Need help deleting Java 6 Update 29
OK, now the big guns
Go to search type java, if it pops up right click and then settings, find out where it is hiding and then delete manually. If that does not work, use the same procedure and when in setting, click delete temporary files.
Mine are in C:/ progam files86>java
Yeah I did, and Disk Cleanup and it's still there. I'm going to go to bed now so I will check the tread in the morning. I'm running a virus scan with Malware Bytes right now, just thought I might as well try it.
Defrag may put different remanants of the software in the right order to allow you to uninstall.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Look in the registry for the entry: -
Each entry on this list (Start > Settings > Control Panel > Add/Remove Programs) is held in a key in the registry under:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
Use 'regedit' to edit the registry. Ideally backup your machine before you do this in case you modify the wrong registry entry.
Just remove the key for any entries that are no longer required.
Note: Most entries reflect the application name as it appears in the list. Some do not. The sub-key 'Application Name' holds the application name as it appears in the uninstall list.
From: - MS Win Troubleshooting - Remove (uninstall) program fails
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Well I already did this method to remove all java related registries.
OK,
If that is so, it would not be listed in the control panel, "Programs & Features" list.
If you display the control panel as a list on the Start menu, is "Java" listed in there? If so, what does the applet say about Java?
    40 Meg
In "Revo uninstaller", what options do you have if you right click on the Java icon?
    40 Meg
Coming late to this and only having skim-read - so I could be off-base.
The initall post had a removal log - that log is APPENDED, NOT REPLACED, when the removal tool is run again.
That is why it always contains the same information!
What evidence is there that the original Java install is still present? - by the OP's own statements he cannot find either the files or the registry entries involved.
    Acer Aspire 8930G
No it is not in the control Panel or Revo Uninstaller. It appears that is is gone except in add/remove programs and when I try to delete it. And Noel what do you mean? There is no Java install files. My problem is When Installing new version it deletes old version but cannot find the msi file for removing old one. Even though I cannot find the file even when I installed on other comp.
Try installing Java 6u18 again: -
Download from here: -
JAVA6u18
    40 Meg
What installer are you using to install the new version?
Have you perhaps had both the x86 and x64 versions installed, and only removed one of them?
Check not only the C:\Program Files folder, but also the C:\Programs Files (x86) folder (if you have one).
From what I can see inthe JavaRa log, the only affected folders on the machine were the ones accessible without Admin access - I suspect that you only ran the tool as a normal user, and need to run it with Admin permissions, or with UAC turned off (there is a note to this effect in the JavaRa pages, but it's almost invisible)
    Acer Aspire 8930G
I have downloaded 18 before and nothing I am an Admin. I Have no traces of java on my pc except in the add/remove programs, java test says I have no Java installed.
Just because you are an administrator, does not mean that you are running with Administrator rights - when you ran JavaRa, were you asked to provide Administrator credentials? If not, then it was running as a limited user, and did not have access to many areas of the OS.
    Acer Aspire 8930G
