network identifing problem
do u hav any conntact infomation i can call u on rite now and speak to you over the phone so i can give live info on whats going on this end i would gladly give u my com details if it means i can get it running wel again i just want my com 2 run like its brand new again the way all laptops shud lol speak in min david
You just downloaded/ran malware to your system with that reg cleaner and mcafee apparently didnt catch it, or stop it.
Ill help you here, If you will follow my instructions- that suggests it is corrupted. and your system is full of malware, and/or corruption
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
ok thanks boss at minute im running sfc /scannow in cmd at min and me hard disk has slowed down now however the cleaner u sed to download i wiped it coz u sed get it off me com before it curups me windows so i did i had this registory cleaner it found 775 errors but wid it being a free trile could only fix 10 so i clicked fix then after that wiped it like u sed im just awaiting ye next instruction also i hav macafee on my com but is there any malware inside it that i can use 2 scan with saves me having 2 download it lol
Alright. That reg cleaner you downloaded from zoombli.com is known Malware.
I never linked you to that reg cleaner. You have malware that is infecting your HOSTS file.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
You need to backup all your User data through Vista file backup utility and do a destructive reformat and re-install of Vista.
Do not install Mcafee. Install either Avast! or Avira.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
now what do i do my friend to remove that then the items i downloaded i removed them as u told me to do so and there is another guy who posted a message on the thred who is having the sam problem as me so im not on me own ere cud u help him 2
Listen.
I never gave you a link to that rogue "reg Cleaner" which is a known malware program.
I specifically asked you to install either Avast or Avira and malwarebytes and delete the possibly corrupted version of mcafee. then run those scans BEFORE running sfc /scannow and disk check. I suspect that your issues are due to viruses and trojans/hijackers/hosts file redirection, etc.
You need to re-install Windows after backing up your User data.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
i see boss that zoobil i never had a page like that wen i downloaded that cleaner also cmd has finished the verification prosess and it did find curupted files also canu email me a step by step on backing up info and then re installing windows thanks boss
Download the FREE registry cleaner Demo! ive just downloaded this and its found a tun of errors in me registory files i mean alot lol lol
This is the URL address you posted:www.zoombli.com/PrimaryLanding/Sammsoft/ARO/v52/Default.aspx?Referrer=uc-C11whitegloveRV-aro&utm_source=DownloadDotCom&utm_medium=Banner&utm_term=728x90whiteglove&utm_content=SecurityLB&utm_campaign=AdvancedRegistryOptimizer
I know you didnt because you probably have HOSTS file malware.
look... this is the page you linked in your post: (notice the addy)
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Again,
You have malware/viruses/Trojans (most likely)
Run the antivirus and malwarebytes scanners to clean your system, and/or reinstall Vista.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
first i need a direct like for the malwarebytes scanners and then i need to know how to re install vista and also back up me files can u help wi captin th that
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
ive just gone on2 it is it the free trile version i get and will it fully remove all of them and fix any files that r curupted or do i need to re install vist 2 fix the files and also, how do i back up my files
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
To access the backup utility go to Start>in search bar, type, backup> then follow prompts to backup to either DVDs or external drive
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Reposted steps to follow:
run the scans with the antivirus and malwarebytes. If they come up clean then that is good. that means your issue is not malware related.
then, go the the performance link I gave you How To Make Vista more responsive and faster , follow the walkthrough to activate the Admin: command prompt-BUT copy and paste this and hit enter:
sfc /scannow
If it comes back with no integrity violations, then skip to step two (disk check) follow the walkthrough. If it comes back with no system file issues or corruption or bad sectors, then we know Windows is ok.
then we update your WLAN driver ( I will need you system model number to locate the driver).
IF... you fail any of these scans with corruption or the scan aborts, that means Windows is messed up and is the cause of your issues. This will neccessitate a re-install of Vista most likely to fix. At that point you will Use Vista's file backup Utility to backup all your User data.
See walkthrough to access Backup Utility above, and re-install Tutorial if a re-install is required.
note- Install Avast antivirus it is a free antivirus/antimalware with a free year subscription. Uninstall your version of Mcafee after you install Avast!.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
thanks so much my friend im doing the malbites scan now and its ok so far but there is ****ed up files on my com tho curpted ones but dont now how 2 fix them tho and as for my drivers 2 the WLAN can they be updated now or do i hav 2 do that later and also if im under worrinty will they take me com and do it all for me
wait untill the scans are done- and be sure to scan with Avast.
then do a disk check. Windows may need to be repaired or re-installed due to corruption.
EDIT:
you can contact your systems tech support/customer service. The number should be in the book that came with your laptop (or on a sticker on the bottom), and see if they can help you. If they do take it you will be without it probably 4-6 weeks, and It will come back most likely with the Vista O/S re-installed. So backup all your data files.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
thanks boss also i will back the lot up and wen u say it needs vista re installing do u mean basicly 2 fletten the com and reinstall the lot also id there any way i can reinstall the WLAN drivers ie update them now 2 c if that helps and with most files curupted can they be repaired now by any chance if so how
