hp recovery manager
Looks like the recovery discs are corrupt.
You can't start the recovery partition in the normal way since the mbr changed when trying to install XP.
Try this :
X:\sources>DISKPART
DISKPART> SELECT DISK 0
Disk 0 is now the selected disk.
DISKPART> SELECT PARTITION 2
Partition 2 is now the selected partition.
DISKPART>ACTIVE
Diskpart marked the current partition as active.
DISKPART> EXIT
Leaving DiskPart...
Then close command prompt and restart. Remove the cd before retarting, obviously.
If you are lucky you will boot into the recovery partition and you can recover from there.
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
siw 2 said he has another plan. me im juiced out. wait. have u chack ur disk for eror before?
    amd 64x2 4200+ 2.2ghz per core
    ECS NETTLE
    3 gb
    nvdia 6150se nforce 430(old rig, upgrading)
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    upgrading, Coolmax CA-450 450watts
    hp casing
    defult..
    hp
    hp
    768kbps down and 128 up...very slow..
    not great compared to other people..
fyi from be4 i chose partition 2 cuz it sed partition 2: primary size: 9gb offset: 102gb
and i figurted that was were my vista was cuz partition one had size 32gb and 32 kb offset lol
i saw this on amother post
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
oo ok guys new discovery, be4 wen i was doin it i musta got mixed up wit my partition 1 and 2 cuz i was usin 2 and readin off siw 2's notes but now i figured i'd try again
and wen i assign the letter c in partition 2
says diskpart has encountered an error: the directory is not empty. see the system event log for more info
i think i before i might have accidently assigned a diff partition as c, so i just made partition 2 assigned to letter h tryin again now, but if this fails siw 2 wat else can i do :S
Ah - you needed to select the partition Vista was on to apply all the commands in my previous post.
You can try it again , this time select the correct partition - the one that was 32gb.
X:\sources>DISKPART
DISKPART> SELECT PARTITION 1
Partition 1 is now the selected partition.
DISKPART> DELETE PARTITION
DiskPart successfully deleted the selected partition.
DISKPART> CREATE PARTITION PRIMARY
DiskPart succeeded in creating the specified partition.
DISKPART>ACTIVE
DISKPART> ASSIGN LETTER=C
DiskPart successfully assigned the drive letter or mount point.
DISKPART> FORMAT FS=NTFS QUICK
100 percent completed
DiskPart successfully formatted the volume.
DISKPART> EXIT
Leaving DiskPart...
X:\sources>bootrec.exe /fixmbr
Should get a message saying it was successful.
Then try using the HP discs.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
um i think i did do that cuz i tried again lol, but i'll give it another go, but if this does fail again wat do i do, cuz i noe each day u have to go around this time and wont be bak til nxt day
u have a underscore . at the top corner. i have the same. but it goes to the boot menue
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
Hi kiddieboy,
The underscore stays there because the machine can't find a bootable device.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Check it is right by typing
X:\sources>DISKPART
DISKPART> LIST VOLUME
It should show the largest partition as Volume 1 NTFS and it should also be the active (System ) partition.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
umm my volume one is a removable type wit 0b no media o_O
vol 2 letter c is my biggest wit 102gb as a ntfs partition
vol3 is next largest wit 9gb and labelled presario_RP also ntfs partition
so am i meant to change my volume 1 the removeable to a diff volume and make my main one thats 102gb to volume 1 or sumfing?"
