You should upgrade or use an
alternative browser .
Solved Guy's I really need your help!!!!
virtue & horse hair
Vista Pro
Geezer10...Hows the P5Q in your system? Is it a worthy purchase?
Chris
system1 (system2)
q9650 3ghz (i7 920)
Asus p5q deluxe (p6t deluxe)
16gb ddr2 (12gb ddr3)
Nvidia 8800GTS 640mb (285gtx 1gb)
on board
Eizo CG301w, Dell 2407
2560 x 1600 + 1920 x1200
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
(raptor 150gb, 2x 500gb)
ocz 600w (ocz750w)
coolermaster stacker (coolermaster 690)
many fans
intellimouse
apple slim aluminum jobbie
2mb
Wacom A3 tablet, Epson 3800
damocles said:
Ted...I'm slightly worried my subconscious forced me into this situation..........Oh! how the human brain works.
Yeah, my doctor has warned me as to the severe repercussions of too much
independent thought ... :huh:
Later
Ted
* BFK Customs *
Intel C2Q 9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
XFX ATI 1GB 4870 XXX
Realtek HD 7-1
1920x1080P & 1920x1200
Corsair 620HX
CM Cosmos RC-1000
Razer Diamondback 3G
HP Enhansed Multimedia
18.6Mb/s
My First Build ;)
This is why I buy gigabyte mb with backup bios. If it ain't broke don't fix it is good advice. Hope you work it out. I take it you don't have the mb manual. Go to MB manufactors site and look for a manual.
well if you don't need SLI its ok. I'm not impressed with the power draw - worse than p3X chipset - I believe the nehalem architecture will address that.
But its inexpensive compared to other Intel mobos and handles the fans beautifully with the Asus 6 engine utility. Ubuntu is a no go however.
E8400
asus p5ql-e
ocz pc 1066 2x2gb
asus eah3650 silent
Edirol UA-25
Gateway FPD2185W
1680 x 1050
750g samsung
Zalman ZM460B 460W
Lian Li A05 + 2 x Sythe S-FLEX SFF21D 120mm case fan
Coolermaster Hyper Z600 fanless CPU cooler
Microsoft Laser Mouse 6000
Merc Stealth
DSL
virtue & horse hair
Vista Pro
I have the manual - but it's no good if the mobo won't post.
But, I hear ya.........and I'm kicking myself.....
EDIT: Geezer10 - I will only use one graphic card so I guess that's OK. How much juice powers your system - mine is on a 600w psu - should be enough.
BTW: Bios is definitely soldered on - I could RMA the board but I need a replacement asap and don't really want to wait weeks for that to happen.
EDIT #2: sorry Geezer10, just seen your specs.
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
I Click Home To Much
Sadness man.. Good Luck.
I've jsut read that if I end up ungrading to a Q9550 CPU. an happen to get lucky and get the E0 stepping. then I'll have to flash my BIOS to a new one. thats only if I get the new stepping though. or even get that CPU. but I might be. so we will see.
I'll do some heavy research first after reading this. so Thanks for posting your experience so others can learn from it. +1 to you, and sorry at the same time.
Good Luck!
Q9650 E0 4.0 GHz @1.304v
eVGA 750i FTW
eVGA/MSI GTX 260 SLI
X-Fi XtremeGamer
Samsung T240 & 226BW
1920x1200 & 1680x1050
PC P&C 750w Silencer PSU
Logitech MX-518
Logitech G11
sorry to hear that you have a soldered bios - all the recent Asus mobos I have seen are socketed - you would think DeLuxe meant something. I'm surprised Asus update verified the burn.
By the way, if your bios flash fritzed it may be due to electrical interference nearby - you may need an uninterruptible power supply or beefier surge protection.
I ran one of those power hungry 4850 graphics card with a 400W Zen PSU on an AMD mobo so sometimes quality of watts beats quantity I guess - I'm sure 600W is more than enough.
sorry to get your hopes up,
E8400
asus p5ql-e
ocz pc 1066 2x2gb
asus eah3650 silent
Edirol UA-25
Gateway FPD2185W
1680 x 1050
750g samsung
Zalman ZM460B 460W
Merc Stealth
DSL
virtue & horse hair
Vista Pro
Update:-
Just bought a P5Q deluxe and swapped every thing out - all fine and dandy......
Bios posts and I can get into it OK to have a look around.
However, when I exit the bios it shuts down instead of resets - Is this normal?
And I get a blue screen just before Vista starts to load - Do I have to reinstall vista or run it from the DVD?
I have only have one disk and the dvd plugged in and bios flashes up really quickly 'no disk information' but recognises it in the bios - The bios also tells me I have 2gb ram when I have all 8gb plugged in ( tried just one stick and it still blue screens )
I don't have much time to see the BSOD codes as it turns off after 15 secs or so but I will try to note the errors codes down for you guys.
On the bright side, it has a bios back up on the board and they can be taken out.
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
virtue & horse hair
Vista Pro
0x0000007B
And during the safe mode load screen it crashes at crcdisk.sys ( I think....or was it cscdisk.sys ) - also I have tired to run vista from the dvd but it shuts down half way through the loading screen.
Any ideas.
EDIT 4pm: I reseated all the RAM and all 8gb shows up OK now.
...and the Stock CPU temp seems very high @ 85 C - cant be right?
Edit2 6pm: I disabled all the marvell IDE, Lan1/2, and firewire and I managed to get the vista dvd to run but it drops the power half way through repairing - that must be an overheating issue surely!!! Why would it just cut out?
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
I use MicroScope. It will test all your harware, memory, cpu and just about the kitchen sink. If you can obtain a copy from someone run the motherboard check and memory check.
85° is very high....time to reseat that cpu
Operating System
Windows 11 Workstation
Ryzen 9 5950X
Creative
Drive
1500W ThermalTake Toughpower
ThermalTake Level 10 GT
Enermax Liqtech 240
Logitech Performance MX
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
HP CP1515n Color Laser
Microsoft LifeCam Cinema
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
virtue & horse hair
Vista Pro
Hi usmc_nam_vet - that looks like an interesting and useful piece of kit. Not Sure I want to spend $500 on it though - can't see myself finding someone with it either.
@z3r010 I've just read that Core2's shut down at 85 c so I guess that's what's happened on that side - I wonder if I put the fan on correctly - I'll check that! The processor did fit OK in the socket and it closed fine - could be the fan - or thermal paste ( can you put too much on? ) - could this cause the bluey?
Was going to buy a new processor tomorrow (q9650) but will hold off until this issue is resolved.
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
You should only have a very thin layer of thermal paste.
[YOUTUBE]OFEOd7nQbuQ[/YOUTUBE]
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
virtue & horse hair
Vista Pro
ah!!!!!!
What's the best way to apply it?
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
make sure the heatsink surface is clean, then put a little bit on and spread it with something like an old credit card until you have an even very thin covering.
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
virtue & horse hair
Vista Pro
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
Or
[youtube]fRRWbQUqW1Y[/youtube]
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
virtue & horse hair
Vista Pro
Thanks for the tip!!!!! Redone it and temps are 35 -40 c...phew that's that one put to bed......Next ----vista reinstall and see if that helps.......
Should I flash the bios?????
:O :O - version 0803
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
I would think it's best to leave the bios alone for now
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
virtue & horse hair
Vista Pro
yeah I know - I was only half serious? actually I've read that the 0803 version is quite stable - Also now I've sorted the CPU the motherboard resets after the bios instead of shutting down - which is good.
I went for a system repair but that didnt help.
Memtest was good via diagonstics screen.
Do you think a vista reinstall would help resolve the issue?...it would be a shame to go through all that to have a bsod again....Maybe the boot sector is corrupt.
system1 (system2)
q9650 3ghz (i7 920)
on board
Raptor 74gb,
Raptor 150gb,
500gb x2,
320gb,
750gb
ocz 600w (ocz750w)
many fans
intellimouse
2mb
