Hard drive speed boosts
How to Increase Hard Drive Performance in Vista
This will show you how to increase the hard drive performance by enabling Advanced Performance, disabling NTFS from creating 8.3 versions of file names, and defragging on a regular schedule.
You can follow all the steps below, or just pick the ones you would like to do.
STEP ONE
Enable Advanced Performance for Hard Drive
This option enables extremely aggressive write caching that will speed up the hard drive's performance, but it can also cause you to lose data in the drive's cache if you lose power suddenly. It is not recommended for laptops that run on battery power all the time. While this is fine for the normal home desktop, it may not be a good idea if you have unreliable power.
This may not be supported by some hard drive setups (Ex: RAID). If it does not, then you will see that it will just change back to the default settings automatically when you look at the Properties again.
2. Click on the Device Manager icon.​
4. Close the Control Panel.​
5. Click on Disk drives to expand it. (See screenshot below)​
6. Right click on your hard drive device listing and click Properties.​
7. Click on the Policies tab. (See screenshots below)​
8. For a ATA (Parallel) or Serial ATA (SATA) Hard Drive
A) Check the Enable write caching on the disk box. (See left screenshot below step 10)​
NOTE: This should already be checked by default.​
B) Check the Enable Advanced performance box.​
NOTE: If this will not stay checked for you, then check to make sure that you have the latest chipset drivers installed for your motherboard. Also see: Write-Caching - Enable or Disable - Windows 7 Forums
9. For an External Hard Drive
A) Dot Optimize for performance. (See right screenshot below step 10)​
10. Click on OK to apply.​
STEP TWO
Disable NTFS from Creating 8.3 Versions of File Names for Backwards Compatiblity with DOS
NOTE: You will not need this unless you work with DOS or the command prompt and have long file names.
1. Open the Start Menu.​
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Filesystem
5. In the right pane, right click on NtfsDisable8dot3NameCreation and click on Modify.​
6. Type 1 and click on OK. (See screenshow below)​
NOTE: To enable it again, type 0 (number) instead.
7. Close regedit.​
STEP THREE
Defrag the Hard Drive on a Regular Schedule
1. If you use Vista's Disk Defragmenter, see the link below on how to create a automatic defrag schedule.​
2. If you do not like Vista's Disk Defragmenter, you can use a 3rd party program instead. Auslogics Disk Defrag is a great program that has a status graph of the hard drive's defragmentation progress, but the free version does not have a automatic defrag schedule. Here is the link:​
3. Here is a recommended schedule of times to defrag.​
NOTE: The more you save and delete items off your hard drive, the more often you should defrag. Adjust to your needs.
Scheduled Time
[/TD]
[TD]
Description
[/TD][/TR]
[TR][TD]
Once a Month
[/TD]
[TD]
For a user that is only on the computer a few hours a week and does not do much file saving and deleting. You rarely install and uninstall programs.
[/TD][/TR]
[TR][TD]
Once a Week
[/TD]
[TD]
For most average users that use the computer for a few hours on a daily basis and does a lot more file saving and deleting. You only do a few installing and uninstalling of programs.
[/TD][/TR]
[TR][TD]
Once a Day
[/TD]
[TD]
For your power user that uses the computer for several hours a day and does an unbelievable amount of file saving and deleting. You do a lot of installing and uninstalling of programs.
[/TD][/TR][/TABLE]
Enjoy faster performance,
That's ok. Thank you for sharing this. :)
Enjoy your vacation, :party:
I just purchased a desktop computer with a Solid State Drive (SSD). The manufacture states not to run disk defragmentation, It may decrease the lifespan of the drive.
Will the steps you list here on boosting hard drive speeds work on my solid state drive?
    Intel QX9770 Quad Core
    Asus P5E3 Premium/Wifi AP
    2 x OCZ DDR3-1333 Reaper 2048MB w/ Heatpipe Cooling
    Asus GeForce 8800GT 512MB
    OCZ Core Series 128GB SATA II 2.5 inch SSD
Hello Goldwing2001, and welcome to Vista Forums.
To be honest, I do not know since it is so new right now. :o
Since SSD drives use memory chips instead of a hard drive using a spinning platter with only a small amount of memory for a cache, I do not think it will make much if any difference. I'm not even sure if a SSD drive has these options.
For now, all I can say is follow any recommendations made by the manufacturer of the SSD drive. If your curious, I suppose that it would be ok to try it for a short time to see if it helps any or not.
Wish I knew more about them to help you better.
I'm not sure what the Sandisk guy is talking about. This is kind of funny don't you think:
http://www.sandisk.com/Corporate/PressRoom/PressReleases/PressRelease.aspx?ID=3785
"The results indicate that the new Windows Vista operating system will run optimally when installed on the SanDisk SSD."
I think what you are seeing here is Sandisk blaming their poor performance on the OS instead of their own drive.
The OCZ SSD drive in my system is working great with Vista. I think it's the best and fastest SSD drive currently on the market.
http://www.tomshardware.com/reviews/ssd-hard-drive,1968-4.html
"The drive is based on Samsung’s current SLC Flash SSD and a modern second-gen SATA interface. We already mentioned the better energy efficiency attributes of a native interface, but the test results are truly enlightening. What the OCZ SATA IISerial ATA - Wikipedia, the free encyclopedia 2.5” SSD is able to do beats everything else — both the Flash SSDs and all of the mechanical hard drives."
Nice guide mate I've seen many guides but you're guides are easy to understand and you do display information of what are we trying to do and what is it for and the most important thing WARNING us about the risks that might happen. Thanks!
    Q6600 OCed till 3.3Ghz
    Nvidia XFX nForce 780i SLI
    2X2GB Corsair DDR2 800Mhz OCed @ 820Mhz
    2xNvidia 9500 GT SLI OCed @ 730Mhz each.
    Motherboard Built in
    Acer 22' LCD + 18.5 Wide Samsung LCD
    Internal 2x250 GB SATA II Maxtor, External 500GB SATA WD,
    600Watts
    GIGABYTE
    GIGABYTE Volar CPU Cooler
    Prestigio
    Samsung Pleomax
    2Mbps
On Step One, It is said that if you enable advanced performance for HD, it may cause you to lose data in the drive's cache if you lose power suddenly.
Now, by "suddenly" you mean sudden power failure, like hit by lightening or breaker down? Does it exclude simply forgetting to plug in and the battery
dies down slowly? Or even this would cause data loss?
Cheers, Tomo
Cheers, Tomo
Hi Tomo,
Missing from the documentation is the reality that even without this setting enabled, a sudden power failure will result in the loss of data. Anything you have not saved, either way, will be gone. That warning wasn't meant so much for us home users, but rather the corporate environment. You'll be fine using this tweak... I noticed big improvements when combined with the other optimizations in this section.
Having said that, everyone should invest in a good UPS... because tweak or no tweak, power outages happen.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Cheers, Tomo
You can set your computer to shutdown safely if it detects low battery power which would stop dataloss from this.
    Hewlett Packard
    3.40Ghz / 2.20Gz Duo Core
    2GB / 3GB
    160 GB / 160 GB
continuing the topic of high performance and data loss,
How can I set my PC to shut down safely keeping data when there is not enough battery?
Or is it normally already set like that by default?
Tomoedinburgh,
I do not run with battery power so I do not have the exact procedure for you, but under Power Options, Change plan settings, and the Change advanced power settings link these are the options that you would change to what you want the computer to do when the battery gets down to a certain point that you decide is low:
  • [SIZE=-1]Battery/Critical Battery Action This option specifies the action Windows Visa should take when the battery reaches the level specified in the following option. It can be set to Sleep, Hibernate, Shutdown, and when plugged in to Do Nothing.[/SIZE]
  • [SIZE=-1]Battery/Critical Battery Level This option specifies the percentage of remaining battery power that is considered critical.[/SIZE]
  • [SIZE=-1]Battery/Low Battery Level This option specifies the percentage of remaining battery power that is considered low.[/SIZE]
  • [SIZE=-1]Battery/Low Battery Action This option specifies the action Windows Visa should take when the battery reaches the level specified in the above option. It can be set to Sleep, Hibernate, Shutdown, and Do Nothing.[/SIZE]
  • [SIZE=-1]Battery/Low Battery Notification This option can be set to On or Off to specify whether Windows Vista should popup a notification when the batter reaches the ‘low' level. [/SIZE]
Thank you for the reply and I will definitely check into the off-mode options to
safeguard my work in progress.
However, I would like to ask, does this high performance option really
does its job if if I click? I burnt a CD today and there was no noticeable improvement. Does it really make a difference?
High performance can make a difference with most items running on the computer. You usually do not notice much difference though until you start running a lot more on the computer at once.
Is It Recomended For Laptops to turn this options on.?
As Far as they Are Using they battery They arent in danger losing data?
    Dell Xps M1530
    Intel Mobile Core Duo T7250 @ 2,00Ghz
    Dell Inc 0xR509
    DDR 2 Dual Chanel 2 Gb
    NVIDIA GeForce 8400M GS 128 mb
    ST9160821AS 149 gb
    24/1 mb but actual speed is lower
Actually, I think laptops are supposed to disable this feature in case of battery failure. I would only do it on a desktop with a backup power supply or a power supply that is not going to fail.
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
Hello Antonyua,
I would agree with Fmjc001. It's not a good idea with laptops. It can increase the chance of data corruption on your hard drive should you lose power.
Thanks for the Info :D
    Dell Xps M1530
    Dell Inc 0xR509
    ST9160821AS 149 gb
We are here to protect and serve...:sarc:
Just post again should you need more assistance, we are happy to help :)
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
In addition, you're welcome Antonyua.
