You know, I was starting to believe that too, because it only has one fan. Usually the front where the HD is gets very warm, like warm enough to heat up the top of the lappy by the touchpad. Other than that I would say no. The area by the fan is pretty cool to touch on the bottom. Just checked
Does anyone else experience this? It seems to be pretty big...
[EDIT] I used autoruns to disable the mail service, and everything to do with the mail, I dont use it. But there was still a context menu for it. I found where the context menu was for that and deleted it so now when I right click a file it only says Send To... Zip or CD/DVD drive. Seems to have worked but idk yet. It took 6 hours for the other change to take place.
- HP
- Intel Neo
- 2GB
- Intergrated Intel Graphics
- Integrated
- 1280 x 800
- 160GB
- PSU
- Power Adapter
- Case
- It's special, it flips open :)
- Touchpad
- Acer
- Down: 16mb/s Up: 1.6mb/s
- Other Info
- I killed my HP Laptop :'(
