hp recovery manager
wait so 20gb is for vista. so u have xp before. and dont u have a recovery partion?
    amd 64x2 4200+ 2.2ghz per core
    ECS NETTLE
    3 gb
    nvdia 6150se nforce 430(old rig, upgrading)
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    upgrading, Coolmax CA-450 450watts
    hp casing
    defult..
    hp
    hp
    768kbps down and 128 up...very slow..
    not great compared to other people..
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
sighz pls read on the previous posts i really cbf explainning again... my comp is a compaq presario c700... and my comp was orginally installed wit vista basic... only software i've plugged into my comp recently is xp reformatt disc which failed...
ok. then answer . do u have a recovery disk pation?
and r u using another pc to answer these question. ?
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
yes i am usin another pc to answer these and yes i do have a recovery disk patition. if u used just a few mins of ur life to "browse" or even skim through the other 6 pages of this topic im sure most of ur answers wud be there, instead of just asking me and makin me repeat myself T_T imo
i am doing that. but unfortuanatly i dont really understand everything u say.
this is kinda hopeless. but im no quitter
so u have tried
recovery disk----no go
recovery disk from torrent---no go
f11 in system reovery----no go
try to install xp on another partion---no go
it seems to be atta my control.
also u have no warrenty
let me ask. create a new thread. and put the link here. it is very confsing.
list ur detail. specs
then put ut partion list
like this (exp)
partion 1 300gb (what it is. exp is vista os)
partion 2 50gb (what it is)
partion 3 20gb (what it is)
then put the new thread link to here. so we an link it. it is getting very confusing.
also dont just use one forum. go to more than one forum. look on google
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
ye i fink i'll just wait for siw2 to come bak, seein as how he was one whos bein guiding me all this time. i have posted on other forums as well but this one has been most effective hence y i stick wit this now. so ye thx for helpin but ye i fink siw2 noes my case pretty well and he noes wat hes doin so i fink if he cant help me not really anyone can lol
kk. if siw 2 cant help call brink. he's admin
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
ye siw2 im just ganna repost it here so that its easier to see instead of flippin bak and forth pages...
alright this is wat it says
volume ### Ltr Label fs type size status info
volume 0 F removeable 0b No Media
volume 1 E 2007.11.03_ UDF DVD-ROM 121 MB Healthy
volume 2 C NTFS PARTITION 32 GB Healthy
volume 3 D PRESARIO_RP NTFS PARTITION 9 GB Healthy
thats wat it says. now after readin this... does this mean i only have like wat 40gb worth of hardisc or sum ****... Cuz orginally before this whole thing happened and i cudnt boot comp, i had 120gb worth of space zzz
Don't worry , your drive hasn't shrunk - that happened because you tried to install XP.
It isn't reading the full capacity. At least it can see the volumes , so there probably isn't any serious HD damage.
1. Is there anything on there you need to keep?
2. Do you have a product key that came with the machine - usually on a sticker on the case ( just in case you need it )
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
oh good thats good to hear :) ur the bomb lol
ye i dunt need nefing on der really and im at skool atm so dunno if my laptop has the product key der i'll let u noe afta.but if i get rid of everything will my dvd drive and things still work if we modify etc if i can still operate everything fine after if sumfing is altered im fine with it
Hi Chikara,
We are going to try to get your HD into a condition that your HP recovery discs will work on.
You need to be sure you are selecting the correct drive and partition.
I assume you only have one hd and what was your Vista partition is partition 1. If not, use the number that relates to your Vista partition ( make sure, because it was listed as volume 2 on the previous page ).
Unplug any other drives you have attached before you start.
To make certain , I have given the complete list of commands.
Boot the Vista recovery cd you made to get to the command prompt and try this : ( press Enter after each command )
X:\sources>DISKPART
Microsoft DiskPart version 6.0.6001
Copyright (C) 1999-2007 Microsoft Corporation.
On computer: PC-PC
DISKPART> LIST DISK
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 149 GB 0 B
DISKPART> SELECT DISK 0
Disk 0 is now the selected disk.
DISKPART> LIST PARTITION
Partition ### Type Size Offset
Partition 1 Primary 30 GB 1024 KB
Partition 2 Primary 25 GB 30 GB
Partition 3 Primary 23 GB 55 GB
Partition 0 Extended 71 GB 78 GB
Partition 4 Logical 40 GB 78 GB
Partition 5 Logical 31 GB 119 GB
DISKPART> SELECT PARTITION 1
Partition 1 is now the selected partition.
DISKPART> DELETE PARTITION
DiskPart successfully deleted the selected partition.
DISKPART> CREATE PARTITION PRIMARY
DiskPart succeeded in creating the specified partition.
DISKPART>ACTIVE
Diskpart marked the current partition as active.
DISKPART> ASSIGN LETTER=C
DiskPart successfully assigned the drive letter or mount point.
DISKPART> FORMAT FS=NTFS QUICK
100 percent completed
DiskPart successfully formatted the volume.
DISKPART> EXIT
Leaving DiskPart...
X:\sources>bootrec.exe /fixmbr
Then close command prompt, remove Vista recovery cd and then try using your HP recovery discs.
Hope it helps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Hi Chikara,
If you are able to use the HP restore discs after the DiskPart commands, then you won't need to use that product key.
If you still can't use the HP discs, then we have another solution.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
hey siw 2 what vista guru?
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
aiight mate i've done those steps im just ganna talk to u along the way to keep u informed lol. if this works man, ur and absolute legend :)
edit: comp has rebooted and is loadin the hp recovery discs
mates..are u from britan?
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
