Intel E8400 Temp problem
Fingers crossed it works for you. Because running at those temps long term is really bad for the CPU :(
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Well it seems he Intel Speedstep is enabled, which would explain the CPU downclocking when it's idle.
As for the temps, he is using a stock cooler in a place that is generally hot. Having a warm room all the time won't help temps on the PC much. Better cooling will be needed in general.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Exactly. I read on Intel, they wrote 72.6c temperature. Mine is running at 69-70c. My mobo dosnt allow me to disable Speedstep :(. Intel DG43NB SUCKS :@
    Intel Core 2 Duo E8400 @ 3.0Ghz
    Intel DG43NB
    4GB OCZ DDR2 PC2-6400 Gold GX XTC Dual Channel
    XFX GeForce 8800GT Alpha Dog Edition
    Realtek HD
    LG Flatron M237WA
    500GB WD5000AAKS 7200RPM, 1TB WD10EARS 5400RPM
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
But not that hot ;)
Speedstep is not a bad thing. It only downclocks when when it's not under a heavy load.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
See guys, i only applied thermal paste. Only one outlet fan and stock cooler. wow my processor is not faulted
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
Much better :)
Now all you need is a new CPU cooler, add a couple of more case fans (one for input and another exhaust) and you'll be sorted :)
    ASUS Xonar DX
    100Mbps
It's still a little warm and I bet the temps rise to the 60-70 range under load, but that is a BIG improvement in comparison :D
Well done :)
Is it still lagging?
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Not at all lagging any more. Under load it reaches 50-55. I added a fan in front of case. When I'll get a little money, I'll buy a cooler master.
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
Good to hear mate :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
