ddr2 and ddr3 mobo
now is my new board again [ASROCK N68C-GS FX MotherBoard AM3+ Processor, 8-Core CPU DDR2-1066 / DDR3-1600
    build by me last summer
    cpu.3.00.ghz
    asrock fm2 -75 pro
    g-skill 1333 7-7-7-21 4 gbs
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    apevia.atx-as500 blue led
    thermatake armor a 30
    5= 80 mm led fans
    logitech
    logitech mk 300
now here are the ram for ddr3 [G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL6D-4GBXH
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
If I'm interpreting the following correctly, you should be able to use that CPU. However, I'll leave it to you to make the final determination since I''m not familiar with all these AMD products.
ASRock > Products > N68C-GS FX
I'll also leave it to you concerning the RAM.
I have no idea what a 750 ws black is.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
here is the best hardrive [Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
when they had the flood i pay 169.00 for that drive
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
here what are they selling now .
Price:
$299.00
SKU:
WD7501AALS
Brand:
Western Digital
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
Nice find on the 1066 cl5 ram. It'd be some pretty fast ddr2 ram. However, finding ddr3 1600 cl6 ram is better.
I would buy the ddr3 cl6 ram as its alot faster, and the timings are nearly the same, and most likely can be dropped to 1333 cl5 in the bios to get you tighter timings.
Along with that, ddr2 is dead, buying it is a waste when you can buy ddr3, which can be used on future builds.
You may, or may not beable to use the your old install of vista. But your harddrive is definately still good.
As for your if you have to reinstall vista, only the stuff in your profile, will be ssaved. However you could partion the drive into 2, and put it on to the 2nd part and it'll be safe.
What board is the black on now?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Yes it supports DDR3 but, as stated, he needs a AM3 or AM3+ CPU to use it.
I assume your copy of Vista is a Retail version. If it was OEM, you probably can't use it on another system. If it's Retail, then you ought to be able to use it on the new system. Either way, the hdd is good on the new mobo since it supports SATA 3.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
As far as I understand, he is going with an x3 which is am3.
is this is the one [ G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL6D-4GBXH
$40.49.
this was in my cart at newegg.ca
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
this is the case i buy with the ram above .
all the other parts are from the old computer .
well old .no .i only turn it on to do the update on it .
i build it last oct
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
Thermaltake ARMOR A30 VM70001W2Z Black SECC MicroATX Mini Tower Computer Case.$119.99
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
What board is the black on now?[this is the board.
now i do that to pass time only .at 68 i have some thing to pass the time .
now with the new board i have 2 computer in one .
cant you buy 2 new pc for the same money .never .i mean never .
so by doing this i will have the fastess pc on ddr2 and ddr3 period
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
by the way this is the board on my signature .
look at the name
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
no it not .
my mistatake .sorry about that .lol
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
$40.49.
Aslong as your cpu is AM3, it should work just fine.
Edit
You may get very lucky and not need to reinstall windows if you keep the board in the amd 8'series line, i.e. 870->880g->890
here is the board it in the computer now .
BIOSTAR TA870U3+ AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
here is the cpu [AMD Athlon II X2 270 Regor 3.4GHz Socket AM3 65W Dual-Core Desktop Processor ADX2700CK23GM
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
now has for vista i buy the key from a guy that fix computer .
so when he get old case with the sticker in them he is keeping the key's .
so i pay 30.00 .
now i do have a couples here also .
if not come to worst i will call microsoft to the key's tranfer on my new board .
i hate talking on the phone because am french .
you know what i mean by that .it not to funny .
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
It should be just fine.
You should look for Microsoft canada's phone number. They have a french department! Or i believe they do as I think you have to here.
