connected to network, but not internet
Putting this up here isnt going to enable some one to do harm to me is it?
Windows IP Configuration
Host Name . . . . . . . . . . . . : ALRST22
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : myhome.westell.com
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : myhome.westell.com
Description . . . . . . . . . . . : Broadcom 802.11b/g WLAN
Physical Address. . . . . . . . . : 00-1A-73-4B-01-75
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::75ae:746e:e479:f35b%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.43(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, July 23, 2008 12:44:36 PM
Lease Expires . . . . . . . . . . : Thursday, July 24, 2008 10:39:24 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 151001715
DNS Servers . . . . . . . . . . . : 192.168.1.1
192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet NIC #2
Physical Address. . . . . . . . . : FF-FF-FF-FF-FF-FF
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.myhome.westell.com
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::5efe:192.160.1.44%14(Preferred)
192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-59-4E-01
IPv6 Address. . . . . . . . . . . : 2001:0:4139:9e50:1422:13ff:3f57:fed3(Preferred)
Link-local IPv6 Address . . . . . : fe80::1423:13ff:3f57:fed3%12(Preferred)
Default Gateway . . . . . . . . . : ::
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : 6TO4 Adapter
Apologies for the delay with this update, I've been overseas for a few weeks.
The good news is that I no longer have this issue using my ISP's DNS servers (I manually set to the Yahoo DNS Servers previously).
The settings I am using now are that Vista PC uses DHCP to get IP4 Address and DNS servers from my Linksys router which I have entered the DNS server addresses into manually rather than "discovering" from the ISP. I have still disbled IPv6 on my ethernet adapter.
IMHO it is IPv6 that was causing the issue, I know my router doesn't support it natively (Someone else here mentioned linksys, mine's a wrt54g v3.1 f/w4.00.7) and perhaps this was the issue all along, or has that been tried already? I've been wrong before ;)
@Alrst22 - I see from your config that you have IPv6 enabled, perhaps you could try disabling it and let us know what happens.
In case you don't know how to do this:
Control Panel > Network & Sharing Center
Select "Manage Network Connections" from the task list
Right click the network connection you're using to connect to the net and select properties
In the list of items under "This Connection uses the following items:" untick "Internet Protocol Version 6 (TCP/IPv6)" and click ok.
I know IPv6 is supposed to tunnel with IPv4 and it's not exactly progressive to turn it off but that's now the only "real" difference in the config between now and when I had issues. Any other ideas?
Cheers,
Marv
    Me
    Core2 Duo E8400 @ 3.0GHz
    Gigabyte EP35DS4
    8GB Crucial Ballistix PC6400 CL4
    ATI Radeon HD 3870 X2
    On board using DTS Connect
    LG-L246WH 24" Widescreen + Acer 17" TFT
    1 x 250GB WD SATA1 4 x 500GB Segate 7200.11 SATA2 (RAID5)
    Coolermaster 700w modular
    Coolermaster Cosmos C-1000
    Stock HS & Fan
I am having the sames issues regardless of wired or wireless connection and regardless of network. It seems to be an issue with my computer. I can use the internet for approximately 30-60 minutes and then I won't be connected anymore. I unplug cablem modem & router and rarely this helps. I try to reconnect using the network and sharing area with no luck. I am required to reboot the computer and this usually works. At all times the network and sharing say that my connection to the network is active and shows that I can connect to the internet. However when I click on the world icon, it won't connect. Nor will it when i click on internet explorer. I have reset my IP addresses manually and this seemed to help, but I am having the same problem now as I was before.
Please help me fix this issue. It is time consuming and really frustrating since I am completely dependent on this computer for work. Thank you
There will be no internat at all if i set the DHCP settings manually(i have tried).
The problem has just disappear without explanation.
I just tested to set the DHCP settings manually, but the connection didn't work as good as it do with automatic DHCP settings.
This problem will come back, it's just a question about when.
