Everything that you did to the computer will be gone; all your games, pictures, files, settings, favorites, everything
Then we reintall. The actual computer is old cannot fix that, but Windows will be like new.
You could put your stuff on a hard drive or CD, but hard drive is best. You can use a finger drive, that is what I did.
For programs like games, you need the install DVD and maybe the key number. If you downloaded from the net you have to download again.
If I were you, this is what I would do
Read the tutorial qucickly
Then go to You Tube and search for something like "Install Vista"
Then go back and look at the tutorial, again. You should understand it better.
Then you have to decide. Want to work together or do you want to bring it to a shop.
Just remember one thing, if you cant do it, no harm done, just bring to the shop then. It will cost the same.
- Dell XPS420
- 6 gig
- ATI Radeon HD3650 256 MB
- Intergrated 7.1 Channel Audio
- Dell SP2009W 20 inch Flat Panel w Webcam
- 640 gb
- Cooling
- Fan
- Dell USB 4 button optical
- Dell USB
- Other Info
- DSL provided by ATT
