Fan Setup for Best Airflow???
in the tempest you have plenty of room because the 120 fan way below where my cpu is.... it is actually a little below my gpu because of where my x16 slot is
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
Oh really? That's a huge plus. My freakin' gfx card is so big that it would definitely benefit from that fan as well. hmmm... very nice to know. Thanks!!!
    Intel Core2Duo E8400 3.0GHz
    eVGA NVIDIA nForce 780i SLI
    OCZ NVIDIA SLI-Ready Edition 4x2GB PC6400 DDR2800 4-4-4-15
    eVGA GeForce GTX 260 896MB GDDR3
    Creative Sound Blaster Audigy 7.1
    LG - 23" Widescreen Flat-Panel LCD HD Monitor - Black
    Seagate Barracuda 250GB 7200RPM SATA 3.0Gb/s
    OCZ GameXStream 600W
    Cooler Master HAF 932
    Arctic Cooling Freezer 7 Pro CPU Cooler, 6x120mm, 2x140mm
    Logitech G51 155 watts RMS 5.1 Surround Sound Speakers
your welcome haha ;) let us know what you choose :)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
I definitely will do!
haha ok :)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
the tempest is a little noisy.... but you can get silent fans for about $10 a peice
but it is still in my room and i do sleep with it on :) but... bright lights haha :)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
For airflow you could always try the Antec Skeleton.
Antec - Skeleton
Edit: I was using HWMonitor when I was overclocking and running my stability test. How do I know what my temperature is when I'm idle? What constitutes a system being idle?
Idling means that nothing is happening (or just about) with the CPU. Considering that this is impossible due to Windows you go to second best option.
Just close all running applications and leave it for a minute = idle temps.
It doesn't have to be scientifically accurate, it is more of a 'near enough is good enough' kind of thing.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Coolermaster Silent Pro 700M
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
    Graphics Driver - 190.38
Antec - Skeleton
Holy crap, that "Skeleton" is...... different? haha. I like it yet don't know what to think of it.
haha a little to.... open for me haha :)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
I read somewhere that one of the most important aspects when it comes to the airflow in PC cases is that the amount of air exhausting from the system MUST NOT be higher than amount of air that the system intakes, to prevent vacuum effect, and acquiring more dust than when using the correct airflow setup ;)
    My Own Build
    Intel Core 2 Duo E8200 @ 3.73 GHz
    ASUS P5E
    Kingston DDR2 HyperX PC2-8500 4x1GB CL5 @ 1117MHz
    Gainward GeForce 8800GT 512MB GS (700 / 1700 / 1020 MHz)
    SoundBlaster X-Fi Platinum Fatal1ty Edition
    LG Flatron W2252TQ 22"
    Seagate Barracuda 11 500GB & 750GB, Total Capacity: 1.2TB
    Corsair HX520W PSU
    AeroCool S9 Pro with 40cm Side Fan
    Scythe Mugen (Infinity) CPU Cooler, 4x Noctua NF-P12-1300
    Logitech MX1000
    Logitech Media Keyboard 600
    ADSL Broadband - 1 Mbit Down / 256 Kbit Up
    Genius SW-HF5.1 5000 Speakers, Roland RH-50 Headphones
Well Majkel you read wrong :)
The best way of cooling a pc with fans is to have more exhauast CFM than intake CFM air flow. This causes cool air to be pulled in through all the gaps in your case. If you think back to the old pcs that only had one fan that fan was always an exhaust as "negative" pressure inside the case is the best cooling solution.
The only reasons to have more intake CFM are if your using dust filters so that you can limit the dust getting into your case or if you want to guide the intake air to specific spots within the case.
Phew..... I was afraid I was going to have to go into my case again to switch fans around. Since my jet engine fan is my exhaust fan and all others are the intake. That would mean I would need to remove my cpu heatsink and moving others around. Thank god I don't need to do that.
so are you still planning to get a new case?
    1680 X 1050
    6 Mbs Down 1 Mbs Up
Without question. I just ordered another 4G's of RAM so I'll have 8G's now for my Adobe work :D. I'm still trying to make my mind up about which one though. Really not leaning in favor of any case as of yet. I'm still looking around for one as this is an important decision. Right now I'm running at about 38C on avg.
Hi Gudziel I hope you got your ram cheap as if i was you id have sold the ram you have and upgraded to 1066 ram as then you could have raised your fsb to 500 and lowered your multiplier on the cpu to 8 which would have gotten you the 4Ghz you wanted.
But anyway 38C is ok, not great but ok lol.
Just thought I'd throw in a pic of my current temps in the HAF 932 for comparison:
(ignore core 1, 3 and 4. Stuck sensors :rolleyes:)
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
When you post a temp screenshot you should include windows task manager with the performance tab selected so we can see uptime as well as temps as this gives a better idea of what temps are really like.
Picky much? :p
That was idle, uptime of around 10hrs when that shot was taken.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
