niemiro
Banned
So do I run the Command Prompt after the scan or during?
After that you want me to upload the tasklist.txt to you and then download and run the batch file you provided for me after I place it in the appropriate folder. Then boot in Normal Mode (if it works) and then upload the new tasklist1.txt to you?
I just want to be clear in case I do something wrong since I don't want to be wasting your time, I'm totally thankful for sticking with me for so long. lol
It is not you who is wasting my time! It is I! For it is I who forgets you for several days before getting reminded! Anyway:
Boot into Safe Mode, and open an elevated Command Prompt, and then run tasklist /svc ... tasklist.txt should have been created on your Desktop. Ignore it for the moment.
Put the batch file into the folder previously mentioned. There is no need to run it yet. All that putting it in this folder will do is run it on startup. Boot into Normal Mode, and it should automatically run. Close it, and boot back into Safe Mode.
tasklist1.txt should have been created on your Desktop. Upload both tasklist.txt and tasklist1.txt from your Desktop to a new post here, all from Safe Mode.
Run MBAM Full Scan, and either upload the log file, or tell me that no infections were found. If no infections are found, there is no need to upload the log file, but if infections are found, I would like to see the log file please.
Thanks!
Richard
- Dell XPS 420
- Intel Core 2 Quad Q9300 2.50GHz
- Stock Dell 0TP406
- 4 gb (DDR2 800) 400MHz
- ATI Radeon HD 3870 (512 MBytes)
- Onboard
- 1 x Dell 2007FP and 1 x (old) Sonic flat screen
- 1600 x 1200 and 1280 x 1204
- 1 x 640Gb (SATA 300) Western Digital: WDC WD6400AAKS-75A7B0 1 x 1Tb (SATA 600) Western Digital: Caviar Black, SATA 6GB/S, 64Mb cache, 8ms Western Digital: WDC WD1002FAEX-00Z3A0 ATA Device
- PSU
- Stock PSU - 375W
- Case
- Dell XPS 420
- Cooling
- Stock Fan
- Advent Optical ADE-WG01 (colour change light up)
- Dell Bluetooth
- 120 kb/s
- Other Info
- ASUS USB 3.0 5Gbps/SATA 6Gbps - PCI-Express Combo Controller Card (U3S6)
