Driver question
Darkassain, Yes i am all for getting it right!
    Dell xps420
    quad [email protected] Ghz
    BTX otp406
    4 gig @ 800mhz
    ati radeon hd 2600 xt PCI-E 256MB
    PCI Express X-Fi Xtreme Audio
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
    Download 2.8 mps Upload 722kbps
    Nod32 4/ Logitech z5500 5.1/ Canon mp600 printer
Yes i got the driver only from their site. AGP card? Sorry just learning here.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
Just to be clear, Everything was working including the ccc prior to the driver update.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Where are you getting your drivers from? At ATI's website you should be able to just dowload the drivers without the CCC panel.
Also, do you have an AGP card?
hd26xx dont have agp if i can remember....
it should all be pci-e
Radeon R600 - Wikipedia, the free encyclopedia
:) Visiontek Radeon HD 2600XT 512 MB AGP 8X Graphics Adapter: Compare Prices, View Price History and Read Reviews at NexTag
thanks for correcting sygnus....;)
hmm he saying that he got it working before the update the drivers (that would be a month ago correct larry??)
256 mb is the card size if this helps? Also i want to thank you all for your help ahead on time.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
yes, i just did a sr after the driver download to get things working a month or more ago. The original driver was dated 6-07.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
This puppy just refuses to work. I think i will just do a sr a leave it alone. Kinda pisses me of that a driver update has to be so complicated. Maybe they need to get their **** togeather at ati or is it just me?:mad:
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
well the least i can do is not let the computer startup in with a error...
go here
http://www.vistax64.com/tutorials/79612-startup-programs-enable-disable.html
go down until you see this...
With System Configuration - msconfig
follow how to get to msconfig and follow until you get to startup....
there uncheck any ATi programs.....
if not then just unnistall it...
hope it helps....
if there is no mention then just ignore it...;)
Darkassain, I am not getting any errors on start up. I just wanted to update the driver. That's it. But why in gods name does a driver update stop the ccc from working properly? I personally do not think that a simple driver update should do this. Thank you for working to help me with this.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
What brand of video card do you have? Also it would really help to know whether you have an AGP, PCI or PCI-e express card. I'll say you don't have the PCI-e card, but...you need to know this. If you're not sure how to do this, maybe you can have someone look at your computer and tell you.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
also if you do not know and this computer was prebuilt by an OEM (hp Dell just name a few...) can you give the product model of the computer.....
after looking for the specs i found it to be a pci-e card. thanks ps this is a oem xps 420 as stated in my system specs.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
Sygnus 21, I wish i would have known agp/pci/pci-e was specificaly needed to continue before downloading drivers for the apg card. My bad! Also changed my system specs to reflect pci-e. As for the brand of card it was at the first post.
(edit) and one more thing sygnus 21, If i had someone to come and look at my computer to see what card i had i would not be here asking for help! Like i said just learning.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
It's just that you said you didn't know what AGP was. I was just asking you if you had someone physically look at the computer. I meant no harm.
edit My Post - http://www.vistax64.com/graphic-cards/201526-driver-question-post928631.html#post928625
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
Sygnus 21, I just wanted to say that i am sorry that i took it that way. Have a good day and thanks for helping.
    Dell xps420
    BTX otp406
    4 gig @ 800mhz
    dell 2707wfp
    1900 x 1200
    375 w
    stock
    stock
    dell bt
    dell bt
You're welcomed.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
