Solved Hjt logs?
Same issue happens under 32/64bit or IE8 with the link that you posted. Do I need to reinstall IE8?
    ME
    Intel Core 2 Duo 2.40Ghz L2 FSB 1066Mhz
    Gigabyte GA965P DQ6 Rev 1 F11
    Geil PC6400 800Mhz 4GB Dual Channel Ram
    GIGABYTE GTX260
    Creative Sound Blaster XI Gamer Sound Card,
    Seagate 250Gb SATA 11, Samsung 400GB SATA
    Corsair 620W HX Series Modular
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
This is similiar to the Hijack This -
It will scan and save a detailed log, and tell you If you have issues
ESET SysInspector
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
No- It is doing it to me too. Its IE8 or the add-on scanner is not yet compatable with this version of IE.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Ok do I need to post this?
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Is there anyway to paste it as one file or do I need to go through each one and do a screen shoot?
does this collect any personal information?
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
No personal info
At top right click "file", and "save log" you can also use it to save multiple logs and compare.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Ok I have attached this.
With regards to IE8 Are you unable to access both the ESEST Sites that you posted and get the same error with IE8 as I do? and the same with the online scanner.
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
The second is the download site. Its just the scanner that I get the add-on error in IE8-evidently it is not designed for IE8 yet.
As for your log-it is difficult to read- What does the inspector itself say when you scroll through it? It should should give you a self diagnostic staus of the individual components.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
oK that's odd I get the error on both of them sites. The system inspector seems to be ok, its not reporting any certial things its got a few errors in the registry, thats about it really.
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
Ok goo news I rolled back to IE7 and ran an online scan at ESET and it passed without any infections. :)
Thank you again for your help. I'll give you some rep now.
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
