How to get an animated forum avatar?
Frankly, I'm getting a little bit dizzy with her dancing around. ;) Longer I look
at her, she's dancing faster and faster. :shock:
I was thinking how to slow her down a little, but I've got no idea how to do it.
Anyway I still like her dance, really. :D :party:
Just let me know when you got enough this gambol.
Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
Cheers...
Not to difficult with the right software ;)
50% slower ;)
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
Yea, you are right, but I don't have idea what application to use. Will have to google, I think. I got the Easy GIF Animator so will try to make special avatar in the future. The present one is OK-ish for now.
Cheers...
Add... thank you Barman for help, thanks to you i just slow down my avatar a little.
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
LOL. Thanks Martee. But yours is the Best.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
What about her View attachment 11835 ? :D The avatar is serious matter :shock:
Well, from the distance...looks even better than the present one. Yea, she's :cool: will swap her I guess.
Cheers...
Its up to you, I like the first one better though :p
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Right Pooch...Thank you very much. I do appreciate you opinion. :D
Cheers...
p.s. Maybe some day I'll swap them.
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
My avatar is a .gif image. Its not moving though. Any idea?
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Check File size and dimensions if the file is larger than the specification in the change avatar screen the avatar will not animate
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
its 98x81. size is 131KB.
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Hi kavita,
Try copying this:
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Hi Dwarf, thanks for letting me know about it. Or else i would have started banging my head as i was not getting why its not working. i will look for some other avatars.
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Hi kavita,
Was that referring to my last post, which I deleted and replaced with the one showing your avatar? If so, you probably caught it before I edited it. If you copy this image, you should find that it will work as your avatar.
    Gigabyte IF233
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Hi kavita,
Right-click on the image and select Save Picture As... Use the default name, and choose where you want to save it. Now edit your avatar, and point it to the file that you have just saved.
    Gigabyte IF233
