niemiro
Banned
Hello,
If you would like, we could start a Sourceforge project, though I am very happy to keep working here. It is entirely your decision.
Richard
There is never any rush. In your own time.I can't give you a fixed date because translation to French/German not started yet.
By the end of this week, both Traditional and Simplied Chinese.
Sorry, I confused you. When I said "Now", I meant that I am doing it now, but it is not finished.WonderfulMake it look nice << Now
Fix bug where half of title will be removed on December 31st. << Fixed
Make sure those extra files do not appear << I think fixed, can you confirm?
You can test them from any folder, Desktop, Downloads, Documents etc. You originally talked about three strange files with the extensions: .reloc, .rsrc, .text. I do not know exactly what these files are, but it is now compiled in Release mode, so they should not reappear. Test in the same way as you originally found these files.Please advise how to test the files on Vista. On which folder shall I save them? Thanks
SensibleAll files exchanged are dated.
Just one quick question, do you want month or day first? I can do either, and it is not very clear with 04/04 !? I assume month first because you said Apr/04.They indicate the file sent from you to me on Apr 04, 2010Code:linbread_20100404_r.dat Verse_of_the_Day_20100404_r.exe
With the .dat files, I strongly agree. However, I though that there would be one .exe with all the languages in it. How would you like it done, multiple .exes or one .exe?Code:linbread_zh.dat (traditional Chinese) linbread_cn.dat (simplified Chinese) linbread_fr.dat (French) linbread_de.dat (German) etc
date and name to be added after country.Code:Verse_of_the_Day_zh.exe Verse_of_the_Day_cn.exe Verse_of_the_Day_fr.exe Verse_of_the_Day_de.exe
Richard
- Dell XPS 420
- Intel Core 2 Quad Q9300 2.50GHz
- Stock Dell 0TP406
- 4 gb (DDR2 800) 400MHz
- ATI Radeon HD 3870 (512 MBytes)
- Onboard
- 1 x Dell 2007FP and 1 x (old) Sonic flat screen
- 1600 x 1200 and 1280 x 1204
- 1 x 640Gb (SATA 300) Western Digital: WDC WD6400AAKS-75A7B0 1 x 1Tb (SATA 600) Western Digital: Caviar Black, SATA 6GB/S, 64Mb cache, 8ms Western Digital: WDC WD1002FAEX-00Z3A0 ATA Device
- PSU
- Stock PSU - 375W
- Case
- Dell XPS 420
- Cooling
- Stock Fan
- Advent Optical ADE-WG01 (colour change light up)
- Dell Bluetooth
- 120 kb/s
- Other Info
- ASUS USB 3.0 5Gbps/SATA 6Gbps - PCI-Express Combo Controller Card (U3S6)
