If you want to view the log open the cmd prompt box again and cut and paste this command into it.
notepad C:\windows\logs\cbs\cbs.log
This may give you some idea about what is getting corrupted.
You should have received both service packs and about 120 updates if your .ISO was the real deal.
Did you activate it and does it show as activated in Control panel,System.
If when you run the ABR program it fails, open the .txt file it has made and cut and paste the code from there into the correct place.
It should also say Service pack 2 in the top section.
You could also go to windows update and see if it will receive them alright.
If your copy of Windows is Genuine it should also say that at the bottom of the System page to the right of the Activated section.
If it will do all that it should pass Windows Genuine Advantage Test.
- Lenovo Thinkpad T400
- Intel Mobile Core 2 Duo P8700 @ 2.53GHz
- LENOVO 64734VM
- 2.00GB Single-Channel DDR3 @ 531MHz
- Intel Mobile Intel 4 Series Express Chipset Family
- Conexant 20561 SmartAudio HD
- 15 inch
- 1280 x 800
- 1x 180GB Intel 530 series SSD 1 x 120GB Hitachi 5400rmp 1 x 650GB Western Digital Elements 5400rpm 1x 1Tb Western Digital Elements 5400rpm
- Medium for New Zealand
- Other Info
- Weakest part of my computer is the graphics chipset. Only ever used a laptop. Also use USB Freeview TV Card Lenovo Docking Station External Speakers Other bits a pieces as needed
