Disappearing Hard Drive Memory. please help!
Yes that is fine. Vista makes backups before the defrag just in case.
Use the new defrag when you are at or over 10% frag.
Ok now part 2
Download ccleaner. Then when you have done that I will tell you how to set it up to get rid of crap that is not needed. BTW, it is now called ccleaner it was called crap cleaner but they changed the name.
Under windows check
temp internet files
history
cookies
recently typed urls
empty recycle bin
temp files
clip board
memory dumps
file fragments
log files
APPlICATIONs
Make sure that registry is completely unchecked
For now do not delete cookies
So, on the left hand side under registry, everything should be unchecked as well as everything under the applications tab next to the windows tab?
  • Memory
    62.2GB
Registry all unchecked this is important
Then for applications all should be checked. This is suggested.
They are just temporary file that are no longer needed.
Also you asked earlier when talking about defrag
Okay Thanks. So now it's just finding and deleting the files that aren't needed?
Defragging does not delete any files it just tries to put file fragments closer together on your disc so you can access them quicker,nothing deleted with defrag.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
^ thanks, and yes, i knew that, bad wording on my part, i was just saying that i was going to have to go through and see what files that i personally needed to delete. sorry about the confusion.
  • Memory
    62.2GB
Dont do anything unless you are comfortable. Always ask if you feel concerned.
Richc46, if he is not going to use Windows defragger you should maybe tell him how to remove the scheduled task from task scheduler.Don't want two running.
    LENOVO 64734VM
    15 inch
She, heh. and I don't believe it's scheduled. I've never scheduled it to do so, unless it is set up like that automatically.
Yes i just checked and it is not set on a schedule
  • Memory
    62.2GB
Its set by default, turn it off.
I think that you are going to be in good shape when all this is done.
I did everything you've said so far, and like I said, there is still only 7.45 gb of space left... is that okay or is there something else i should do?
  • Memory
    62.2GB
There is no magic available space number. It depends on the size of your hard drive and space used.
Make a system restore point and then download windirstat. We can see exactly what is on your hard drive. When we are done we can use system restore to get rid of it, if you dont want it. But it will help answer your question, now.
WinDirStat - Windows Directory Statistics
