thepizzaman
Banned
no it can't be true.............. lolThe specs differ quite a bit. The 295 has the lowest core clock at 576MHz that is equivalent to the 8400GS. The 280 at 604MHz, 285 at 648MHz, and the 4870 X2 at 750MHz. The winner is clearThe 295 can out perform a 285 and 280, and in a lot of cases can also out perform a 4870x2 as well.
I stick to my order.
Clock speeds aren't everything though, and you don't buy a 295 to run it without SLI enabled, so having it run in SLI is going to out perform a 280 and 285, and will infact out perform a 4870x2 regardless of clock speeds.
i will reject your reality and substitute my own
- Acer, Aspire M1201\Custom Build
- AMD Athlon X2 5000+ @ 2.6Ghz
- Acer Micro-ATX Motherboard
- 2x2gb Patriot Viper DDR2 PC6400 @ 800mhz Dual Channel SLI Edition (4-4-4-12)
- ATI HD3870 with 512mb GDDR4
- Realtek HD 7.1 Onboard Sound
- 22" Acer X223 Widescreen
- 1680 X 1050
- 320gb Western Digital SATA II (Ubuntu 9.10) 500gb Seagate SATA II 1tb Seagate SATA II (Vista Home Premium)
- PSU
- ULTRA X3 600 Watt Modular
- Case
- NZXT Tempest (The Airflow King) 2x 140mm Fans, 4x 120mm Fans
- Cooling
- 1x 135mm In PSU, 1x 70mm On CPU, And 1x 120mm On GPU
- Microsoft Sidewinder X5
- Microsoft Sidewinder X6
- 6 Mbs Down 1 Mbs Up
- Other Info
- AVerMedia 1500MCE TV Tuner Logitech X540 5.1 Surround Sound
