Hard drive speed boosts
How to Increase Hard Drive Performance in Vista
This will show you how to increase the hard drive performance by enabling Advanced Performance, disabling NTFS from creating 8.3 versions of file names, and defragging on a regular schedule.
You can follow all the steps below, or just pick the ones you would like to do.
STEP ONE
Enable Advanced Performance for Hard Drive
This option enables extremely aggressive write caching that will speed up the hard drive's performance, but it can also cause you to lose data in the drive's cache if you lose power suddenly. It is not recommended for laptops that run on battery power all the time. While this is fine for the normal home desktop, it may not be a good idea if you have unreliable power.
This may not be supported by some hard drive setups (Ex: RAID). If it does not, then you will see that it will just change back to the default settings automatically when you look at the Properties again.
2. Click on the Device Manager icon.​
4. Close the Control Panel.​
5. Click on Disk drives to expand it. (See screenshot below)​
6. Right click on your hard drive device listing and click Properties.​
7. Click on the Policies tab. (See screenshots below)​
8. For a ATA (Parallel) or Serial ATA (SATA) Hard Drive
A) Check the Enable write caching on the disk box. (See left screenshot below step 10)​
NOTE: This should already be checked by default.​
B) Check the Enable Advanced performance box.​
NOTE: If this will not stay checked for you, then check to make sure that you have the latest chipset drivers installed for your motherboard. Also see: Write-Caching - Enable or Disable - Windows 7 Forums
9. For an External Hard Drive
A) Dot Optimize for performance. (See right screenshot below step 10)​
10. Click on OK to apply.​
STEP TWO
Disable NTFS from Creating 8.3 Versions of File Names for Backwards Compatiblity with DOS
NOTE: You will not need this unless you work with DOS or the command prompt and have long file names.
1. Open the Start Menu.​
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Filesystem
5. In the right pane, right click on NtfsDisable8dot3NameCreation and click on Modify.​
6. Type 1 and click on OK. (See screenshow below)​
NOTE: To enable it again, type 0 (number) instead.
7. Close regedit.​
STEP THREE
Defrag the Hard Drive on a Regular Schedule
1. If you use Vista's Disk Defragmenter, see the link below on how to create a automatic defrag schedule.​
2. If you do not like Vista's Disk Defragmenter, you can use a 3rd party program instead. Auslogics Disk Defrag is a great program that has a status graph of the hard drive's defragmentation progress, but the free version does not have a automatic defrag schedule. Here is the link:​
3. Here is a recommended schedule of times to defrag.​
NOTE: The more you save and delete items off your hard drive, the more often you should defrag. Adjust to your needs.
Scheduled Time
[/TD]
[TD]
Description
[/TD][/TR]
[TR][TD]
Once a Month
[/TD]
[TD]
For a user that is only on the computer a few hours a week and does not do much file saving and deleting. You rarely install and uninstall programs.
[/TD][/TR]
[TR][TD]
Once a Week
[/TD]
[TD]
For most average users that use the computer for a few hours on a daily basis and does a lot more file saving and deleting. You only do a few installing and uninstalling of programs.
[/TD][/TR]
[TR][TD]
Once a Day
[/TD]
[TD]
For your power user that uses the computer for several hours a day and does an unbelievable amount of file saving and deleting. You do a lot of installing and uninstalling of programs.
[/TD][/TR][/TABLE]
Enjoy faster performance,
From the resource monitor at a certain point it's hard to tell because the background operations are changing back and forth. I used the Auslogics defrag program and it stated that my PC is not optimized although the elaboration wasn't provided.
After a period of the time the programs in the background disappear and it does seem to run smoothly but whatever I may engage their seems to be some sort of hesitation from the hard drive and that's what I don't understand. I've never witnessed this before on a 500GB and Vista absolutely operated smoothly regardless of the performance tweaks.
Do you think it's got something to do now with the firmware?
    i7 965
    Asus Rampage II Extreme
    Corsair TR3X6G1333C9 x 2
    Gigabyte GTX295 SLI
    SB X-Fi MB
    Samsung Syncmaster T240
    1900x1200
    2x1TB Western Digital Black (Raid 0), 150GB WD Raptor
    1200W Thermaltake Toughpower
    Lian Li PC80P
    Chassis - 3 Front 140mm, Top 140mm, Rear 140mm
    Logitech MX Revolution
    Fold up beast by me :-)
When enabling advanced performance for hard drive and a poer outage happens, will this just randomly loss or corrupt files on your hard drive or files that are open when it happens?
    Toshiba Satellite A215-S4757
    2048MB DDR2 SDRAM
    ATI Radeon® X1200 128MB-319MB
    15.4” diagonal widescreen TruBrite®TFT LCD display at 1280x800 native resolution (WXGA)
    250GB (4200RPM); Serial ATA hard disk drive
Hello Shortmantuff,
Only if it was in the middle of being saved to the hard drive, otherwise you would just loose whatever that was in the cache. It's usually not a problem though unless you have a lot of power outages though.
Never knew about this, thanks!
    Intel i7 920
    Intel DX58SO
    6GB PC3 12800 DDR3
    Asus 9800GTX+ 512MB
    AOC 917Vx
    1 TB Western Digital Cavair Black 320GB Seagate Barracuda 250GB Western Digital My Passport
    Antec EA650 650W ATX12V
    Antec Nine Hundred Black Steel ATX Mid Tower
    20MB down / 5MB up (Fios)
You're welcome Microdude. :)
Thank you Brink. I didn't come across either setting when I was speeding up my hard drive the first time around.
The new release of Auslogics Disk Defrag is impressive. But I do worry if the increased speed is at the cost of effectiveness.
    Dell Dimension 9200
    Intel Core 2 Duo 2.66 GHz
    2.00 GB
    Nvidia 8600 GTS (Overclocked)
    Dell 2007 WFP 27 in LCD
    1680 x 1050
    One (72.8/455 GB)
    Razer Salmosa
    Standard Dell Keyboard (Dusty)
Ditto. It's insanely fast, but hope it doesn't effect it.
    2048MB DDR2 SDRAM
my reboot time was 325seconds, just by turning this on it has gone down to 241seconds. will carry on tweeking, many thanks
    dell inspiron 1520
    Intel core 2 duo T5250 @ 1.50GHz
    Intel GM965
    integrated Intel GMA X3100
    Panasonic TX-P50V10B (50")
    Fujitsu MHW2080BH ATA 80GB 5400RPM
    laptop
    wireless
    wireless
    14MB
Hey Shawn, your links broken:
Brink said:
8. For a ATA (Parallel) or Serial ATA (SATA) Hard Drive -
NOTE: If this will not stay checked for you, then check to make sure that you have the latest chipset drivers installed for your motherboard. Also see: How to Fix Can't Enable Hard Drive Advanced Write Caching in Vista
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Thank you Tom. Link substituted for another one. :)
Good tutorial.
    HTPC/Desktop PC/Gateway LT2104u
    Intel Pentium 4 2.8Ghz with HT/3.0Ghz with HT/Atom N450
    GIGABYTE GA-81915ME-C/Intel D865GBF/Acer LT21
    2x1GB DDR 400Mhz/512x2GB DDR 400Mhz/1GB DDR2-800Mhz
    ECS 9800GT 512 DDR3/ Sapphire HD3650 AGP 8x 512MB/Intel 3150
    Turtle Beach RIVERIA 5.1 SPDIF Out/SoundMAX AD1985/Realtek H
    SONY BRAVIA KLV-32V300A V-Series/ KLV-19T400A/ Built-in
    1920x1080/1980x1080/1024x600
    MAXTOR 40GB WD ESSENTIAL EDITION 1TB USB Hitachi HDT721010SLA360 1TB SATA 150/ 250GB Toshiba
    OCZ Fatal1ty 550W/
    Lian-Li v351, Lancool K-62 DragonLord
    Logitech Combo
    Logitech Combo
    512 Kbps
Thank you Hari. I'm glad that you liked it. :)
Ok I have a couple questions. First, for #1 does "data loss" refer to files and open programs you're working with? Or does it also apply to operating files and the like, that could mess up your computer if power is lost? I ask because it seems like something I want to do, but I've been having an odd issue lately where my computer has a unique freeze up (I still have a thread started about it if anyone wants to take a look. It's one of two that I've made so it should be easy to find by clicking my user name or whatever). Anyway, I haven't figured it out yet but it could be HD related, so if this tweak will potentially cause OS instability when power is lost I'd like to know.
Second, could someone clarify the NOTE on step two? I use the cmd prompt sometimes (not heavily though) so I'd like to know exactly how it'll affect the use of that, it wasn't very clear. Thanks for the great guide though!
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Touchpad, + Logitech wireless mouse (USB)
    Built in
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
Hello Adam,
For #1, it's not going to affect the stability of Vista. It's referring to whatever data happens to be in the write cache before it is finished actually written to the HDD if you were to lose power or freeze up. Of course, this would be the case for anything that's not saved anyway.
If you use really long file names (ex: 25+ characters or more) and use them in DOS, then you wouldn't want to do STEP TWO. The link below can help give you more details about the purpose of the 8.3 file name format to help decide if you really needed it or not. If not, then turning it off can help Vista gain a tiny bit of performance by not having to convert long file names for the 8.3 format.
8.3 filename - Wikipedia, the free encyclopedia
Ok thanks. Definitely going to do the first one then. Won't make a bit of difference in my situation. And I think I'll go for step two as well, and just revert it if for some reason I need to. One last thing: I tried it several years back on an mp3 player that wouldn't work (I had no idea what it did at the time and I was just desperately trying things) and it pretty much rendered it useless. And halved it's capacity. Ever since then I've been pretty weary of the built-in defrag system. So how stable is the defrag? How resource intensive is it? How long will it take? (300 gig) Is there anything I should be worried about when using it? Anything to avoid? Thanks :)
    Dell Inspiron 1545
    1366x768
    Single built in fan
    Built in
The built-in defrag feature of Vista is good, but it's slow. You might consider using the free program Auslogics Disk Defrag if you find it to slow. :)
Ok. I'll try to build up the courage to use it sometime. I tried Smart Defrag, but I was trying to use it to consolidate all the free space at the end of my drive so that I could have enough free space there to make another partition, but it didn't work. Then I tried another one (I can't remember the name of it) but it had a very similar interface and took literally two hours to do 2% of my drive so I just ditched the idea. But I'll give it a whirl and see how it goes. Can you give me an estimate for how long it should take ish? Thanks!
Oh. It said that with less than 10% free space it reduces performance. That might be why I've had bad experiences with defraging in the past.
    Dell Inspiron 1545
    1366x768
    Single built in fan
    Built in
Sorry, but there's no way for me to know how long it will take to defrag it on your computer. :(
