hdbg62
Just about came to the same conclusion but then I remembered what I was doing before the dvd player showed up. I was testing a bootable usb stick which I created according to the instructions in this forum. I booted from the usb which is a copy of the install disk for the laptop and which worked fine. After that, I booted the normal way and that’s when the dvd player showed up; what made it disappear after ten minutes, I don’t know. Tried the same routine again, booting with the usb just to get me to the Windows install screen, opted out, booted the regular way and dvd player is back! Changed the drive letter, booted into safe mode, dvd player still there; numerous soft and hard boots, even putting it to sleep manually for awhile, dvd player still there. Let the laptop go to sleep on its own, when I woke it up, dvd player is gone. So I repeated the same scenario, usb install disk boot first, out of it, boot the normal way and the dvd player is back; it’s back as I write this. Even uninstalled the dvd player, rebooted and the dvd player was there. One thing I know for sure, if the dvd player is gone and I boot first with that bootable usb, get out of it, boot regular, the dvd player is back; have tried it often enough. Don’t know why. What I’m trying now is to figure out why the dvd player disappears by turning off the “put the computer to sleep after….” option and just putting it to sleep myself when I need it; I remember somewhere in all my searching on this that in one instance the “put the computer to sleep after…..” option came into play and when turned off solved the problem in that instance. Don’t understand why what’s happening is happening, so I’m willing to try anything. Have been at this most of the night. All of it does not make any sense to me; we’ll see.
- Dell Inspiron 530
- Intel Core 2 DuoE4500 2.20G
- 3.00G DDR2, 667MHz
- Intel G33/G31 Express 320
- Realtec ALC888 (7.1 Channel audio)
- Dell 22" E228WFP
- 1680x1050
- Samsung HD501LJ ATA 500 G PBDS DVD+RW DH-16W1S ATA MAXTOR 320 G USB
- 5.28 Mb/s Down, 0.64 Mb/s Up, ATT Dry Loop DSL
