Mystery BSOD problem
Alright, here is what i found:
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault). The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
DEFAULT_BUCKET_ID: vista_driver_fault
MODULE NAME: amdk8.sys
Reinstall your amd cpu drivers. amdk8.sys is a cpu driver for AMD.
This is usually caused by that driver going on an incorrectly addressed part of the memory.
If overclocking, set everything back to default.
Also try to run memtest86 to check for memory problems.
If you have the cool and quiet technology on your motherboard, try to disable it.
Good luck and post your results.
-Kelvin
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
Re-install your chipset drivers and in vista set your power options to high.
Go into the Bios and disable all power saving options, especially the CPU power saving options.
Can you confirm that you have replaced the amdk8.sys driver file.
This all comes back to this file, or at least that is what the dump files are saying, so until this file has been eliminated we cant move forward.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I was looking around on google, and the amdk8.sys file is the file that helps the processor use the Cool and Quiet technology from AMD, disable that feature (perhaps from the bios or whatever way).
Stoney, did i interpret the minidump correctly?
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
Yes you did, good work.
The problem seems to be around the CPU and/or driver.
When i first started i went through all the old BSOD posts and tried to decipher them without looking at the the answers, its good practise, what you will find though, is that its not as hard as you first thought it was, i thought it was black magic at first. lol.
If you ever need any help just ask, although i have not been doing it that long myself. You learn something new with each one.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hold on, I thought I was supposed to keep amdk8.sys. im pretty sure that the one I have in is the most recent. i found it on the internet on freedrive.com. cool and quiet was disabled already, but there was something called AMD visualization or something like that. It say something else too but the first AMD visualization is the only thing enabled. I set the power to high.
Here's where my serious inexperience comes into play. I'm not sure how to re-install a chipset (or what the chipset is beyond the processor.) Could you point me in the right direction?
You will need to go to your MB manufacturers site for the chipset drivers.
Also, don't forget to monitor the CPU temps.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Apparently, this is often associated with memory problems. You said you had recently replaced the RAM. Is it all the same? Compatible with motherboard? Do you need to set any special BIOS settings for it?
See Microsoft Online Crash Analysis.
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
Getting beyond my pay grade; sorry about that.
You might want to try _Tech Support Forum. They've got a number of Microsoft techies there who know their stuff. If you do, make sure you post a list of everything you've already tried so they know immediately what didn't work.
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Although I agree that TSF has a great staff, I must insist that the staff here is just as capable. Although, I am not an expert when it comes to BSOD, may I suggest that I contact someone with extensive knowledge in this field, so that you may be helped.
No offense intended, Richard.
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Ed
No offense taken ED. I just want to give the Thread Starter full advantage of our surperb knowledge regarding the BSOD, before he moves on.
You have given the thread starter excellent help and gave an honest opinion.. I cannot take offense at that.
I have seen some of these experts bring back a computer from the dead.
Richard has asked me to give a hand.
Download a copy of Memtest86 and burn the ISO to a CD using Iso Recorder. Boot from the CD, and run it for at least 5 passes.
Uninstall AVG and then run this removal tool: http://download.avg.com/filedir/util/avg_arm_sup_____.dir/avgremover.exe
Then download and install Microsoft Security Essentials.
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\Jonathan\AppData\Local\Temp\Temp1_New Folder (2).zip\New Folder (2)\Mini051610-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 6002.18209.x86fre.vistasp2_gdr.100218-0019
Machine Name:
Kernel base = 0x81e45000 PsLoadedModuleList = 0x81f5cc70
Debug session time: Sun May 16 12:02:30.335 2010 (GMT-4)
System Uptime: 0 days 1:14:51.020
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 7F, {d, 0, 0, 0}
Probably caused by : ntkrpamp.exe ( nt!KiSystemFatalException+f )
Followup: MachineOwner
1: kd> !analyze -v
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
        use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
        use .trap on that value
Else
        .trap on the appropriate frame will show where the trap was taken
        (on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 0000000d, EXCEPTION_GP_FAULT
Arg2: 00000000
Arg3: 00000000
Arg4: 00000000
Debugging Details:
BUGCHECK_STR:  0x7f_d
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  System
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from 84a1409d to 81e9374f
STACK_TEXT:
803ecc00 84a1409d badb0d00 00000000 803ecc20 nt!KiSystemFatalException+0xf
WARNING: Frame IP not in any known module. Following frames may be wrong.
803ecc70 803eccf8 87d64a9c badb0d00 00000000 0x84a1409d
803ecc9c 81eee003 83c48e0e 803eccdc 00000004 0x803eccf8
803eccf8 81ef5d14 86731098 00000000 86f01d78 nt!EtwpCCSwapTrace+0x3b1
803ecd50 81eed861 00000000 0000000e 00000848 nt!PoIdle+0x2d1
803ecd54 00000000 0000000e 00000848 4c480484 nt!KiIdleLoop+0xd
STACK_COMMAND:  kb
FOLLOWUP_IP:
81e9374f c3              ret
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!KiSystemFatalException+f
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrpamp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4b7d1e08
FAILURE_BUCKET_ID:  0x7f_d_nt!KiSystemFatalException+f
1: kd> lmntsmn
start    end        module name
87a00000 87a0d080   1394BUS  1394BUS.SYS  Sat Jan 19 00:53:27 2008 (47919057)
80605000 8064b000   acpi     acpi.sys     Sat Apr 11 00:19:03 2009 (49E01A37)
8cab2000 8cb04000   ADIHdAud ADIHdAud.sys Tue Jan 16 11:41:49 2007 (45AD004D)
8d0bd000 8d105000   afd      afd.sys      Sat Apr 11 00:47:01 2009 (49E020C5)
87d63000 87d73000   amdk8    amdk8.sys    Sat Jan 19 00:27:20 2008 (47918A38)
8c9c6000 8c9ce000   ASACPI   ASACPI.sys   Wed Oct 18 01:44:46 2006 (4535BF4E)
8d1f4000 8d1f5440   AsIO     AsIO.sys     Wed Dec 21 03:55:21 2005 (43A91879)
9a9cc000 9a9d5000   asyncmac asyncmac.sys Sat Jan 19 00:56:29 2008 (4791910D)
80710000 80718000   atapi    atapi.sys    Sat Apr 11 00:39:09 2009 (49E01EED)
80718000 80736000   ataport  ataport.SYS  Sat Apr 11 00:39:10 2009 (49E01EEE)
87d06000 87d48800   atksgt   atksgt.sys   Thu Oct 02 05:43:41 2008 (48E497CD)
9c986000 9c9b9280   avgldx86 avgldx86.sys Wed Feb 10 22:51:19 2010 (4B737EB7)
9c980000 9c985940   avgmfx86 avgmfx86.sys Wed Feb 17 17:38:39 2010 (4B7C6FEF)
9c9ba000 9c9f3a80   avgtdix  avgtdix.sys  Tue Apr 13 17:11:02 2010 (4BC4DDE6)
8cbd7000 8cbde000   Beep     Beep.SYS     Sat Jan 19 00:49:10 2008 (47918F56)
80425000 8042d000   BOOTVID  BOOTVID.dll  Sat Jan 19 02:27:15 2008 (4791A653)
9a898000 9a8b1000   bowser   bowser.sys   Sat Jan 19 00:28:26 2008 (47918A7A)
93920000 9392e000   cdd      cdd.dll      unavailable (00000000)
9c96a000 9c980000   cdfs     cdfs.sys     Sat Jan 19 00:28:02 2008 (47918A62)
805d7000 805ef000   cdrom    cdrom.sys    Sat Apr 11 00:39:17 2009 (49E01EF5)
8046e000 8054e000   CI       CI.dll       Sat Apr 11 02:25:22 2009 (49E037D2)
87fc0000 87fe1000   CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
8042d000 8046e000   CLFS     CLFS.SYS     Sat Apr 11 00:13:51 2009 (49E018FF)
8d467000 8d474000   crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
87fe1000 87fea000   crcdisk  crcdisk.sys  Sat Jan 19 00:50:29 2008 (47918FA5)
8d182000 8d1dd000   csc      csc.sys      Sat Apr 11 00:14:49 2009 (49E01939)
8d1dd000 8d1f4000   dfsc     dfsc.sys     Sat Apr 11 00:14:12 2009 (49E01914)
87faf000 87fc0000   disk     disk.sys     Sat Apr 11 00:39:14 2009 (49E01EF2)
8cb31000 8cb56000   drmk     drmk.sys     Sat Jan 19 01:53:02 2008 (47919E4E)
8d474000 8d47e000   dump_diskdump dump_diskdump.sys Sat Apr 11 00:39:11 2009 (49E01EEF)
8d4b5000 8d4c6000   dump_dumpfve dump_dumpfve.sys Sat Jan 19 00:27:05 2008 (47918A29)
8d47e000 8d4b5000   dump_nvstor32 dump_nvstor32.sys Tue Aug 04 20:27:05 2009 (4A78D1D9)
8d4c6000 8d4d0000   Dxapi    Dxapi.sys    Sat Jan 19 00:36:12 2008 (47918C4C)
8c919000 8c9ba000   dxgkrnl  dxgkrnl.sys  Thu Sep 24 21:27:14 2009 (4ABC1C72)
87f64000 87f8b000   ecache   ecache.sys   Sat Apr 11 00:40:12 2009 (49E01F2C)
8d404000 8d42c000   fastfat  fastfat.SYS  Sat Apr 11 00:13:52 2009 (49E01900)
807ed000 807fd000   fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
807bb000 807ed000   fltmgr   fltmgr.sys   Sat Apr 11 00:13:59 2009 (49E01907)
8cbc7000 8cbd0000   Fs_Rec   Fs_Rec.SYS   unavailable (00000000)
87f8b000 87faf000   fvevol   fvevol.sys   Sat Apr 11 00:13:03 2009 (49E018CF)
87ceb000 87d06000   fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
87df7000 87dfc280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
81e12000 81e45000   hal      halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8bc0c000 8bc99000   HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8cb9f000 8cbaf000   HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
8cbaf000 8cbb5380   HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
8cb96000 8cb9f000   hidusb   hidusb.sys   Sat Apr 11 00:42:48 2009 (49E01FC8)
9a80e000 9a87b000   HTTP     HTTP.sys     Sat Feb 20 15:53:31 2010 (4B804BCB)
8ca13000 8ca1e000   kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8cbb6000 8cbbf000   kbdhid   kbdhid.sys   Sat Apr 11 00:38:40 2009 (49E01ED0)
8040d000 80414000   kdcom    kdcom.dll    Sat Apr 11 02:25:29 2009 (49E037D9)
8ca2b000 8ca55000   ks       ks.sys       Sat Apr 11 00:38:47 2009 (49E01ED7)
87a0e000 87a7f000   ksecdd   ksecdd.sys   Mon Jun 15 08:48:53 2009 (4A364335)
9a9dc000 9a9e0880   lirsgt   lirsgt.sys   Tue Jun 17 10:41:11 2008 (4857CD07)
8d5aa000 8d5ba000   lltdio   lltdio.sys   Sat Jan 19 00:55:03 2008 (479190B7)
8d4df000 8d4fa000   luafv    luafv.sys    Sat Jan 19 00:30:35 2008 (47918AFB)
8d4d0000 8d4df000   monitor  monitor.sys  Sat Jan 19 00:52:19 2008 (47919013)
8ca1e000 8ca29000   mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8cbbf000 8cbc7000   mouhid   mouhid.sys   Sat Jan 19 00:49:16 2008 (47918F5C)
80700000 80710000   mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
9a8b1000 9a8c6000   mpsdrv   mpsdrv.sys   Sat Jan 19 00:54:45 2008 (479190A5)
9a8c6000 9a8e7000   mrxdav   mrxdav.sys   Sat Apr 11 00:14:39 2009 (49E0192F)
9a8e7000 9a906000   mrxsmb   mrxsmb.sys   Tue Feb 23 06:10:12 2010 (4B83B794)
9a906000 9a93f000   mrxsmb10 mrxsmb10.sys Tue Feb 23 06:10:17 2010 (4B83B799)
9a93f000 9a957000   mrxsmb20 mrxsmb20.sys Tue Feb 23 06:10:12 2010 (4B83B794)
8d03f000 8d04a000   Msfs     Msfs.SYS     unavailable (00000000)
80654000 8065c000   msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8c9ce000 8c9fd000   msiscsi  msiscsi.sys  Sat Apr 11 00:40:07 2009 (49E01F27)
87b8a000 87bb5000   msrpc    msrpc.sys    unavailable (00000000)
8ca55000 8ca5f000   mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
87f55000 87f64000   mup      mup.sys      Sat Apr 11 00:14:12 2009 (49E01914)
87a7f000 87b8a000   ndis     ndis.sys     Sat Apr 11 00:45:52 2009 (49E02080)
8bd07000 8bd12000   ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8bd12000 8bd35000   ndiswan  ndiswan.sys  Sat Apr 11 00:46:31 2009 (49E020A7)
8caa1000 8cab2000   NDProxy  NDProxy.SYS  Sat Jan 19 00:56:28 2008 (4791910C)
8d11b000 8d129000   netbios  netbios.sys  Sat Jan 19 00:55:45 2008 (479190E1)
8d077000 8d0a9000   netbt    netbt.sys    Sat Apr 11 00:45:35 2009 (49E0206F)
87bb5000 87bf0000   NETIO    NETIO.SYS    Sat Apr 11 00:46:21 2009 (49E0209D)
8d04a000 8d058000   Npfs     Npfs.SYS     Sat Apr 11 00:14:01 2009 (49E01909)
8d178000 8d182000   nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
81e45000 821fe000   nt       ntkrpamp.exe Thu Feb 18 06:01:28 2010 (4B7D1E08)
87e04000 87f14000   Ntfs     Ntfs.sys     Sat Apr 11 00:14:34 2009 (49E0192A)
8cbd0000 8cbd7000   Null     Null.SYS     unavailable (00000000)
8c917000 8c918040   nvBridge nvBridge.kmd Tue Jan 12 00:18:11 2010 (4B4C0613)
8be0b000 8c916080   nvlddmkm nvlddmkm.sys Tue Jan 12 00:32:34 2010 (4B4C0972)
8bc99000 8bcefc00   nvmimx32 nvmimx32.sys Wed Jul 01 14:52:46 2009 (4A4BB07E)
80736000 80743000   nvstor   nvstor.sys   Wed Jun 06 16:34:41 2007 (46671A61)
80784000 807bb000   nvstor32 nvstor32.sys Tue Aug 04 20:27:05 2009 (4A78D1D9)
805ef000 805fe300   ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
8d105000 8d11b000   pacer    pacer.sys    Sat Apr 11 00:45:51 2009 (49E0207F)
87d97000 87daf000   parport  parport.sys  Sat Jan 19 00:49:32 2008 (47918F6C)
80683000 80692000   partmgr  partmgr.sys  Sat Apr 11 00:39:19 2009 (49E01EF7)
9a9d5000 9a9dc000   parvdm   parvdm.sys   unavailable (00000000)
8065c000 80683000   pci      pci.sys      Sat Apr 11 00:19:16 2009 (49E01A44)
806eb000 806f2000   pciide   pciide.sys   Sat Apr 11 00:39:10 2009 (49E01EEE)
806f2000 80700000   PCIIDEX  PCIIDEX.SYS  Sat Apr 11 00:39:09 2009 (49E01EED)
9c805000 9c8e3000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
8d5cd000 8d5f2000   PnkBstrK PnkBstrK.sys Mon Sep 28 12:03:16 2009 (4AC0DE44)
8cb04000 8cb31000   portcls  portcls.sys  Sat Apr 11 00:42:48 2009 (49E01FC8)
80414000 80425000   PSHED    PSHED.dll    Sat Apr 11 02:25:32 2009 (49E037DC)
8d058000 8d061000   rasacd   rasacd.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8bcf0000 8bd07000   rasl2tp  rasl2tp.sys  Sat Jan 19 00:56:33 2008 (47919111)
8bd35000 8bd44000   raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8bd44000 8bd58000   raspptp  raspptp.sys  Sat Jan 19 00:56:34 2008 (47919112)
8bd58000 8bd6d000   rassstp  rassstp.sys  Sat Apr 11 00:46:40 2009 (49E020B0)
8d13c000 8d178000   rdbss    rdbss.sys    Sat Apr 11 00:14:26 2009 (49E01922)
8d02f000 8d037000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:01:08 2008 (47919224)
8bd6d000 8bdf6000   rdpdr    rdpdr.sys    Sat Apr 11 00:52:32 2009 (49E02210)
8d037000 8d03f000   rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
9c937000 9c96a000   RDPWD    RDPWD.SYS    Sat Apr 11 00:51:22 2009 (49E021CA)
8d5ba000 8d5cd000   rspndr   rspndr.sys   Sat Jan 19 00:55:03 2008 (479190B7)
9c8e3000 9c8ed000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
87d8d000 87d97000   serenum  serenum.sys  Sat Jan 19 00:49:29 2008 (47918F69)
87d73000 87d8d000   serial   serial.sys   Sat Jan 19 00:49:34 2008 (47918F6E)
8d0a9000 8d0bd000   smb      smb.sys      Sat Apr 11 00:45:22 2009 (49E02062)
87f4d000 87f55000   spldr    spldr.sys    Thu Jun 21 20:29:17 2007 (467B17DD)
8d4fa000 8d5aa000   spsys    spsys.sys    Tue Mar 10 13:10:28 2009 (49B69F04)
9a97e000 9a9cc000   srv      srv.sys      Fri Dec 11 06:43:28 2009 (4B223060)
9a957000 9a97e000   srv2     srv2.sys     Mon Sep 14 05:29:49 2009 (4AAE0D0D)
9a87b000 9a898000   srvnet   srvnet.sys   Fri Dec 11 06:43:10 2009 (4B22304E)
80743000 80784000   storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8ca29000 8ca2a380   swenum   swenum.sys   Sat Jan 19 00:49:20 2008 (47918F60)
87c01000 87ceb000   tcpip    tcpip.sys    Thu Feb 18 06:28:54 2010 (4B7D2476)
9c8ed000 9c8f9000   tcpipreg tcpipreg.sys Tue Dec 08 12:26:18 2009 (4B1E8C3A)
8be00000 8be0b000   TDI      TDI.SYS      Sat Jan 19 00:57:10 2008 (47919136)
9c920000 9c92b000   tdtcp    tdtcp.sys    Sat Jan 19 01:01:08 2008 (47919224)
8d061000 8d077000   tdx      tdx.sys      Sat Apr 11 00:45:56 2009 (49E02084)
8ca03000 8ca13000   termdd   termdd.sys   Sat Apr 11 00:51:14 2009 (49E021C2)
93900000 93909000   TSDDD    TSDDD.dll    unavailable (00000000)
9c92b000 9c937000   tssecsrv tssecsrv.sys Sat Jan 19 01:01:15 2008 (4791922B)
87ff7000 88000000   tunmp    tunmp.sys    Sat Jan 19 00:55:40 2008 (479190DC)
87d58000 87d63000   tunnel   tunnel.sys   Thu Feb 18 06:28:13 2010 (4B7D244D)
8d42c000 8d467000   udfs     udfs.sys     Sat Apr 11 00:13:59 2009 (49E01907)
8ca5f000 8ca6c000   umbus    umbus.sys    Sat Jan 19 00:53:40 2008 (47919064)
8cb84000 8cb95e00   usbaudio usbaudio.sys Sat Apr 11 00:42:54 2009 (49E01FCE)
8cb56000 8cb6d000   usbccgp  usbccgp.sys  Sat Jan 19 00:53:29 2008 (47919059)
8cb6d000 8cb6e700   USBD     USBD.SYS     Sat Jan 19 00:53:17 2008 (4791904D)
87bf0000 87bff000   usbehci  usbehci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
8ca6c000 8caa1000   usbhub   usbhub.sys   Sat Apr 11 00:43:14 2009 (49E01FE2)
87daf000 87db9000   usbohci  usbohci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
87db9000 87df7000   USBPORT  USBPORT.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
8cb6f000 8cb84000   USBSTOR  USBSTOR.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
8cbde000 8cbea000   vga      vga.sys      Sat Jan 19 00:52:06 2008 (47919006)
8d00e000 8d02f000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
80692000 806a1000   volmgr   volmgr.sys   Sat Jan 19 00:49:51 2008 (47918F7F)
806a1000 806eb000   volmgrx  volmgrx.sys  Sat Apr 11 00:39:25 2009 (49E01EFD)
87f14000 87f4d000   volsnap  volsnap.sys  Sat Apr 11 00:39:37 2009 (49E01F09)
8d129000 8d13c000   wanarp   wanarp.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8c9ba000 8c9c6000   watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
8054e000 805ca000   Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
805ca000 805d7000   WDFLDR   WDFLDR.SYS   Sat Jan 19 00:52:19 2008 (47919013)
936e0000 938e2000   win32k   win32k.sys   unavailable (00000000)
8064b000 80654000   WMILIB   WMILIB.SYS   Sat Jan 19 00:53:08 2008 (47919044)
9c90e000 9c920000   WUDFPf   WUDFPf.sys   Sat Jan 19 00:52:49 2008 (47919031)
9c8f9000 9c90d580   WUDFRd   WUDFRd.sys   Sat Jan 19 00:53:04 2008 (47919040)
Unloaded modules:
87fea000 87ff7000   crashdmp.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
87d06000 87d10000   dump_storpor
    Checksum:  00000000
87d10000 87d47000   dump_nvstor3
    Checksum:  00000000
87d47000 87d58000   dump_dumpfve
    Checksum:  00000000
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Ill read the bsod dump file when i get home, i dont have windebug atm. Ill get back to you.
-Kelvin
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
I see the dump is from 16 May 2010 and driver updates mentioned, but have these Asus mobo utility drivers been updated?
Code:
[FONT=lucida console]ASACPI.sys Wed Oct 18 01:44:46 [COLOR=red]2006[/COLOR] (4535BF4E) - Asus ATK0110 ACPI Utility[/FONT]
[FONT=lucida console]AsIO.sys   Wed Dec 21 03:55:21 [COLOR=red]2005[/COLOR] (43A91879) - Asus "Cool n Quiet"[/FONT]
Go to Asus Support site --> ASUSTeK Computer Inc.-Support-
Slideshow for asio.sys update --> Asus mobo utility driver updates - jcgriff2 - Windows Live Slideshow
Choose Vista instead of Windows 7 for OS, but note that same asio.sys driver update is shared by both OS'. Same instructions apply for asacpi.sys - but look for ATK0110 mobo utility driver update.
Also update NVIDIA nForce SATA driver -
Code:
[FONT=lucida console]nvstor.sys   Wed Jun 06 16:34:41 [COLOR=red]2007[/COLOR] (46671A61)[/FONT]
NVIDIA --> Drivers - Download NVIDIA Drivers
Please be sure to follow advice by Jonathan King. If RAM checks out, drivers are updated, AVG replaced with MSE and BSODs persist, run the Driver Verifier.
Driver Verifier - jcgriff2.com
Regards. . .
jcgriff2
    HP dv7-1020us
    Intel P7350 Core2 Duo @2GHz
    4096mb DDR2 SDRAM
    NVIDIA GeForce 9600M GT
    IDT
    Fujitsu 320gb SATA HDD 5400RPM
    Logitech USB
    Intel 5100
Well gentlemen, I'm going to try that other site. I'll update you if/when a solution is found. Thanks for the effort and pointing me in the right direction.
We wish you luck.
