How to get an animated forum avatar?
Hi kavita,
Right-click on the image and select Save Picture As... Use the default name, and choose where you want to save it. Now edit your avatar, and point it to the file that you have just saved.
did exactly what you said. saved this image on desktop and chose this image as an avatar, its not working. I think this avatar is not worth it. Dwarf could you please search for an animated avatar of a superwoman or something like that which fits properly as an avatar for me?
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
That's strange. I changed mine to this avatar temporarily using the method I described to check and, as you can see, it is animated. Try again, making sure that you don't accidentally change the file extension by mistake.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Tried thrice. not working.
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
This is confusing. :confused:
When you double click the file that you have saved, does it animate?
    Gigabyte IF233
Yes it opens up in IE 8 and it animates well. thats what i dont understand. if it animates well in IE, why wont it animate when selected as an avatar?
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Try uploading the image as a normal attachment to your next post.
    Gigabyte IF233
I bet you've got a headache now Dwarf :devil:
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
This ain't Super Woman, but here's one for you!
Later ;) Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Something strange is going on here, Dwarf and Delphin have the same avatars and now Kavita wants this one, too. :shock:
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
Too right :sarc:
As I mentioned earlier in this thread, this is only a temporary measure. My blue mouse will be back.
    Gigabyte IF233
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
He's back !!! :D
Just in case anyone is wondering who or what he is running away from, it is my little friend over on Se7en Forums.
    Gigabyte IF233
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
Im sorry i had gone for some work. Ok here is the original image :
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
