disc clean-up not working
under the system stability chart there is: software Uninstalls, application failures, hardware failures, windows failures, miscellaneous failures. and on the application failures there are so many red x, and also on the miscellaneous failures with red x. and on the software uninstalls there are few yellow color "!" and with respective dates.
Look for the disk cleanup entries and run that .bat file.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
The .bat file will run chkdsk in readonly mode to see if your hard disk had bad sectors. Right-click it and select run as administrator.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Here:
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Right click it and select run as adminstrator. Don't edit it or open it.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Frostmourne, can we continue this tomorrow? its getting late here in SF CA. got to work for tomorrow. btw thnx so much. until tomorrow. CIAO!!! gudday/gudnight.
hi frostmourne, im back from work. i did your instructions last night but nothing happen, still disc cleanup not working. i went to event viewer and there are lots of errors on the administrative events and also on the diagnostic performance operational there are also lots of errors
Can you go to your C:\ drive and look for results.txt? Do any of the errors stand out?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
The type of the file system is NTFS.
Volume label is SQ004829V03.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
0 percent complete. (0 of 190784 file records processed)
1 percent complete. (19079 of 190784 file records processed)
2 percent complete. (38157 of 190784 file records processed)
3 percent complete. (57236 of 190784 file records processed)
3 percent complete. (62593 of 190784 file records processed)
4 percent complete. (76314 of 190784 file records processed)
4 percent complete. (86529 of 190784 file records processed)
5 percent complete. (95392 of 190784 file records processed)
5 percent complete. (113462 of 190784 file records processed)
6 percent complete. (114471 of 190784 file records processed)
6 percent complete. (128685 of 190784 file records processed)
7 percent complete. (133549 of 190784 file records processed)
7 percent complete. (142565 of 190784 file records processed)
7 percent complete. (144617 of 190784 file records processed)
7 percent complete. (148663 of 190784 file records processed)
8 percent complete. (152628 of 190784 file records processed)
8 percent complete. (158872 of 190784 file records processed)
8 percent complete. (160196 of 190784 file records processed) this what the drive C says
Towards the bottom of the text file, what does it say? Does the disc have any errors?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Open up your C:\ drive in Windows Explorer and look for Results.txt.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Re-run the .bat file as administrator. It should create a file in your C:\ drive. Have you installed SP2?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
If everything else works, ignore disk cleanup. Wait for Windows 7 in less than a month. That will probably fix it. Apart from this are you having any other problems?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
