install it. I hope it works.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
Hopefully. At the price you paid, even if it doesnt you learnt something
Ok guys. I have it installed with the new cooler. Pics attached.
WEI went from 4.4 to 5.4. Lowest was the CPU.
How are the temps? EDIT: When watching HD video Core 0 went up to 49 and Core 1 went up to 51. Celsuis
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
Thats not too bad. youre at 46C @ 48% load.
Try a burn in with Intel burn test
IDK why it was at 48%, must have been a random spike.
Why would I want to this burn test? Sounds like it over heats things...........
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
It shouldnt overheat things, but it will stress ut the cpu, and allow the TIM properly seat in.
Plus its best to see how hot it'll get, when youre around to stop it.
Just run it 5 minutes and you'll se if things are good.
I found a link. It says my CPU's max temp is 63 degrees C. It's at idle right now at ( Core 0 ) - 42c. ( Core 1 ) - 47c.
There's really no where on this case to put a fan blowing air IN, I just have a 3.75" exhaust fan on the back blowing out. No place on top, nothing on the side, I mean I could put a fan on the side where the door is removed, but that's kind of silly.
Hope it doesn't get too hot!
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
As long as you have air slots on sides , the other fans should pull air in. Do the test and see how it works out.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yeah, there's slots, not many. Along the bottom of each side panel there is some, and vents on the removable side door.
I imagine I could make more vents. It does run a couple degrees cooler when I keep the case door off.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
I clean it out to frequently to bother. Thanks anyways. When I get into some deep HD video editing I'll see what the temps go up to.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
