Mystery BSOD problem
i forgot there for a moment.
i was reading the dump. its something to do with ntkrpamp.exe
vista driver fault
ntkrpamp.exe essentially is one of the main (core) windows drivers, and are essentially "windows" .
you basically have windows crashing itself, or something causing windows to crash itself.
you really have something messed up there.
i was searching on the bsod index about the bugcheck str: 0x7f_d and i couldnt find anything, so then i proceeded to search on google.
my hunch says that your OS is corrrupt. but, there are many other possibilities. if youve ran memtext 86, chkdsk, set clocks to default, updated drivers for other components (gpu, mobo chipset) and STILL you are getting bsods, then it is something with your OS. if you have sp1 then i suggest that you upgrade to service pack 2.
and just in case, if this information is wrong forgive me, im no expert at bsod problems
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
have you done or able to have any other hardware tests done?, all it can take for a system to fall over is a 10th of a volt or a few hz off. have you tried swopping out components, or a burn-in/stress test of any sort ?
    home brews
    pc1 msi k7delta, pc2 asus kn79txd evo
    pc1 2gb crucial, pc2 4gb gskill ripjaws
    pc1 bfg 7800gs, pc2 shapphire 5770 vapor-x
    onboard
    corsair hx
    jeantech phong
    pc1, handmade waterblocks,passive cooling, pc2 corsair h50
    logictech mx510s wired
LOL. they said the same thing that we suggested: memtest, chkdsk,driver verifier, mobo drivers, cool n' quiet. if they get this thing sorted out then thumbs up to them!
but what i didnt realize is the power supply, they suggested that you check that and i think it would be a good idea to.
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
They suggest PSU for everything. :rolleyes:
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
that is true but, i really doubt that the power supply is the problem. hey did you get bsods everytime when you just STARTED using your computer, or did the bsod catch on after a while of computer usage. if it started after a period of time on the computer then i doubt that its the powersupply.
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
