You should upgrade or use an
alternative browser .
Solved Guy's I really need your help!!!!
A clean install is the only way to go IMHO.
Operating System
Windows 11 Workstation
Ryzen 9 5950X
Creative
Drive
1500W ThermalTake Toughpower
ThermalTake Level 10 GT
Enermax Liqtech 240
Logitech Performance MX
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
HP CP1515n Color Laser
Microsoft LifeCam Cinema
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
if you're getting crashes at install it is almost always DRAM. Getting 8GB to work is a challenge anytime, so it might be easier to install with 2 or 4GB. I had to input my memory volts & timing manually.
I agree with Z3r010. don't flash your bios especially when we don't know why the first one failed and you have urgent need for the computer.
E8400
asus p5ql-e
ocz pc 1066 2x2gb
asus eah3650 silent
Edirol UA-25
Gateway FPD2185W
1680 x 1050
750g samsung
Zalman ZM460B 460W
Lian Li A05 + 2 x Sythe S-FLEX SFF21D 120mm case fan
Coolermaster Hyper Z600 fanless CPU cooler
Microsoft Laser Mouse 6000
Merc Stealth
DSL
virtue & horse hair
Vista Pro
I tried it with 2gb and 4 gb and then 8 - same thing
All settings are on auto so I may change them manually ( I think the ram was previously 1.9v )
Gskill CS5 6400 800mhz I'll have a look on the website
- Package : 4096MB kit (2x2GB) dual channel pack
- CAS Latency : 5-5-5-15 (PC2-6400)
- Test Voltage : 1.8-2.0 V
- Speed : DDR2 800MHz (PC2-6400)
- Type : 240-pin DDR2
- Error Checking : Non-ECC
- Registered/Unbuffered : Unbuffered
- Quality Control : Comprehensive rigorously tested in pair at dual channel environment
- Warranty : Lifetime
Trust me I won't flash it.
I'll do the timings first then see if a reinstall makes a difference on a different drive - just in case I need to preserve my original setup.
system1 (system2)
q9650 3ghz (i7 920)
Asus p5q deluxe (p6t deluxe)
16gb ddr2 (12gb ddr3)
Nvidia 8800GTS 640mb (285gtx 1gb)
on board
Eizo CG301w, Dell 2407
2560 x 1600 + 1920 x1200
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
(raptor 150gb, 2x 500gb)
ocz 600w (ocz750w)
coolermaster stacker (coolermaster 690)
many fans
intellimouse
apple slim aluminum jobbie
2mb
Wacom A3 tablet, Epson 3800
virtue & horse hair
Vista Pro
OK there's a lot of stuff in the Ai tweaker.
First off
under dram timings control it states the following under auto settings,
1st information : 5-5-5-15-3-52-6-3
2nd information: 8-3-5-4-6-4-6
3rd information: 14-5-1-6-6
I've seen the 1 st information for my ram before I don't know what the rest is - shall I tap those numbers in manually?
Geezer10 you have a very similar board I'm guess the bios is the same(ish) any pointers.
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
Here is another option: power supply. Possibly you're getting excess ripple from a leaking capacitor, this could cause memory errors both in flashing and memory access. Have a look at the pc health status, are the voltages steady? The next thing I would do is swap out that PSU and do a compare. There aren't too many other options.
E8400
asus p5ql-e
ocz pc 1066 2x2gb
asus eah3650 silent
Edirol UA-25
Gateway FPD2185W
1680 x 1050
750g samsung
Zalman ZM460B 460W
Merc Stealth
DSL
i only put the first 4 timing numbers in and left the rest on auto
E8400
asus p5ql-e
ocz pc 1066 2x2gb
asus eah3650 silent
Edirol UA-25
Gateway FPD2185W
1680 x 1050
750g samsung
Zalman ZM460B 460W
Merc Stealth
DSL
virtue & horse hair
Vista Pro
Ok Guys.......I don't believe it.
The vista install has sorted it...I really want to thank everyone who has helped!
I guess it must have been a boot sector issue - Phew! Up and running now...
Right!, I can get on with the art now......
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
Hello damocles, I wasn't any help but I'm glad to see you get it sorted!
Later
Ted
* BFK Customs *
Intel C2Q 9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
XFX ATI 1GB 4870 XXX
Realtek HD 7-1
1920x1080P & 1920x1200
Corsair 620HX
CM Cosmos RC-1000
Razer Diamondback 3G
HP Enhansed Multimedia
18.6Mb/s
My First Build ;)
virtue & horse hair
Vista Pro
@Ted....well, moral support counts too.....not to mention your 'enabling' of mobo / processor upgrades....it's a shame the upgrade had to happen this way but the end result is really good. Faster and better.
/logging off topic_cheers guys - great support
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
