Intel E8400 Temp problem
i cleaned my pc througly. See now. :) Improved right ;)
    Intel Core 2 Duo E8400 @ 3.0Ghz
    Intel DG43NB
    4GB OCZ DDR2 PC2-6400 Gold GX XTC Dual Channel
    XFX GeForce 8800GT Alpha Dog Edition
    Realtek HD
    LG Flatron M237WA
    500GB WD5000AAKS 7200RPM, 1TB WD10EARS 5400RPM
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
That is an improvement :) It seems to have fixed your sensors too as it no longer displays the temps as a minus.
Is your room generally warm as well? As ambient room temperature will always affect a PC's temp.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Yes bro my room is warm. If I turn on Air condition, i feel very cold. So i keep it off. I'll add more fans and better cpu cooling
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
My objective to to decrease temp to 45~50c.
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
Yeah, they are some crazy temps for idle...
Did you double check the cooler is attached properly?
Did you use thermal paste?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Yes I removed the cooler and then reinstalled. There was some thermal paste on the sink and also on the processor. I used brush to clean the dust as it was covering the whole processor (except its center).
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
Wait... you removed the cooler, brushed it and then put the cooler back without adding new paste? If so, there's your answer ;)
Each time you remove the cooler you really should clean the existing paste off and then re-apply a fresh lot. Especially if there is a chance that there is now dust in the paste.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Hmmm i'll do it today. :geek: for sure...
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
I noticed that your clock speed is just 1.99Ghz and the multiplier is 6. In the case of E8400 your cpu is underrated. out of the box the E8400 should be rated at around 2.4-2.8Ghz and with a multiplier 9. the temp problem of your E8400 is not caused by poor cooling system and even if you dont add any additonal fan the temp shouldnt be as high as it indicates but you need to take a look on the correct BIOS settings and check if you have the latest drivers. now, if you have all these correct settings and drivers the problem is with your E8400. your cpu is not located in the mohabi desert to have this kind of temperature you're "deep frying" your cpu actually. check if it is still under warranty.
hmm it is still under warrenty. Should I claim warrenty?
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
How long have you had it and long has it been running this hot?
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
hi,
and since it still under warranty you need to return your cpu (E8400) to the computer retailer for them to thoroughly check the cpu. because as for the present behavior of your cpu i can say it is "abnormal". in a room temp the E8400 would have a temp of 33-40C (with 6-8 hours of continous usage) and if you're using your airconditioning system the temp would normally play between 32-34C (6-8 hours of continous usage). here's another thing even if you overclock your cpu you wont get that kind of temp no matter how clean your pc is. in an overclock mode (without good cooling fan) the E8400 would normally play between 36-40C (6-8 hours of continous usage)
so better return your cpu to the computer retailer while it's under warranty.
hang on a sec. look wht i see on my desktop. I was playing this HD movie and my cpu reaches its max. 2.9ghz 9x multiplier
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
I dont remeber hmmm its like this from 3 week i think coz from 3weeks my games are laging.
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
Did you adjust the cooler about 3 weeks ago by any chance?
If it's multi x9 and 2.9 under load then it's not a BIOS setting as it's clocking normally. When games lag, do you actually know what the clock is running at?
Although as powevan8 mentioned, those temps are abnormal and if it's under warranty you should consider a replacement.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
No i adjust the cooler yestaday when my friends told me to recheck the cooler. After that games are not laging. Beforce when games where laging, the temp is high as 90-98c. Now its 75c. What you guys say about bios update? Any chance of improvement?
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
It really depends on what the actual cause is whether a BIOS update will help. Have you been adjusting anything in the BIOS?
It was lagging because it was throttling... has it lagged since new or only in the last 3 weeks?
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
No nothing i think but i'll make sure by checking bios settings again. No, when i bought it, it was not lagging at all. Since last 3 weeks, my brother start playing GTA4 (as i've exams i left), later he told me game is laging. First I ignored but later i went deep into this issue and posted a thread here.
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
Silly question, but has your brother been fiddling with things he shouldn't have?
Has he been adjusting things in the BIOS? ie Trying to overclock? (not that he would admit it anyway ;))
I'd double check your voltages are still where they should be.
Another silly question, is the CPU fan still working?
Can you remember what temps you had before it started to cook?
Assuming nothing has been touched and the CPU has for no apparent reason suddenly started to cook, I'd look at replacing it under warranty sooner rather than later.
I'd still re-apply the thermal past too if you haven't already done so and triple check the Heatsink is properly seated. It does sound like one of the pins is not pushed down properly and it's not fully making contact with the CPU.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Not at all, my brother is not going deep in these things. K first i'll apply the thermal paste again and recheck the fan connectors. If still it hot like this, then i'll try to replace the processor.
    Intel DG43NB
    Realtek HD
    LG Flatron M237WA
    Gigabyte
    Thermaltake
    Intel Stock
    Manhattan
    8192kb/s / 509kb/s
