Printer installation problems
I was hoping sfc would repair them all. It's a wireless printer is it?
I would try these.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
I have to go right now have to work early. If you look at the thread and find any ideas to help me I will check back tomorrow. Thanks for all your help so far.
    self built
    amd dual core 2400
    asus
    2gb
    nvidia
    hitachi
Did you try this?
After taking ownership and deleting the file spoolsv
You can then try the following steps,
Right click on start --- Left click on explore ---- Go to i386 folder from C
drive --- search for the file spoolsv --- Copy the file spoolsv and paste in
C:\windows\system32.
EDIT: You need this as well
http://www.vistax64.com/tutorials/112795-context-menu-take-ownership.html
    LENOVO 64734VM
    15 inch
I activated the mobile wireless devices and I am still not able to use the set-up cd. Yes it is a wireless printer. My son set up a wireless printer from his laptop and I was able to access his printer through my PC. He moved out and I thought I would be able to do the same from my PC. This spooler problem is a ghost I haven't been able to exorcise since it started. I imagine if he set up my printer from his laptop on my network I should be able to use the printer. Yet the problem with my PC will remain.
    self built
    amd dual core 2400
    asus
    2gb
    nvidia
    hitachi
Did you try this?
You can try the following steps:
I tried to do that however I could not locate the i386 folder to copy from. The C:/windows/system32. Has a spoolsv file in it however it may be corrupt.
    self built
    amd dual core 2400
    asus
    2gb
    nvidia
    hitachi
Ok this is a copy un zip first.
    LENOVO 64734VM
    15 inch
The file you have that is corrupt you can take ownership of and delete.
Then take ownership of the file in the zip folder and replace the deleted one in system32
I left a link to a registry file that will add take ownership to the right click menu in an earlier post.
    LENOVO 64734VM
    15 inch
can anyone send me a clean copy of their spoolsv.exe file. I have been working on resolving this issue for 2 days and have tried many tips to fix. especially from the following thread....
Vista Forums > Vista Forums > General Discussion cannot restart print spooler error 5 permission denied
the only thing I haven't done is replace the corrupted spools file. Please help
    self built
    amd dual core 2400
    asus
    2gb
    nvidia
    hitachi
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
I sent you one, you have to save it to your computer, then right click and unzip it,it is there in the zip folder.
    LENOVO 64734VM
    15 inch
Sorry I didn't see you had sent me a copy. Trying it now. I will let you know.
    self built
    amd dual core 2400
    asus
    2gb
    nvidia
    hitachi
