Crysis 64bit
Hi guys, I believe this "Crysis Warhead has stopped working" crap is caused by drivers. Mine was working fine until after the last 3 driver upgrade. Don't remember the previous two but the last one is 185.20 just came out. Some glitches even show up in Crysis 1 I had'nt noticed before. However, I have find out that the problem seems go away after the first few stages which I hadn't find out yet 'cus I was busy playing FC2 and just finished first round of Dead Space. The new drivers is helpful for the this other games. How nVidia patch the problem real quick.
Cheers,
Bruce
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Cheers,
Bruce
185.20? theres no driver out with that version number? i think NV are upto 180.48 for latest drivers and 180.84 for beta drivers
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
185.20 was released a few days ago, they're modified by a 3rd party & not officially supported by Nvidia...
im running them now, they're pretty good. ;)
i think Nvidia's latest BETA's are 180.84 for x64 ..??
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Hi guys, guess what? I went back to 180.48, the "Crysis Warhead has stopped working" went away.
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Strange, mine starts fine from an icon on my desktop, it also runs in 64 bit from the desktop from the shortcut from install and runs in DX10 automatically, and to check you are running in 64 bit, you could control+alt+delete and see if your crysis.exe has a *32 next to it.
Lordvader, to have an icon on the desktop, just navigate to C:/program files(x86)/electronic arts/crytek/crysis/bin64/crysis.exe right click this file and send to> desktop(create shortcut), to place an icon in your game folder, open the game folder up and drag the new icon to the game folder
in that Folder there are 2 Options
1 Crysis
2 Crysis64
But not a - Crysis.exe ICON
which one should i put on my desktop ?
Thxs for ur help
the exe isnt showing because you are hiding extentions for known file types, heres a few images to help you understand.
furthermore, right click the "crysis" file and send to desktop(create shortcut)
thanks again :)
Was messing around on Crysis Warhead trying to fix the bad fps I was getting (under 10) on enthusiast 1680x1050.
In my search on the Internet, I came across how to enable the ingame ambient occlusion, which I find makes a huge difference at no performance loss (I was already getting bad performance, so I don't think I'd have noticed any more anyway).
To enable it, you need to add a few commands to your configs in the Crysis Warhead directory (not sure these commands work on Crysis, I'll have to get the disk off a friend and try it). Once in your Crysis directory, go to Game>Configs and open the difficulty config you use.
I used diff_easy.cfg for this as I've already completed it.
con_restricted=0
r_SSAO = 1
r_ssao_quality = 1
r_ssao_radius = 2
r_ssao_amount = 0.55
r_SSAO_darkening = 1.3
Just copy and paste them parameters at the end of your config and fire Warhead up and you should notice the lighting straight away. I tried editing the values, but them values seem to be the "sweet spot" for it.
The next part I found seemed to fix the bad fps, and stop all the "pop up textures" that seem blurred from a distance and load in as you got nearer.
sys_budget_videomem = 512*
r_TexturesStreaming=0
*Change value to however much VRAM you have on your graphic card. If you have 1GB of VRAM, then change to 1024 etc.
Copy these to the end of the config again. I set mine to 512 and the performance felt a lot smoother for me. Apparently, Crysis Warhead only uses 256mb VRAM by default, no idea if that's actually true, but the performance increase from that command seems to justify it for me.
The TextureStreaming command does what I said before and gets rid of that "pop up texture" problem.
I'm not sure if these work in Crysis, I'll test it myself when I get the disk off a friend, which will be next week.
Think I'll have a replay of Warhead this weekend though at max graphics.
I'll add some screenshots tomorrow of the ambient occlusion, too.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Copy these to the end of the config again. The performance for me shot up and was very playable with the 512 value, but as I have two video cards, I upped it to 1024 and now the performance is amazing. Not checked the fps though, will do that tomorrow. Apparently, Crysis Warhead only uses 256mb VRAM by default, no idea if that's actually true, but the performance increase from that command seems to justify it for me.
Hi Everlong, great info. Thank you.
I would like to ask you if for my system config, use different ram value such that sys_budget_videomem = 640 instead? I am going to give it a try tonight.
Thanks,
Bruce
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Yea I should have added that. Change it to the value you of the amount of memory your graphic card has, so yea it would be 640 for you, but you have SLI, so you might see better performance from setting it to 1280, like I did from setting mine to 1024 for my two 512mb cards.
    ASUS Xonar DX
    100Mbps
i am having the same problem. but the windows games 'fix' thing works halfway. i get it to load, then when i try to load a new game/ load any level, its loads completely, then when i 'press any button' it crashes and says 'crysis64 has stopped working'
any more (different then whats already here perhaps?) suggestions?
There are all requirements of Crysis->
Minimum Requirements
CPU: Athlon 64 3000+/Intel 2.8ghz
Graphics: Nvidia 6200 or ATI X1300 - Shader Model 2.0
RAM: 768MB on Windows XP or 1GB on Windows Vista
HDD: 6GB
Internet: 256k+
Optical Drive: DVD
Software: DX9.0c with Windows XP
Recommended Requirements
CPU: Dual-core CPU (Athlon X2/Pentium D)
Graphics: Nvidia 7600 or ATI X1600 Pro (SM 3.0) or DX10 equivalent
RAM: 1.5GB+
HDD: 6GB
Internet: 512k+ (128k+ upstream)
Optical Drive: DVD
