Nope.. If you don't play games thats fine... No need to load out the video card if you don't do it.. It'll just show how hot it gets when maxed out. But you aren't doing this.
The program i posted will, test your video card for errors. It was made to check how the card performs math, which relates to how it displays things on screen. Errors there mean errors displaying.
If it is heat damaged, its a gonner, 90% of laptops you can't replace the video card as its solder on the board. If you can fix it and live with the daily fixing, leave it alone.
The damage is caused by bad soldering and as it heats and cools, the joints break.
Hope I'm wrong and it smartens up with a driver issue, but it is a possibility its damaged hardware.
- Dual L5639 // i7 950 @ 4.0Ghz
- Evga SR-2 // Gigabyte x58a-ud3r
- 12Gig Corsair XMS3 // 6Gig OCZ Gold
- gtx 560 ti // gtx 260-216
- Dual 22" // Headless
- OCZ aGILITY 3, 120Gig + Seagate 500Gig x 2
- PSU
- Silverstone da700 // Corsair 520hx
- Case
- Rosewill BlackHawk Ultra // Antec 900v1
- Cooling
- Twin CM Hyper 212+ // Noctua NH-u12
- Other Info
- Acer 8930 laptop with x9100...
