Solved new here and need some help
Just a note I once had ABR fail to run again after I had installed but you are still able to open the file it makes and cut and paste you activation code.worked sweet.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
can i put the dvd and ABR on a thumbstick
sry for all the stupid questions i just dont want a laptop shaped paper weight
Only if your computer can boot from a USB drive
I would use a DVD if it was me.
    LENOVO 64734VM
    15 inch
ok dvd it is
2 separate dvds??? one for each program
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    Logitech M215 wireless
    LIGHTNING FAST
one DVD for the ISO and you can use a USB stick for ABR.
    LENOVO 64734VM
    15 inch
k
do you know where i can get a good torrent this one is horrible only 5 seeds and im dloading at about 50kb/sec normally i can dload at about 2.3MB/sec
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
Be warned this will take some time to do. The Windows updates take a long time to finish. Then you have to reinstall all your favorite programs and do all the tweaks you like.
Last time I did mine it took 20 hours to complete with all programs and tweaks but I ended up with a clean fast computer.
If you are using a torrent file for your ISO I would scan it with MalwareBytes first.
    LENOVO 64734VM
    15 inch
im aware that this will take forever i have tons of time (i live in sc it snowed and the whole state is dead altho im from ny and am completely used to the snow) i have norton and it autoscans all my dloads
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
LOL its coming to NY tomorrow 12-18 inches. I have been to Charleston many times.
It's summer here and we have been told to expect a hot summer this year.
Hot for us is not really that hot.
    LENOVO 64734VM
    15 inch
i love Charleston i want to move there so bad just for the fishing off the pier at folly beach
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
My fav is Savanah. Took a tour it was such a nice time.
The Movie the Patriot is based on Swamp Fox, who comes from the ares. parts of the Movie were filmed in Charleston and Mt Pleasant (at one of the plantations)
After you have your system up and setup how you like it get an external hard drive and take an image of your disc and save it to that. It will make it a lot faster to restore if you ever have to do it again. I use Macrium Reflect Free.
Macrium Reflect FREE Edition - Information and download
    LENOVO 64734VM
    15 inch
have you ever used or heard anything about a SATA dock i have a brand new never used WD 500GB SATA hard drive that i would love to use and i can get one off amazon.com for like 20 bucks
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
I've never had the need for a dock and haven't looked at them
I use two external drives for media.
    LENOVO 64734VM
    15 inch
so i got imgburn do i want to run that iso file thru power iso and the burn it to the disk also when i start up imgburn it asks me what do you want to do do i want to burn image to disk or files/folders to disk???
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
Sorry I took so long to answer You want to burn the image to disc.
    LENOVO 64734VM
    15 inch
Sounds like you are just about ready to start. Run the ABR, save it and any files you want to keep to another hard drive or USB stick. Restart your computer and look at the bottom of the screen and you will see how to get into the boot menu.
You will only be able to use the arrow keys and you have to get the DVD to the top,
Some computers will only let you move things down not up so move any above the DVD to below the DVD entry.
Put in the disc you have just made and it will start the install.
Did you read the Tutorial by Brink that I sent you the link for as it will show you what to expect to see.
Should see you back here in about 20 hours.
    LENOVO 64734VM
    15 inch
so i did what you said but it only took about 45 min to do it all up (is it possible im running 2 vistas now i didnt need to dload any updates)
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
That doesn't sound correct could you please go to computer,right click,manage,disc management and take a snip with the snipping tool and post it.
Is it working alright or are there problems.
EDIT: could you also go to the start search box type cmd hold shift and ctrl press enter. this will open a command prompt in administrator mode.
In the box that opens type SFC /SCANNOW
note the space before scannow.
This will check your system files.
    LENOVO 64734VM
    15 inch
everything seems like its running fine
scanning now ill post back as soon as its done
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
