How do i reset my video card?
And by the way when i got that crash, Asynchronous flip was activated (ON)
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Can you PLEASE tell us what you have done so far to try and fix this.
Thank you,
Derek
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
Everything and nothing worked.
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Everything?
    Asrock P67 Extreme4
    auria eq2367
Yes, everything. Is the second time i repeat.
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Well if you've tried everything I don't know what else I can add, Sorry.
    Asrock P67 Extreme4
    auria eq2367
Ok. No thanks from me.
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
    Asrock P67 Extreme4
    auria eq2367
You waste precious time. I tried memory test and told me that no errors found. If you could tell me, i think you don't know, how to repair or reset my video card to default condition you get a reputation from me, if not, i leave this forum.
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Well you said you tried EVERYTHING, so what else could I suggest.
I don't know why you think I've wasted precious time, I'm just trying to help you out and I don't care about the rep I actually get more satisfaction from solving a problem. Obviously that didn't happen in this case, I don't know what else I can do and I certainly don't want to waste any more of your precious time, Maybe someone else can tell you what you want to hear.
    Asrock P67 Extreme4
    auria eq2367
Ok here what i've tried: Reinstalling video card
Video Test (no errors found)
Reset to default
Change resolution
VGA
none worked. what else can i try ?
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Come on i don't say you waste time, i was a bit nervous. So again i repeat, there is no way to repair my video card? I did a fresh install of vista, and that didn't change something at all. Is video card problem, is not windows problem because that happens in boot menu too. So i hope you come back and you find a solution related to my problem.
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
Do you have an external monitor you can hook up to your notebook? That might narrow it down if it does the same thing on a different display.
    Asrock P67 Extreme4
    auria eq2367
I don't have an external monitor :(
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
I have an Intel 965 chipset. Never encountered anything like this...
Try contacting intel Customer support. I thinkt hey can help you more than anyone here. Sorry this had to happen to you, computer problems REALLY suck.
ADD: Are you just concerned about the bubbles that have come up onto the desktop? The one that said "click here for optimal resolution" ? Mine does this too, and it means nothing, it's just a retarded Intel glitch. I noticed that you have your Windows in Basic.
To enable the Aero Transparency, right click Personalize > Windows color > "Check" Enable transparency.
And if your Vista works, just go back to that. I noticed on your Windows 7 it said "Windows 7 Build 7100, Evaluation copy" which is the Release Candidate for Windows 7. This version has already started it's bi-hourly shutdown phase, and on June 1st it will be disabled and considered "Pirated" if you still run it on a computer.
If you need any more help, don't hesitate to ask.
LINKS:
1 Customer Support Contact Information
2 Intel Corporation - Welcome to E-mail Support
    AMD
    ATI
Cooking my video card in oven; is it good ?
    HP 530
    Intel
    121 GB
    Intel
    1280X780
    Serioux
I lol at this thread. If you really want to stick to your computer you might have to get a new graphics card (if u have a desktop). Have you tried setting your resolution to the max? Have you tried changing the monitor settings instead of the gpu's?
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
Confirm Download
click this blue writing above and install it
this will make your graphics work
secondly, i can see you are using a beta build, the windows 7 beta will shut down every 2 hours as of march 1st, the background will change to a solid colour and the resolution cannot be changed from the safe mode resolution, you need to buy windows 7 to stop this happening, or switch back to vista!
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
