No wireless connection
I now have Windows 7 but no wireless. I even added my wireless network. When I troubleshooted this was the response:
Problem with wireless adapter or access point.
Might be a problem with driver for network bridge adapter.
    Sony Vaio VGN-CS320J
    Intel® Core™ 2 Duo Processor T6500 (2.10 GHz)
    4GB PC2-6400
    Mobile Intel® GM45 Express Chipset
    Intel® High Definition Audio
    WXGA
    320 GB
I'll have a look for drivers now. What version of Windows 7 have you got? Home premium, professional, ultimate etc.
Also, is your laptop 32bit or 64bit (x86 or x64)?
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Home premium 64 bit. I also feel I should mention this because I don't know if any of this is connected and all details may help. My computer problems originally started with an improper hibernation. This causes Chkdsk to run at startup everytime and my computer wouldn't sleep properly or hibernate and the wireless problem originated. Wireless would come on at time but then it stopped working totally. IN the process of trying to get chkdsk to stop running I tried several things including downloading AVG to do a virus scan. I got the chkdsk to stop and recently fixed my hibernation issue (though I haven't checked if hibernates properly recently) and also deleted AVG after finding a virus on my computer. So as of yesterday the only issue was the wireless internet. When I installed Windows 7 update in the middle of the process, I got a message that said drive X: may be corrupt and to run chkdsk. I clicked ok and when Windows 7 caused a restart, chkdsk ran and it seemed to resolve a problem at a certain file and the whole process went through.
    4GB PC2-6400
    WXGA
    320 GB
COuld something be wrong with my internet modem wirelessly because obviously it works when the ehternet cable is hooked up?
    4GB PC2-6400
    WXGA
    320 GB
i just had a quick flick through, didn't read all the solutions but here's some food for thought, "microsoft 6to4" ;)
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
I'm wondering if my Intel 5100 AGN adapter card is bad. Are those easy to replace or should I just try a USB adapter? I am looking for a quick fix. restoring my computer to purchase state is an option but it may not solve the problem. I am trying to start a business and this whole no wireless thing is hurting me!!!!
    4GB PC2-6400
    WXGA
    320 GB
You seem to know more about networking than me, so feel free to take over if you want?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I am not sure what this means.
    4GB PC2-6400
    WXGA
    320 GB
the microsoft 6to4 adapter is created when your network needs a connection to establish the network settings made by 3rd party applications, for example, windows media player needs a connection to share stuff on your network, but without a router connected, it cannot start service, so it creates it's own, called 6to4 (because it supports IPv6 and IPv4 connection types).
simply have a look in your network connections by opening up network and sharing center, go to network connections on the left and see what we have in there, if you see microsoft 6to4, then right click and disable, restart and see if the connection comes back.
    16Mb Sky bb
the microsoft 6to4 adapter is created when your network needs a connection to establish the network settings made by 3rd party applications, for example, windows media player needs a network to share stuff on your network, but without a router connected, it cannot start service, so it creates it's own, called 6to4 (because it supports IPv6 and IPv4 connection types).
Thanks for the information, you learn something new every day :)
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I am not seeing a microsoft 6to4 adapter in device manager or when I click change adapter settings in Network and Sharing Center. What is listed is my Local area connection, network bridge, and wireless network connection.
    4GB PC2-6400
    WXGA
    320 GB
delete the network bridge, unless you are bridging connections to other computers, its not needed, let me have a good look through this thread and catch up with whats been done and ill get back to you with some practcal solutions.
MrNeeds
Edit: ok, had a flick through, it's lucky that i'm on windows 7 right now, sounds to me like your drivers aren't installed, simple enough, get the download here > http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS320JP&upd_id=5882&os_id=49
    16Mb Sky bb
That didn't help. Troubleshooter (Windows Network Diagnostics) is failing to find the access point.
    4GB PC2-6400
    WXGA
    320 GB
ok, i've got 1 more thing to try and then i think you may need to contact sony, or join up with our sister forums and see if anybody else can help over there, click on the start menu and type "services.msc" without the quotation marks, and look for "WLAN autoconfig" and see if it is running, if it isn't then right click and set to automatic and start the service, then look for "WMI performance adapter" and see if that is running, if not, do the same as the other servcie and set to automatic and start, if this doesn't work then I can only suggest you pop over to here > Windows 7 Forums and see if our gurus' over there can help you a bit more than we could, sorry.
MrNeeds
    16Mb Sky bb
okay I will check that later. If something is wrond with the adapter itself, it would say it isn't working properly wouldn't it? I have a USB wireless adapter I borrowed that I am going to try.
    4GB PC2-6400
    WXGA
    320 GB
at the moment, i'd say that there maybe something underlying that I must be missing, it maybe software but the fact that your drivers are installed and you're not picking up any access points maybe an indication of a hardware fault, but i'm not dismissing software being the issue, that's why i've pointed you to 7 forums, i've only just upgraded to 7 so i'm not fully familiar with the UI or methods of fixing just yet, but the chaps over at 7 are more than capable of fixing this issue if it is software related.
MrNeeds
    16Mb Sky bb
MrNeeds
I did have to start the WMI performance adapter but that didn't do anything. I am using a USB wireless adapter and have successfully gotten on the internet wirelessly. But I am still mad I don't know why I can't get on wither my Intel adapter.
    4GB PC2-6400
    WXGA
    320 GB
