Here's the next one:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Loading Dump File [C:\Windows\Minidump\Mini041709-01.dmp]
Symbol search path is: SRV*C:\SymCache*
Symbol information
Executable search path is:
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrpamp.exe -
Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible
Built by: 6001.18226.x86fre.vistasp1_gdr.090302-1506
Machine Name:
Kernel base = 0x81c0b000 PsLoadedModuleList = 0x81d22c70
Debug session time: Fri Apr 17 16:20:29.028 2009 (GMT-7)
System Uptime: 0 days 0:18:08.863
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck C1, {b937cf08, 0, f8, 22}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : win32k.sys ( win32k!xxxMsgWaitForMultipleObjects+cb )
Followup: MachineOwner
1: kd> !analyze -v
SPECIAL_POOL_DETECTED_MEMORY_CORRUPTION (c1)
Special pool has detected memory corruption. Typically the current thread's
stack backtrace will reveal the guilty party.
Arguments:
Arg1: b937cf08, address trying to free
Arg2: 00000000, bytes requested
Arg3: 000000f8, bytes calculated
Arg4: 00000022, caller is trying to free a bad address
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: win32k
FAULTING_MODULE: 81c0b000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 498f9e9d
BUGCHECK_STR: 0xC1_22
SPECIAL_POOL_CORRUPTION_TYPE: 22
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 81ca2a53 to 81cd80e3
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
8701f9f4 81ca2a53 000000c1 b937cf08 00000000 nt!KeBugCheckEx+0x1e
8701faec 81cf8f78 b937cf08 00000000 9617fbd8 nt!NtFreeVirtualMemory+0x5d9c
8701fb50 81c4c9b8 b937cf08 00000000 e24a4936 nt!ExFreePoolWithTag+0xeb
8701fb9c 81c4d04e 9617fc18 8701fbc8 8701fbd4 nt!ObDereferenceObjectDeferDelete+0x11f
8701fbf4 81cc2322 00000000 00000000 00000000 nt!KiDeliverApc+0xce
8701fc44 81cbf32f b5256d78 81cbedef fe4bae90 nt!KeInsertQueueDpc+0x670
8701fc98 9b92ee62 00000002 b4c54ff8 00000001 nt!KeWaitForMultipleObjects+0x540
8701fcf0 9b8bf1c8 00000001 b4c54ff8 9b8cfa7a win32k!xxxMsgWaitForMultipleObjects+0xcb
8701fd34 9b8bee28 b4c54ff8 00000001 9ba93260 win32k!xxxDesktopThread+0x1a8
8701fd48 9b981ff2 00000004 00f8fe08 8701fd64 win32k!xxxCreateSystemThreads+0x54
8701fd58 81c62a1a 00000004 00f8fe48 77029a94 win32k!NtUserCallNoParam+0x1b
8701fd64 77029a94 badb0d00 00f8fe04 00000000 nt!ZwQueryLicenseValue+0xbd2
8701fd68 badb0d00 00f8fe04 00000000 00000000 0x77029a94
8701fd6c 00f8fe04 00000000 00000000 00000000 0xbadb0d00
8701fd70 00000000 00000000 00000000 00000000 0xf8fe04
STACK_COMMAND: kb
FOLLOWUP_IP:
9b92ee62 8945e4 mov dword ptr [ebp-1Ch],eax
SYMBOL_STACK_INDEX: 7
SYMBOL_NAME: win32k!xxxMsgWaitForMultipleObjects+cb
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: win32k.sys
BUCKET_ID: WRONG_SYMBOLS
