Graphics Card Performance and Classification
GTX 280 should be above the 4850 x2 and right below the GTX 285.
HD 4870 512 MB should be above the regular GTX 260.
HD 3870 x2 should be above the 8800 Ultra.
9800GT/8800GT (and soon to be GTS 240) should be above the HD 4830.
8800GTS G80 320/640 should be right below the HD 3870.
9600GT should be above the HD 4670.
    Intel Core 2 DUO E8400 @ 3.6 ghz (1600 mhz FSB)
    (XFX) NVIDIA nForce 680i LT SLI
    4 GB RAM (Crucial Ballistix 4 x 1 GB DDR2/PC2 6400 @ 960 mhz)
    (EVGA) NVIDIA GeForce GTX 260 C216 - 55nm @ 684/1476/1190
    Creative Sound Blaster Audigy SE 7.1 (PCI)
    Acer X223W
    1680 x 1050
    Western Digital Caviar 320 GB SATA - 7200 RPM 3.0 GB/s
    COOLER MASTER Real Power Pro 650W - 57A on the +12v line
    Antec 300
    Arctic Cooling Freezer 7 PRO
    Unknown Logitech Wired
    Unknown IBM Wired
    20 mbps download/5 mbps upload
    2x 120mm blue LED front intake fans, 1x 120mm blue LED side intake fan, 1x 140mm blue LED top exhaust fan, 1x 120mm blue LED rear exhaust fan
The performance between these two are too close to tell really, same for the 9600 and 4670.
I've also just seen, you haven't got the 9600GSO on there.
9600GT ...(G92)
HD2900XT
HD2900PRO
8800GTS (G80)
8800GS(G80)
8800GTS 320MB
HD2600XT
HD2600PRO
HD2400PRO
HD3850
This area needs looking at I think. The 3850 should be above the 2600, not sure where them 2900s should be, but the 9600GSO should rank in above the 3850, but below the 9600GT.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
The 9600GSO should also be below the 4670, as well as the 9600GSO 512. The 9600GT and 4670 aren't that close in performance, the 9600GT beats it by a decent margin. The 4670 is actually the 9500GT's competitor but it absolutely smokes the 9500GT.
Either way the 8800GTS G80 are obviously too low. The 8800GS (and 9600GSO) do not beat the 320 MB 8800GTS. Look at the differences.
8800GS/9600GSO
Chipset: G92
Transistor Count: 754 Million
Manufacturing Tech: 65nm
Memory Type: GDDR3
Memory Size: 384 MB
Memory Interface: 192 bit
Stream Processing Cores: 96
Texture Filtering Units: 48
Raster Operators: 12
Core Clock: 550 mhz
Shader Clock: 1375 mhz
Memory Clock: 800 mhz (1600 mhz effective data rate)
8800GTS 320
Chipset: G80
Transistor Count: 681 Million
Manufacturing Tech: 90nm
Memory Type: GDDR3
Memory Size: 320 MB
Memory Interface: 320 bit
Raster Operators: 20
Core Clock: 500 mhz
Shader Clock: 1200 mhz
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
How about putting the desktop cards above the mobility ones while your at it? ;)
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
The 8800GS (9600GSO) and GTS 320mb are pretty even
http://www.hardspell.com/pic/article/2008/1/18/5598da15-b8f8-4a24-a91c-313369c55ecb.png (only side by side comparison I could find)
The G92 chip alone compensates the lower specs than the GTS. Higher resolutions the GTS will most likely push ahead slightly because the 8800GS/9600GSO are crippled by their memory interface.
The other revisions of the GSO with more memory will be harder to place, like I think they released a 768mb version at one point, and www.scan.co.uk as a 1.5GB version for sale, though still crippled by the memory interface.
I don't think the list will ever be accurate by looking at benchmarks etc and real world performance with the endless number of setups you can test under, different computers will always yield different tests and the list isn't going off any specific setup either, like you can argue about resolution and at different resolutions the list will be different, though I think something like the Steam Hardware Survey would be ideal to go off to an extent (February 2009 showed 1280x1024 resolution as the most used resolution still).
I think the list would be better by just putting them in order of specifications :p
I think it's better how the mobile GPUs have been listed in the different classes such as "for high end gaming, go for these cards" and every card in that class will play the latest games with ease on the highest settings, and then the mid-range cards in another class and so on.
    ASUS Xonar DX
    100Mbps
Because this thread started as a mobility GPU thread that is comparable to the desktop versions in classification and performance benchmarking), and the Independent Desktop card list was added by Skunksmash as a courteousy for users at a much later time, and I have asked him to help me keep the card performance rankings up to date.:D
Mobility cards updated...
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
ok....... have a look at the list now lads..??? ;)
now i don't believe the GTX280 is stronger than the 4850x2, everything ive seen shows it out performing the 280 & 285, but feel free to provide benches to the contrary...
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
I'd put the 3850 underneath the GTS 320. In my opinion they're around equal to each other.
But apart from that I'm happy with the list. It'll never be 100% :p
    ASUS Xonar DX
    100Mbps
will do mate......;)
these GTS250s are getting raves everywhere i look, SLI is where these are supposed to excel....
& even though this still has a 256bit bus, the 1gb version has been tweaked for better AA delivery at high res.... unlike the complete shambles they were left with on the 1gb 9800gt :sarc:
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
:)SK
That's interesting. Seems Nvidia are focusing more on improving AA, especially as the "performance increase" on the Nvidia driver download page say "with AA" when they never did before.
Still think it would have been better being made a GTX250 for a mid-range GT200 card :p
    ASUS Xonar DX
    100Mbps
Also the 8800M GTX should be right below the 9800M GT in the mobility section. They are essentially the same card.
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
Done. The 9800m GT has been downgraded below the 9800m GTS/GTS 160m Cards.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Actually the 9800M GT is a rebranded 8800M GTX. They have 512 MB VRAM and 256 bit interface with 112 stream processing cores. I don't know about the GTS 160M, but the 9800M GTS is actually worse than the 9800M GT. NVIDIA likes to confuse their customers.
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
8800m GTX (NB8E) 3dmark06 bench: 9194
9800m GT (NB9E-GT2) 3dmark06 bench: 9416/ vantage bench:4011
86 shaders/500 core speed/1250 shader speed/800 memory speed/256 memory bus
GTS 160m (NB9E-GT)
9800m GTS (NB9E-GT) 3dmark06 bench: 9692
64 shaders/600 core speed/1500 shader speed/800 memory speed/256 memory bus
Rank:
GTS 160m (?)
9800m GTS
9800m GT
8800m GTX
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
My bad, I meant 96 stream processing cores on the 9800M GT/8800M GTX. 3DMark 06 is not the place to test GPU's. Look at the specs, the GTS 160M is worse. 3DMark 06 is way CPU limited, 3DMark Vantage tests your GPU.
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
Radeon HD 4890 review | test
Not sure where I'd put the 4890. Possibly just under the GTX285, although the 260 beats it in things like Farcry 2.
Not looked at the GTX275 yet, will have a look at some soon :)
Edit: Had a quick look at the 275, and will be between the 285 and the 4890 by the looks of it.
    ASUS Xonar DX
    100Mbps
OK.....the list has been updated, the GTX275 seems to have the edge by 1-2fps in the standard resolutions, but the 4890 pulls away by a few frames when the res is pumped up.... they're very close in terms of performance.....;)
i am hearing the 275 is a VERY hot card though, 80-85c fully loaded :eek:
let me know how it looks..??
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
I am waiting for the 4870x2 to drop back to $399 or below.
    16GB DDR667
    SAS RAID
:)SK
Looks okay :)
From what I've seen on benchmarks, they out perform each other or are around the same in various different games, so on average they do pretty much perform the same.
    ASUS Xonar DX
    100Mbps
That's absolutely horribad.
    My build
    Core2Quad Q9550 yorkfield C1 3.8G
    GIGABYTE GA-EP45-UD3R
    8gig Kingston HyperX 8500 CL5
    Gigabyte GTX280 1G...generally stock.
    onboard
    Samsung 24" 2433bw + Benq 19" FP91G+
    2 x Samsung 500G Raid0 1 x Samsung 1TB 32
    Thermaltake Toughpower 850W
    Antec twelve hundred.
    Air...a lot of air. Thermalright 120 push/pull,8 case fans,
    Logitech G5
    Logitech G15
    ADSL2
